how do i make my 96f250 7.3 black smoke more - Diesel Forum - TheDieselStop.com
Powerstrokes 1994-1997 General FAQ Frequently asked questions in the Powerstrokes 1994-1997 General forum.
 2Likes
Closed Thread
post #1 of 17 (permalink) Old 08-22-2011, 09:58 AM Thread Starter
i was wondering is anyone knows if the 10k resistor mod is good? will it make my truck black smoke more? please let me no thanks
96powerstrokediesel is offline
post #2 of 17 (permalink) Old 08-22-2011, 11:10 AM
SteveBaz's Avatar
My Photos: (12)
Send a message via Skype™ to SteveBaz
Hey Welcome to Ford Diesel.
A great way to start is to open up all the exhaust system first.
There is a lot of things that can be done to make your truck more powerful.
Diesels need a lot of air and a free flowing exhaust. As a matter of fact without a free flowing exhaust you will get no power and that would be your weak link to getting more power. Some power mods are more important than others.
Start at the air intake and get a better air intake. Do some searches on "Air Intakes".
Then that goes from the intake to the Turbo. You can leave the stock one or go to a high capacity 1" turbo housing.
From the turbo to the Down-pipe. If your down pipe is stock that means its flat against the firewall (another Fine Ford Idea) you need to replace that with a aftermarket DP I have a "Hypermax Down Pipe" but there are other companies out there.
From the Down Pipe to the catalytic converter that need to be removed, gutted out or replaced with a cat delete pipe part number Ford part number F4TZ-5A212-V.
From the catalytic converter to the muffler (your choice) that has free air flow with at least 4" exhaust and then some folks have even 5" exhaust and then out the muffler.
You now have set your truck up to breathe and you can start adding power. The quickest way at this point to add power is a chip programmer.
Good luck,
BAZ....
SteveBaz is offline
post #3 of 17 (permalink) Old 08-22-2011, 11:19 AM Thread Starter
yea i have an intake 3" turbo dowpipe edge chip, no cat or muffler to a 6 inch stack and i have a shift kit still barley black smokes, i wanna make it smoke cheap lol, my buddy wants to sell me a banks 6 gun tuner soo i might get that but any other ideaas?
post #4 of 17 (permalink) Old 08-22-2011, 11:27 AM
SteveBaz's Avatar
My Photos: (12)
InjectorsandDifferantOutputs
The difference between the injectors is as follows quoted by Richard Maddon �Maddog� who did the rebuilds for me. I am sure if you are interested in talking they would be pleased to discuss them with you.
We have bench tested the High Output International injector and they do flow more fuel than the stock ford injectors and the modified or stage two injectors. But they are very expensive like $500 per injector.
ThatisfromInternationalandaDieselInjectionService
The stock Ford injectors (94-97) flow 95 to 100 cc's on our flow bench.
The stock Ford injectors (99-01) flow 120 cc's on our flow bench.
The stage one injector�s flow 160 cc's (Stage 1 160 cc�s after 2600 rpm�s) Wide open throttle (WOT)
The stage two injector�s flow 160 cc's (Stage 2 160 cc�s after 2000 rpm�s. Mid range and up.
The H.O. International injectors 240cc's
The modified H.O. International injectors are flowing over 300 cc's
These test's are done at a 3000 rpm's, on a 1000 count test.
I was told split shot injectors will not work in my 96 but somewhere I heard that it would in a 97 but I am not sure. I was also told that the fit of 99+ injector would not fit 94 to 97. I am not a professor on injectors but that�s what I was told. The Stage Ones were a very substantial increase in horsepower at WOT (Wide Open Throttle). They are saying that the power increase is at least 75 horsepower and as much if not more than propane injection. The injectors are balanced and calibrated. Balanced meaning the spray pattern and calibrated is so that each injector produces within 2 to 3% the same amount of fuel to each cylinder. As compared to HYPERMAX injection re-build Richard told me all the springs inside are checked for the same spring load and all the internal parts are replaced and no used part goes back in like the Hypermax re-builds. It was said to me that the re-build Hypermax does for $880.00 compared to the $995.00 from Richard and I have heard it from an other source that they re-build with used parts that are tested and pass there inspection and the ones I have are all new internal parts including the updated new o-rings.
BAZ...
SteveBaz is offline
post #5 of 17 (permalink) Old 08-22-2011, 07:08 PM
you need a better chip for one, dp or tony wildman and you need bigger injectors. mine smokes like a coal train when i gun it on the 120hp setting, otherwise it hardly smokes, which means it is set up efficiently.
