Automotive Cable - Which Type? - Diesel Forum - TheDieselStop.com
Automotive Electrical & Wiring A place to discuss Electrical & Wiring issues.
 5Likes
  • 1 Post By Steve83
  • 1 Post By bugman
  • 1 Post By DENNY
  • 1 Post By Big Horn
  • 1 Post By ArcticDriver
post #1 of 6 (permalink) Old 05-07-2019, 03:48 AM Thread Starter
Fix
Fix's Avatar
Gents, question on which type of auto cable to use for a job.
I want to wire up an anderson connector to my battery and leave it somewhere with easy access, (like under the seat at the passenger side door).
It's for quick easy access for jump starting other vehicles when out on breakdown calls.
I don't want to have to be connecting clamps directly to the battery.
Does anyone know what sort of cable I should be using?
Fix is offline
post #2 of 6 (permalink) Old 05-07-2019, 05:34 PM
Steve83's Avatar
Common stranded Copper wire. If you're asking for the SIZE; that would depend on the amount of current you expect to supply through this connector, and the total length of wire from your truck's battery (batterIES?) to the alligator clamps.
But what's the point? You'll still have to connect jumper cables to every other vehicle's battery since they won't have quick-connectors under their seats. And it's not likely that your seat will be the closest point on your truck to a vehicle that needs a jump - it's more likely going to be the front bumper, which is where those connectors are usually installed. Shop the wrecker websites; here's one:
https://zips.com/
Fix likes this.
Steve83 is offline
post #3 of 6 (permalink) Old 05-07-2019, 11:13 PM
bugman's Avatar
My Photos: (12)
If I was going to do something like this I would go with a 1/0 welding cable with either crimped or soldered on ends.
1/0 will be oversized for most applications but being oversized is better than undersized.
I would also place a battery disconnect switch on it near where you tie it into the vehicles battery so that it won't be hot all the time.
Fix likes this.
bugman is offline
post #4 of 6 (permalink) Old 05-08-2019, 12:17 AM
This is a great mod to have. I have one to rear bumper and front grill. I bought a HD set of cables and put the connector in the first foot of the cables so I have standard cables/front/rear jump capability. I can jump or be jumped from front or back. Both front and rear cable tie into passenger side battery send me a PM and I will walk you through it.
DENNY
Fix likes this.
DENNY is offline
post #5 of 6 (permalink) Old 05-11-2019, 04:40 PM
Big Horn's Avatar
I’ve got battery disconnect, ANL Spartan fuse holder, 2/0 welding cable, 350A X-Haibei disconnect plug behind license plate for my jumper cables, winch, and 3K watt inverter.
Fix likes this.
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #6 of 6 (permalink) Old 05-13-2019, 10:02 AM
ArcticDriver's Avatar
That engine compartment looks spotless. 😉
Fix likes this.
SOLD:
ArcticDriver is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Automotive Electrical & Wiring
Similar Threads
86 e-350 throttle cable motoit 6.9L IDI Diesels (Not Power Strokes) 1 09-22-2009 08:36 PM
No Power to Alternator Cable GraemeDiesel 6.0L Power Stroke Engine and Drivetrain 2 09-01-2009 11:40 AM
Stretched Throttle Cable??? Plywood 7.3L IDI Diesels (Not Power Strokes) 13 06-23-2008 12:50 PM
Should i run type F in my c-6? farnereinar 6.9L IDI Diesels (Not Power Strokes) 10 12-03-2005 04:10 PM
e-brake cable removal Q jmann Power Strokes 1994-1997 General 2 08-07-2005 12:49 PM
