Power Steering - Diesel Forum - TheDieselStop.com
'11-16 Gas Engines Discussion of the gas engines available in the 2011-Up Super Duty trucks
post #1 of 3 (permalink) Old 07-06-2019, 04:23 PM Thread Starter
Power Steering
2012 F250 4x4
At idle or slow speeds the steering is super hard. When accelerating or gaining speed it seems to function properly?? Not sure if the pump is out (or going out) or if maybe it is a bad line?? Any help would be appreciated!
lj8215 is offline
post #2 of 3 (permalink) Old 07-06-2019, 07:29 PM
Sounds like the pump. Make sure the drive belt is tight and the fluid is full before you buy a new pump
Stroking it is offline
post #3 of 3 (permalink) Old 07-06-2019, 07:53 PM
Make sure that your foot is off the brake. Power steering doesn't work when your foot is on the brake.
DonWarkentin is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Gas Engines
