x springs - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 11-09-2001, 10:55 AM Thread Starter
x springs
What is all the talk about x springs out of F-550's used on F-250 and 350's?
'01 F-350, XLT, V-10, 5 spd, SC, LB, Torreador Red, Weld Outback, ProComp AT's, Line-X, Slide-N-Lock, APC Diamond corners, Flowmaster 40
Just remember- racing stickers may add 5hp but engine chrome adds 10hp!
aleig14572 is offline
post #2 of 4 (permalink) Old 11-09-2001, 08:34 PM
Re: x springs
I've got a 250 4x4 with a V-10 and the snowplow package, so I've got the x springs. The plow setup is approx. 1000 lbs, BTW. I had to buy the snowplow package, since I plow with my truck. That being said, the truck sits level and I like it that way. The SDs that I see without the x springs have a bit of a rake towards the front. After seeing this, I'd buy the plow package just so the truck sat level. YMMV SamC
SamC is offline
post #3 of 4 (permalink) Old 11-09-2001, 11:33 PM
Re: x springs
People are installing the "X" springs to increase front ride-height. It's mostly done for appearance, but some (mostly PSD owners) have installed them to fix/prevent spring sag do to the heavy weight of the engine.
NoMo is offline
post #4 of 4 (permalink) Old 11-12-2001, 08:16 AM
Re: x springs
I'll add if your looking for a lift I wouldn't do the x spring change. The longer the truck the less lift. For another $150-$200 you can get a real lift and proven results.
For my trouble I got maybe 1" of lift. I got more lift (1.25") from cutting the old springs down to about 16" and sliding them underneath the springs. No sag with these.
Rob
99.5 CC LWB 4x4
robsd is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
