Diesel Truck NITRO Gear Packages - Diesel Forum - TheDieselStop.com
JTS Parts & Accessories
post #1 of 8 (permalink) Old 12-24-2015, 04:52 PM Thread Starter
Just Diffs's Avatar
At Just Differentials we carry gear and axle accessories for nearly every vehicle out there. We work on developing and stocking the hard to find parts, or gear sets, so you can make one call to find everything you need to repair or replace parts in your axles.
Our Gear Packages include everything you need to regear both your front and rear axles with high quality parts. They include Front and Rear:
-Ring & Pinions
-Master Install kits with bearings, shims, seals, etc (MK)
-Solid preload Spacers if available (noted as SK in description)
-Pinion flanges (if noted with YOK)
Check out all of our diesel truck gear packages below. We have gear sets for many more vehicles then are listed on our website. If you need a quote or have a question, send us an email or call us at the number listed below. We only made a small number of our gear sets into packages with a single part number. So if you don't see your vehicle, don't worry, we can still help you out. Just give us a call or email us and we will take care of you!
(866) 525-4620 ---
Follow us on
Just Diffs is offline
post #2 of 8 (permalink) Old 12-24-2015, 04:55 PM Thread Starter
Just Diffs's Avatar
Diesel owners rejoice, Nitro now offers a 4.30 ratio for 2000 & newer AAM 11.5" rear axles!
Our brand new 11.8" AAM 4.30 gears are what every diesel owner has been waiting for. These new gears fit both the new AAM 11.8" housing and the 2000-2012 AAM 11.5" housings. Anyone with an older model 11.5" who has been waiting for gears can install this upgrade with ease. Larger diameter ring adds extra strength to your rear differential! Upgrade you GM or Dodge 2500 or 3500 diesel today.
AAM 11.8" Differential Gears
2001-2010, GM 2500 or 3500 - GPDURAMAX-4.30
GMC Sierra & Chevrolet Silverado with Duramax
Use AAM11.8-430-NG gear with MKAAM11.5 Master Kit
2011 & Newer, GM 2500 or 3500 - GPDURAMAX2-4.30
GMC Sierra & Chevrolet Silverado with Duramax Diesel
2003-2013 Dodge 2500 or 3500 - GPRAM-4.30
Dodge Ram with Cummins Diesel
2014 & Newer, Dodge 2500 or 3500 - GPRAM2500-4.30
Use AAM11.8-430-NG gear with MKAAM11.8-B Master Kit
(866) 525-4620 ---
Follow us on
post #3 of 8 (permalink) Old 03-18-2016, 11:56 PM Thread Starter
Just Diffs's Avatar
6 Reasons to Re-Gear your Truck!
1. Oversized tires - the engine is not running at optimum rpm at cruising speeds. This results in a “lugging” condition when pulling a heavy trailer and often the driver needs to resort to downshifting which revs the engine higher than ideal increasing wear and noise levels at highway speeds. Essentially under load the ideal narrow maximum efficiency rpm range simply cannot be found at normal highway speeds.
2. Fuel economy improves - Operating the engine at the correct RPM delivers maximum efficiency and economy.
3. Performance - Easily one of the most overlooked items of diesel performance is correct gearing. Faster revving means a faster truck, especially when pulling a trailer.
4. Lazy O.E. ratios - Many of these trucks are ‘under-geared’ from the factory. Tall ratios in the axles improve unloaded fuel economy numbers for EPA tests and are common from the factory as a result.
5. Drivetrain wear - Transmission temps and loads will be reduced by adding lower gears to the axles. Simply increasing the mechanical advantage in the final drive reduces stress on transmission and driveline. With heavily modified diesel engines the benefits can be seen in increased transmission reliability and longevity.
6. Opportunity to add a traction device.
When re-gearing adding a limited slip differential or locker improves traction and reduces unwanted wheel-spin at the same time. This improves wet and dry performance and makes it much easier to get moving with an unloaded truck when brisk acceleration is required (such as merging).
(866) 525-4620 ---
Follow us on
post #4 of 8 (permalink) Old 04-27-2016, 01:13 PM Thread Starter
Just Diffs's Avatar
Bumping this back up, we always keep Diesel Gear Packages in stock!
(866) 525-4620 ---
Follow us on
post #5 of 8 (permalink) Old 06-01-2016, 01:21 PM Thread Starter
Just Diffs's Avatar
35" or taller tires have a huge effect on performance, fuel economy and transmission life that is easily corrected by swapping the right gear ratio into the axles.
We stock complete 1 part number kits for these late model trucks that take the guesswork out and give you everything you need to make your diesel perform as it should once again.
Check out the link below for details or call 866 349 6801 to speak with one of our differential experts and we will help you get the right gears (and LSD units if you need more traction as well) for your truck.
(866) 525-4620 ---
Follow us on
post #6 of 8 (permalink) Old 01-09-2017, 07:08 PM Thread Starter
Just Diffs's Avatar
We had this rig at the shop a few weeks ago for a set of Nitro Gears, it has 40's with very little lift. If you are running big tires on your truck check out the link below to get correct gearing in your truck now!
(866) 525-4620 ---
Follow us on
post #7 of 8 (permalink) Old 06-26-2017, 05:32 PM Thread Starter
Just Diffs's Avatar
Did you upgrade your suspension and add oversized tires but forget to address your gears? We always keep NITRO Gear Packages in stock!
(866) 525-4620 ---
Follow us on
post #8 of 8 (permalink) Old 09-28-2017, 11:29 PM Thread Starter
Just Diffs's Avatar
Oversize tires and performance is now lacking in your diesel truck?
We're doing a full set of 4.30 Nitro Gear & Axle gears into this Dodge on 35's today in the shop. Truly the Goldilocks ratio we highly recommend 4.30 gears for diesels running 35-37" tires for optimum compromise between highway cruising and towing performance!
Contact us today and we can quote you the right parts for your rig today. 866 349 6801 or [email protected]
(866) 525-4620 ---
Follow us on
  Diesel Forum - TheDieselStop.com > Decommissioned > JTS Parts & Accessories
