'2012 Ford F750 Brake Lights Not Working - Page 2 - Diesel Forum - TheDieselStop.com
Automotive Electrical & Wiring A place to discuss Electrical & Wiring issues.
post #16 of 18 (permalink) Old 06-08-2018, 12:57 PM
ford_doctor's Avatar
Okay - the 2013 system is a different system.
Normal Operation — Hydraulic Brakes
Voltage is supplied from Battery Junction Box (BJB) fuse F5 (5A) to the dual brake warning switch. Voltage is supplied from the Battery Junction Box (BJB) fuse 7 (15A) to the ABS event relay switch and coil. When the brakes pedal is pressed the dual brake warning switch inputs a voltage signal to the hydraulic brakes module. The ground side of the ABS event relay is controlled by the hydraulic brakes module. When the ABS event relay is energized voltage is routed to the multifunction switch and the body builder stoplamp relay coil.
Air Brakes
Voltage is supplied from the BJB to the stoplamp switch(es). When the brake pedal is applied, the stoplamp switch(es) routes voltage to the multifunction switch and the body builder stoplamp relay coil.
All Brake Systems
When the brake pedal is applied, the multifunction switch routes the voltage to the LH rear lamp (both LH and RH circuits), and to the LH and RH body builder turn relay coils. Voltage for the RH rear lamp is then routed out of the LH rear lamp to the RH rear lamp. Ground for the RH rear lamp is routed into the LH rear lamp. The ground circuit is spliced internally to the LH rear lamp.
The BJB supplies voltage to the body builder stoplamp relay switch side through. When the body builder stoplamp relay is energized, voltage is routed to the body builder connector.
The body builder turn relays (switch side) are supplied voltage at all times. When the LH or RH body builder turn relay is energized, voltage is routed to the body builder connector.
2016 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is online now
post #17 of 18 (permalink) Old 06-15-2018, 09:39 AM Thread Starter
Update: So the brake light issue has been fixed! I ended up getting a 72 hour www.motorcraftservice.com subscription just to see how helpful it would be, and by-golly it was amazing, everything that I needed was in there!! Turns on a connector close to the BJB had a very small wire that was corroded, I repaired the circuit and all is well now! EXCEPT, now my back up lights and the warning beeper are not working, I honestly don't know if they ever worked simply because when we got the truck we never had to put it in reverse, until I was backing it out of my bay and that's when I noticed that issue. So here's the problem, I have the schematic and the workshop manual for this problem, I have encountered that even with the VIN inputed into the motorcraft website, there are slight differences with the truck im working on as opposed to the truck in the workshop book. The workshop manual tells me to check for voltage at the Vehicle Interface Module circuit 295. Now the plug its asking me to check for isn't on this transmission! So yeah now I'm stuck again...FML!!
BTRfleetTech is offline
post #18 of 18 (permalink) Old 02-08-2019, 06:08 AM
Odd that this is coming up on the active threads page now...
With regard to "stuff not being the same" look more carefully at the schematics. Each section may contain different diagrams depending on the engine or transmission you are working with. Also, those boxed arrows with a letter inside and page/section numbers next to them send you to a different section in the book. Also, yes, there can be production changes that are not reflected in the manuals due to timing. If you are absolutely sure that something does not look the same, try looking in the previous or next model year book. I have run into this a few times especially with the medium duty trucks.
  Diesel Forum - TheDieselStop.com > Other Topics > Automotive Electrical & Wiring
