Where is the Aux input jack? - 2015 F350 - Diesel Forum - TheDieselStop.com
 2Likes
post #1 of 19 (permalink) Old 02-25-2018, 08:23 PM Thread Starter
Mustanglee's Avatar
Where is the Aux input jack on the 2015 F350. I have looked everywhere I can think of. I have the Media center on top of the dash. It as every kind of jack that you can think of, except Aux input.
Mustanglee is offline
post #2 of 19 (permalink) Old 02-25-2018, 09:19 PM
check page 320 of your owner's manual. If you do not have a manual, you can download one here...
https://owner.ford.com/tools/account...h-results.html
Larry
larrgh is online now
post #3 of 19 (permalink) Old 02-25-2018, 10:58 PM Thread Starter
Mustanglee's Avatar
Yeah, I checked the manual before posting this. It shows a picture of the jack but it doesn't say where it is. Not on the dash, not in the console, not in the media center. Where can it be hiding?
post #4 of 19 (permalink) Old 02-26-2018, 05:26 PM
If it has the high end Sony system it doesn't have an aux in. My 2016 f250 doesn't. Just the media centre SD slot, 2x usb ports and the RCA left right connections which is the aux in for the radio. I had an RCA to din adapter and plugged my portable Sirius XM radio into those.
Sent from my Moto G Play using Tapatalk
Roadrunner II is offline
post #5 of 19 (permalink) Old 02-28-2018, 07:43 PM Thread Starter
Mustanglee's Avatar
Wow! A $65,000 truck with no Aux in. Even the cheapest Hyundai has one. The RCA to din cord was plan B. I have XM radio in the truck but my Lance cabover camper blocks the antenna. I have not found a reasonable way to remedy that situation. My idea was to install an XM vehicle kit and use my home radio with a magnetic antenna on the hood. Or bring lots of CDs.
post #6 of 19 (permalink) Old 02-28-2018, 08:05 PM
Drivers side under dash the antenna has a connection. Just use a magnetic antenna
post #7 of 19 (permalink) Old 02-28-2018, 08:33 PM
For the Sirius that is. Should be able to disconnect factory antenna and plug in the mag mount
RoadrunnerII
post #8 of 19 (permalink) Old 03-01-2018, 02:18 AM
Kraig1957's Avatar
I have over 25,000 mp3 files split between two 128GB flash drives plugged in the USB ports.
HeavyAssault and ford_doctor like this.
2016 F350 DRW FX4 Lariat King Ranch Crew Cab 6.7 V8
2011 F350 SRW 4X4 Lariat Crew Cab 6.7 V8 (Sold)
2006 F450 DRW 2X4 XLT Stake Bed Crew Cab 6.0 V8 (Sold)
2016 Mustang GT Premium 5.0 V8
2003 Crown Victoria LX 4.6 V8
1967 F100 Pickup 352ci V8, C6 automatic
1972 Pontiac Lemans 400ci V8, Turbo-Hydromatic 400
1964 Pontiac Catalina 389ci V8, Roto-Hydromatic 375 (Slim-Jim)
Kraig1957 is offline
post #9 of 19 (permalink) Old 03-01-2018, 05:21 PM
ford_doctor's Avatar
I do the same with my Fusion. It's nice having my entire library on board. Also, high capacity thumb drives are not all that expensive and I bought a low profile or compact drive so it does not get int he way.
2016 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #10 of 19 (permalink) Old 03-02-2018, 06:23 AM
HeavyAssault's Avatar
My Photos: (6)
Any pics of your media center? Seems odd that yours is "missing" RCA inputs. I got the Sony system using an RCA-3.5mm jack adapter working great. Just ran the cable to the console for my input.
2015 F-350 CCLB PSD 4X4 3.55 ELD
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
post #11 of 19 (permalink) Old 03-04-2018, 12:03 PM Thread Starter
Mustanglee's Avatar
No, I have the RCA jacks. Ordered the adapter cord and putting in my XM car kit and magnetic antenna on the hood. Found a cool mount for the car kit that goes in the cup holder. Regarding antenna input under dash on drivers side, I believe that they eliminated that in 2015. I have searched and searched for it. Somebody posted a bulletin a while back that shows it behind the radio. No way am I going to try to pull the dash and wiring apart. With my luck, nothing would work after that.
post #12 of 19 (permalink) Old 03-04-2018, 08:21 PM
My 2016 has the antenna connector drivers side just above e brake. I know it is there because I used it for my portable Sirius XM radio
RoadrunnerII
post #13 of 19 (permalink) Old 03-10-2018, 03:45 PM Thread Starter
Mustanglee's Avatar
What does it look like?
post #14 of 19 (permalink) Old 03-12-2018, 06:36 PM
It is the yellow plug with orange clip. It is mounted on the support just to the right of the emergence brake
RoadrunnerII
post #15 of 19 (permalink) Old 03-17-2018, 06:10 PM Thread Starter
Mustanglee's Avatar
OK, found it hiding in plain sight. Looks like you can pull the yellow plug and orange clip holds cable in plug? The cable for the magnetic antenna has a right angle plug, so I'm not sure that this will plug into the yellow Ford plug. I see FAKRA adaptors advertised online. Do I need one of these? Sorry for the dumb questions but I had shoulder surgery a few weeks ago and can't use my right arm to reach up and fiddle with the plug.
Last edited by Mustanglee; 03-17-2018 at 06:49 PM. Reason: Needed to ask more questions.
