'2017 Dually TPMS? - Diesel Forum - TheDieselStop.com
'11-16 Ordering Information Discussion of ordering and status of an order of a Super Duty truck. All engine types allowed.
post #1 of 9 (permalink) Old 11-20-2016, 08:12 PM Thread Starter
'2017 Dually TPMS?
Do the 2017 duallys come with TPMS standard or as an option, I hope it's not standard.
mmxvxlt is offline
post #2 of 9 (permalink) Old 11-20-2016, 09:36 PM
Individual Tire Pressure Monitoring System (TPMS) – SRW/F-350 DRW only
So, appears it does come on the dually now as standard equipment
Larry
larrgh is offline
post #3 of 9 (permalink) Old 11-21-2016, 05:57 PM Thread Starter
Went by a dealer today, they had a dually I could look at, said yes it is standard and there was no way to turn it off even though it is above the GVWR limit.
mmxvxlt is offline
post #4 of 9 (permalink) Old 11-21-2016, 06:49 PM
I suspect if you were able to turn off the TPMS. It would have to be done via the BCM/PCM with the Ford VCMII and IDS. The 2011 thru 2016 have an option to turn on/off the TPMS since the same module is on both SRW and DRW. The TPMS is allow programmable for the tire pressure thresholds.
Larry
larrgh is offline
post #5 of 9 (permalink) Old 11-21-2016, 10:35 PM
Phillippeterson's Avatar
Why do you want to turn it off?
Phillippeterson is offline
post #6 of 9 (permalink) Old 11-22-2016, 04:29 AM
Why does a person do lots of things that others do not understand?
Larry
larrgh is offline
post #7 of 9 (permalink) Old 11-22-2016, 06:51 AM
I have had duallies for decades. Flats on inboard tires that are undetectable when not loaded have damaged 4 trucks and caused replacement of tires where there was no damge to vehicle on twice that many more. I think dually TPMS is more useful than it is ever has been on a SRW truck.
TPMS is aggravating when tires already having borderline low pressure end up triggering warnings on that first cold morning.
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
post #8 of 9 (permalink) Old 11-22-2016, 08:33 AM
Yes, indeed, why? Although I am not doubting someone's reason for the delete. I just want to learn from others. He must have a reason for wanting to not have a dually TPMS. And it may be a great reason or a not so great reason. Still, any reason is worth hearing.
post #9 of 9 (permalink) Old 11-22-2016, 06:14 PM Thread Starter
The main reason is, if it is not mandated to have it then I don't want it and I don't need it, it is something else to have an issue with and with the jobs I've had, you get in the routine of checking the vehicle, I've only had 3 tires catch me off guard in 20 years. Actually it would not bother me so much if they had two settings for the rear, loaded and unloaded but I know that makes sense and ford won't do it.
mmxvxlt is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Ordering Information
