Trailer Stop and Turn Lights - Diesel Forum - TheDieselStop.com
Automotive Electrical & Wiring A place to discuss Electrical & Wiring issues.
post #1 of 5 (permalink) Old 05-11-2019, 08:07 PM Thread Starter
Big Horn's Avatar
I lost my stop and turn signal lights on my boat trailer on my last day of fishing last week. Yesterday I checked my wiring and then owners manual.
I was pleasantly surprised that Ford wires up the trailer plugs to a separate fused circuit (#6 20A)
The water must have shorted the circuit somewhere on the trailer as the fuse was blown.
I’m usually with the camp of “unplug” lights before putting trailer in the water, but I know a lot of guys don’t.
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #2 of 5 (permalink) Old 05-12-2019, 10:11 AM
69mach1377's Avatar
I found out that Ford's color codes for a 7 pin connector do not match the 'standard' colors while on vaca last month. At least the ground and trailer brakes match...but the lights were wak.
2000 F250 XLT 4x4 SC 7.3 w/rebuilt 4R100, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods, lakes and streams if possible.
See my album for a recent pic.
69mach1377 is offline
post #3 of 5 (permalink) Old 05-12-2019, 01:55 PM
Steve83's Avatar
Fresh water (near Illinois) can't short a 12V circuit; its resistance is far too high. Even salt water has too much resistance to pass more current @12VDC than a typical trailer lighting fuse. Look for a pinched wire on the truck or trailer, or a smashed bulb.
Ford revised its colors to match SAE colors in the early 90s, but the colors molded into the connector and used by most trailer pigtail manufacturers are NOT SAE - they're the original standard from the ~70s (or earlier).
(phone app link)
Steve83 is offline
post #4 of 5 (permalink) Old 05-12-2019, 03:02 PM
69mach1377's Avatar
Yeah, wish I had known that when I stepped on the cable and broke stuff. Ford's connectors don't help either...
post #5 of 5 (permalink) Old 05-16-2019, 03:43 PM Thread Starter
Big Horn's Avatar
(phone app link)
Thanks Steve83, My son and I went fishing Monday—left lights plugged in, in and out of the lake. No issues this time-no blown fuse, go figure....
Big Horn is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Automotive Electrical & Wiring
Similar Threads
Combination multifunction switch for hazards turn and stop lights SOLVED alalor1 1999-2007 General Questions 0 05-30-2017 01:29 PM
WEIRD transmission and electrical problem 97 F250 westend301 Power Strokes 1994-1997 General 6 04-15-2010 01:18 AM
TBC Fault Asaff Towing and Hauling 8 06-03-2009 06:34 PM
Help! No Brake Lights and Turn Signals at trailer plug-in hotincolo Towing and Hauling 7 04-13-2009 07:20 PM
turn and stop lights Gone Fishen Power Strokes 1994-1997 General 6 09-26-2007 12:04 AM