2003 F350 crew cab 4x4 , 295's on 17's, performance MFG coolant filer, Blue spring, new HFCM, FICM, Batteries and Alt. SCT performance tune, 128k on engine 12/13. Stock everything else.
ryhed is offline
post #6 of 17 (permalink) Old 08-23-2011, 10:08 PM
DavidD's Avatar
You need a 6 position with a smoke position to dump more fuel into the engine then it can digest then it should smoke like a freight train... I've seen newer ford with a smoke switch not sure if the older ones can use that or not.
93 F-250 7.3L XLT Extended cab 2wd 235K Auto.
95 F-250 PSD XLT 4X4 E4OD Tony wildman 6pos chip, Custom intake,pillar Gauges
89 F-350 7.5L 5spd Dump
96 F-350 PSD 5 spd Dump
99 F-350 PSD 5 Spd Dump
96 IH 4700 DT466 7Spd Dump
2002 Isuzu NQR Dump was a box until I solved that problem.
DavidD is offline
post #7 of 17 (permalink) Old 08-23-2011, 10:23 PM
Yes, please make your truck smoke. That'll help get the EPA off of our backs.
Ozhold likes this.
Kevooo is offline
post #8 of 17 (permalink) Old 08-24-2011, 10:22 PM
The easiest way to smoke is just run a clogged air filter. Run the filter 60 or 70,000 miles it will hopefully be dirty enough to smoke. If waiting for clog is too long you can probably pour oil on the filter and roll it in some dirt, or cover a good portion of the filter so it cant flow air, like stuff rags in the intake. You need to snuff out the air to get smoke.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
RonKZ650 is offline
post #9 of 17 (permalink) Old 08-24-2011, 10:44 PM
Alecs's Avatar
My Photos: (12)
97 F-250 7.3l XLT 4x4 CC SB e40d
Diamond Eye 3x4 Downpipe
Four Inch Diamond Eye Exhaust, no cat
Tymar Intake
138,00mi as of 11.11.11
Alecs is offline
post #10 of 17 (permalink) Old 08-25-2011, 08:03 AM
You can always do the Wall-mart bag mod ....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #11 of 17 (permalink) Old 08-25-2011, 08:08 AM
drinkypoo's Avatar
My Photos: (25)
Let us know how the cops like your soot dispenser.
Ozhold likes this.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #12 of 17 (permalink) Old 08-25-2011, 09:11 AM Thread Starter
lol im not going to clog my air filter to black smoke, or walmart bag lol but yea ill keep u posted about the cops haha, seriously tho whats the cheapest best way to make my truck black smoke i have a 96 f250 ext cab long bed 4x4
post #13 of 17 (permalink) Old 08-25-2011, 09:39 AM
mustangii's Avatar
as you can see most people arent that fond of this but if you must blow smoke you need BIGGER INJECTORS and a good chip. this is not cheap! if you want cheap throw a smoke bomb in the bed and go for a drive
1996 f250 crewcab auto trans 4.10 gears 4x4 7.3 ts 6 pos -idm mod -a real tymar intake -3in dp -4inch mbrp exhaust -3 guages -a big trans cooler
-coolingmist water methanol injection -baby swamps and custom tunes by swamps. will it ever be enough?
towing a 2003 keystone sprinter 5th wheel 33.7 ft
mustangii is offline
post #14 of 17 (permalink) Old 08-25-2011, 10:38 AM
drcampbell's Avatar
My Photos: (32)
The EPA doesn't care about one individual truck; that's for local law enforcement. The EPA relies on averaged air-quality measurements over a whole city or region and focuses on sources of large amounts of air contaminants.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
- Never did get around to converting it to french-fry oil, which is why I originally stumbled upon this site.
drcampbell is offline
post #15 of 17 (permalink) Old 08-25-2011, 10:38 AM
drcampbell's Avatar
My Photos: (32)
"The Diesel Stop does not promote speeding or racing on the street and does not promote tampering with ANY EPA pollution devices for street driven cars or trucks!"
http://www.thedieselstop.com/forums/
IMEO, substituting bigger injectors for the injectors the vehicle's emissions were certified with constitutes tampering. I'm quite sure the EPA and CARB would agree.
Closed Thread
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 General > Powerstrokes 1994-1997 General FAQ
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
cfed
