Unknown bolt/grease zerk - Diesel Forum - TheDieselStop.com
 4Likes
  • 1 Post By ArcticDriver
  • 2 Post By bugman
  • 1 Post By larrgh
post #1 of 12 (permalink) Old 08-06-2017, 09:23 AM Thread Starter
This was found where i park my trk,only other thing that has been parked there is an f150 ...any idea's where this goes?...
2016 F350 FX4 CC Lariat pkg-diesel 6.7
jwbboat is offline
post #2 of 12 (permalink) Old 08-07-2017, 12:22 AM
Muffler bearing!
Sent from my SAMSUNG-SM-G890A using Tapatalk
diesel2121 is offline
post #3 of 12 (permalink) Old 08-07-2017, 01:36 AM
ArcticDriver's Avatar
Trailer Axle Bolt?
ArcticDriver is offline
post #4 of 12 (permalink) Old 08-07-2017, 07:41 AM
Relentless007's Avatar
reminds me of the bolt on top of lawnmower deck that holds the blade and belt wheel.
1997 F250 Heavy Duty 7.3 Powerstroke 4x4 Crew Cab, SRW, Automatic E40D
BTS Valve Body
Tru-Cool Trans Cooler
4" Turbo Back Diamond Eye Stainless Exhaust
Tymar Air Intake
TS Six Position Chip (stock,High Idle, +50, +75, +100, +120)
Tymar HPX line in hand but no installed yet
285/75r16 BFG All-Terrain KO2
ARE LSII Custom Color Tonneau bed cover
Color match Rhino spray in bed liner
Better To Be Tried By 12 Than Carried By 6
Relentless007 is offline
post #5 of 12 (permalink) Old 08-07-2017, 07:55 AM Thread Starter
Originally Posted by ArcticDriver View Post
Trailer Axle Bolt?
thanks,..i hadn't thought of that,..i had my 2 boats in there(trk barn)..doing some things to them months ago..will ck that..thanks for the reminder
jwbboat is offline
post #6 of 12 (permalink) Old 08-07-2017, 07:57 AM Thread Starter
thanks for the response,..this was in an area that I cant take my mower...good thought tho
jwbboat is offline
post #7 of 12 (permalink) Old 08-07-2017, 12:31 PM Thread Starter
Nope,not off my boat trailers
jwbboat is offline
post #8 of 12 (permalink) Old 08-07-2017, 04:54 PM
A neighbor tossing it on your drive because he knew it would bug ya? ;-)
ford_doctor likes this.
post #9 of 12 (permalink) Old 08-07-2017, 05:20 PM
ford_doctor's Avatar
Looks like a bolt head with a hood prop/liftgate prop mount (the ball) or a mount for a ride height sensor rod. A little large to be a Zerk... the pictures are small so I can't zoom in to see much detail.
2016 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is online now
post #10 of 12 (permalink) Old 08-07-2017, 05:33 PM
bugman's Avatar
My Photos: (12)
Just throw it away and within 2 days you will find where it is suppose to go.
bugman is offline
post #11 of 12 (permalink) Old 08-08-2017, 07:07 AM Thread Starter
the bolt is hollow,for greasing..zerk on one end,hole on the other...after more research,..this appears to be what is called a 'wet-bolt'...used on axles..it was nt buried in the dirt,..it was on top of the ground...pretty puzzling
jwbboat is offline
post #12 of 12 (permalink) Old 08-08-2017, 11:36 AM
That maybe a "wet bolt" but it is not big enough for spring hangers. Also too many threads on the bolt that would weaken it. Wet bolts have an actual zerk in the end, it is not made into the spring hanger bolt.
I am more inclined to agree with Ford Doctor. It is for some type of gas charged shock mount that holds the hood or trunk lid open.
jwbboat likes this.
Larry
larrgh is offline
