Would you buy - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By larrgh
post #1 of 5 (permalink) Old 09-13-2019, 01:16 PM Thread Starter
Texkenusmc's Avatar
Question Would you buy
I found a 2016 f350 4x4 dully 6.7 with 80,000 miles for $30,000. It got deff in the tank and had the whole fuel system replaced by ford dealer. Would you buy one that had this issue.
I can't believe I am thinking of letting my old 7.3 go.
Texkenusmc is online now
post #2 of 5 (permalink) Old 09-13-2019, 02:33 PM
I see no issues as long as the dealer warrants the parts in the contaminated fuel kit for the 2 years and the labor provided you were not the cause of a fuel fuel related problem
HeavyAssault likes this.
Larry
larrgh is online now
post #3 of 5 (permalink) Old 09-16-2019, 10:19 AM
The damage this causes has no impact on the base engine, it only harms the injection pump, injectors, rails, fuel pressure sensor and relief valve. The tank and filter housing need to be flushed and there are some lines that are usually replaced. The kit has all but the pieces that vary with model year within an injector and pump use group. If the truck has been in use for a few thousand miles post repair then the work was done correctly as the corrosion and failure from DEF contamination not dealt with properly comes back in a short time.
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
post #4 of 5 (permalink) Old 09-18-2019, 06:14 PM
HeavyAssault's Avatar
My Photos: (6)
@larrgh has you covered. Make them put it on paper they will cover any and all costs for those components over the next two years.
2015 F-350 CCLB PSD 4X4 3.55 ELD
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
post #5 of 5 (permalink) Old 09-19-2019, 11:12 PM
pitstop's Avatar
That sounds a good deal to me provided the parts are in warranties.
pitstop is offline
