Advice on a chip, tuner, module for safe daily driving - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 05-18-2006, 10:54 AM Thread Starter
I have a 2005 6.0L Excursion and am fairly new to the board. I use this mostly for commuting but do pull a 3500lb boat in the summer for maybe 10 miles a week. Currently I have a MBRP TB exhaust and might add a Pro Guard 7 soon as I have 19K on the odometer.
My question is what tuners, etc. are the most economical for getting a little bump in performance? I don't care anything about radical horsepower or messing with custom tranny shifts. Just something easy I can plug in and switch quickly on the fly that ideally leaves no trace on the computer. I've heard the new Painless SP Diesel Module will do this but I'm open at this point. Honestly 100 horsepower would be plenty.
2005 6.0L Excursion Limited, 4x4 Mineral Gray, 18x9 Ice Metal's w325/60 18's, Nitto Terra Grapplers, MBRP Turbo Back w/delete pipe, Fumoto valve, Westin Bull bar, Air Lift Bags, Dipricol pyro, boost, trans. temp, water temp, SCT custom tune by Innovative Diesel w/Tow-Street-Extreme Street
ERyser is offline
post #2 of 7 (permalink) Old 05-18-2006, 11:42 AM
Re: Advice on a chip, tuner, module for safe daily driving
I guess just remember that if you have the power available YOU WILL USE IT.. several sponsors have setups for you here .. the sct tuners are most bang for your buck and can ready trouble codes.. might give you abit more distance per gallon and you should be concerned with the tranny because if you add power you must address the shifting.. or you will pay for new parts.
look around some and most will agree if you are towing you should have a pyrometer at a minimum and check out the sponsors link someone have what you want..
2003 f250 SD Arizona beige
engine build date is 12-23-02 and a Jan 03 truck.. sct tunes,daily driver.
2 bad injectors, blown headgasket,bad egr, bad ebpr,front brakes,ohh and a bent pushrod.
yeasu ft90... 305 70 16 nittos..
4 inch stainless all the way..
afe intake...
3 dogs
1 glock
107k as of 5-18-06
116k as of 7-9-06
118k as of 8-17-06
125k as of 6-27-07
Davemcfarland is offline
post #3 of 7 (permalink) Old 05-18-2006, 12:14 PM Thread Starter
Thanks for the input Daveoh. I plan to add pyro, boost, and trans temp soon along with an AFE intake.
ERyser is offline
post #4 of 7 (permalink) Old 05-20-2006, 08:59 PM
guardrail22's Avatar
do a search on
EDGE CHIP VOIDED FACTORY WARRANTY!!
and see what he recommends
New Truck
2012 F150 SuperCrew Lariat 157" VWE
Traded March 2013
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver, 2010 NAV and Sync
Traded In Nov 07:
2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch
guardrail22 is offline
post #5 of 7 (permalink) Old 05-22-2006, 09:27 AM
Look at the Quad Xzillaraider modules. The 65hp setting is great for daily driving, adds a lot of low end power, from my experience. But after you try that you will want more, so get the 110hp module, this has a more power for the weekend, and only costs a little more.
'04 F-250, 6.0L, 6-speed, crew cab, long bed. 3-1/2" downpipe to 4" exhaust. MAC intake. Zoodad mod. TS Performance 5X Loader. May 04 PSD build. Hauls wife, kids, and lots of camping gear.
martyyeager is offline
post #6 of 7 (permalink) Old 05-22-2006, 03:24 PM
I had a Superchip 1704 and was pleased with the performance but got tired of sending it back to Superchips everytime the dealer flashed my truck. So I got the SCT Xcal2 and I love it! The truck runs much better now (not that it ran bad before)and the mileage has increased over what I was getting with the 1704. Call Eric or Ted @ Innovative Diesel. They will take care of you.
2004 Ford F250 Lariat FX4 6.0 Powerstoke Diesel SCT Xcal 2 aFe Stage 2 Cold Air Intake 4" Pro Comp Lift Firestone Air lift
35 x 12.50 x 16 Toyo Open Country A/T
2003 Excursion Limited 6.0 Powerstroke Loaded!
Powerslot Cryo'd Rotors and Hawk pads.
Destinsb is offline
post #7 of 7 (permalink) Old 05-22-2006, 04:09 PM Thread Starter
I'll look into the SCT as well.
Thanks.
ERyser is offline
