Swapping to a 5 speed. Year model question - Page 2 - Diesel Forum - TheDieselStop.com
7.3L IDI Diesels FAQ Frequently asked questions in the Powerstrokes 7.3L IDI Diesels forum.
post #16 of 18 (permalink) Old 09-09-2014, 01:17 PM
I am trying to do the opposite. I have a 5 speed manual, and I'm trying to go to a c6. I have been having a horrible time trying to find the correct flywheel. I have a 9 bolt crank and all the ones the local auto stores could order was a 6 bolt. I finally ordered what seems like the correct one online, but it seems to need a spacer behind it to clear the block. Has anyone heard of this? Did your 7.3 w/ c6 have a spacer behind the flywheel? And if so does anyone know where I can get one, I haven't had any luck on internet searches. Thanks.
Coppercreektx is offline
post #17 of 18 (permalink) Old 11-16-2014, 08:45 PM
NH2112's Avatar
I'm almost 100% certain that there is a spacer between the flywheel and flexplate, it's a relatively common setup when using an automotive automatic & bellhousing adapter with an engine with an SAE bolt pattern. As far as where to get them, the first place I'd try is the Ford dealership and then the parts houses. As far as the spacer itself, maybe eBay? A Ford or Navistar dealer may have them, too.
Phil
Check my lists of common part numbers in my photos! Updated often!
1991 F350 Lariat XLT, 7.3l, 5-speed, crew cab, SRW, 3.55, 2WD.
1990 Jeep Wrangler Sahara, in the process of a major overhaul/upgrade. OM617 on the horizon! Front & rear Dana 44s from a Wagoneer till I get some 1-ton axles built & narrowed, and eventually a front shackle reversal. Diesel YJ, bay-BEE, and not a cookie-cutter 4BT conversion!
NH2112 is offline
post #18 of 18 (permalink) Old 11-17-2014, 01:33 AM
My Photos: (9)
C6 on 6.9s definitely had a spacer in there then a small flange that acted as a washer for the flywheel bolts. I'm going by memory but its pretty good, did a pile of rear main seals on the 6.9/7.3 idi while they were still under warranty.
I have a recently purchased 88 with a 7.3 /C6 I might be able to check for example but we got a lot of early snow here and I can't even get under it until we get some melt.
I hate winter, I'm a mechanic.
compression ignition rules
daily 2003 E350 EXT clubwagon 7.3 470,000km 15/04/17
newest member 2005 E350 clubwagon 6.0 160,000km(not running
other diesels: 1996 F250 supercab 2wd beater, 1996 F250 2wd parts truck, 1996 F 350 4wd parts truck, 2000 E450 cube parts truck,2003 E350 cargo parts truck, 1997 F350 2wd parts truck.
next summer : 89 E250 clubwagon xlt 360,000km
projects: 93 Bronco 2wd lowered on 96 7.3 parts
1986 E150 shorty maybe a 6.0 tweaked
68Mercury250Ranger is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > 7.3L IDI Diesels (Not Power Strokes) > 7.3L IDI Diesels FAQ
