App: Torque 6.0L - Page 4 - Diesel Forum - TheDieselStop.com
post #46 of 75 (permalink) Old 04-03-2014, 01:25 PM Thread Starter
SteamRollin's Avatar
Originally Posted by Bsh102 View Post
Steam, I just reread your first post above. In the units section, I should have the box checked that says use degrees Celsius intead of Fahrenheit ?
It should be unchecked to use Fahrenheit, I switched and all the other Pids went to Celsius.
Leave the "Use Celsius" box unchecked.
There is no "Use Fahrenheit" box. I was multitasking when I posted that there was a "Use Fahrenheit" box. Sorry for the confusion.
'05 F250 Lariat 4x4 / Torque Pro / ARPs w/OEM HGs / Banks Ram-Air / Banks High-Ram Intake / Banks 4" Monster Exhaust(Muffler Delete) / Banks Techni-Cooler Intercooler / Sinister Coolant Filter Kit / Pace Edwards electronic bedlocker / stock wheels & tires / LED bulb conversion
SteamRollin is offline
post #47 of 75 (permalink) Old 04-03-2014, 01:55 PM
Double check your formula. In the past I found I had an uneven number of parentheses which gave me a flat 32 from cold start to fully warmed up.
Sent from AutoGuide.com Free App
2006 F-350 King Ranch 6.0; Banks Ram-Air; EGR Delete; 4" exhaust; Banks 6-Gun (non funct after EGR Delete); 20" Wheels.
RedStagg is offline
post #48 of 75 (permalink) Old 04-03-2014, 02:22 PM
Bsh102's Avatar
This thing is driving me nuts. Everything else is just the way it was prior except the EOT. There are 3 parentheses at the beginning and three more through out the equation just like Steam posted.
2005 F250 Crew Cab Lariat 4x4
Banks 4" exhaust
EGR delete
Blue Spring update
Torque App
New Oil Cooler
Turbo Drain tube upgrade
Sinister Coolant filter with Cat1 ELC
Bsh102 is offline
post #49 of 75 (permalink) Old 04-03-2014, 02:40 PM Thread Starter
Bsh102,
That's how it looks on mine. Check this link out see if maybe we're missing something. Bare with us, you'll get it figured out.
Forums — » Torque OBD ECU Scanner » Torque Discussion / Ideas » FORD 6.0 DIESEL NO EOT, PLEASE HELP!!!Torque
post #50 of 75 (permalink) Old 04-03-2014, 04:50 PM
Bsh102's Avatar
Originally Posted by SteamRollin View Post
Bsh102,
Thanks but I read that one and about 10 more. I now registered and asked the question over there as well. I have done about everything that anyone posted over there on how to make this thing work. I had zero issues the first time setting this up. I was like every one else, the issue was transmission not reading accurate temps. They gave out the change in the equation and it has been working fine ever since. I replace the FICM and lose all the data and have to set everything back up and I feel like a 2 yr old trying to figure this out. Very frustrating but for $40 invested I guess it is just part of the deal.
Banks 4" exhaust
EGR delete
Blue Spring update
Torque App
New Oil Cooler
Bsh102 is offline
post #51 of 75 (permalink) Old 04-03-2014, 08:25 PM
Bsh102's Avatar
Thanks guys for the assistance. Give me a wrench any day over trying to figure this computer stuff out. All is good, the Torque App is working the way it used too. All my PIDS are accurate and correct.
In case someone else runs into the issue. Remove everything from your app and phone. Let the system delete, which will take anywhere from 15 minutes to an hour. Reset the app, set up everything new and you should be good to go. I was wanting instant results and I guess sometimes patience is the only way but I had some free time today to get some things taken care of and just did not wait long enough when I reset the equations etc.
Once again this forum has proven itself to be a very valuable asset to us PSD owners. thanks.
Banks 4" exhaust
EGR delete
Blue Spring update
Torque App
New Oil Cooler
Bsh102 is offline
post #52 of 75 (permalink) Old 04-04-2014, 06:42 AM Thread Starter
I affirm you for posting this, I can't stand waiting for things either, especially when it comes to technology. I had the same situation happen to me about 2 months ago. However I was still using the Free version of Torque and couldn't get some of the units to update on the interface(gauges). What eventually fixed my problem was buying the Pro version which replaced all my existing PID/formulas with new ones.
Happy to hear everything worked out for you. I'll probably have to quote you sometime in the future as newcomers thumb through these post.
post #53 of 75 (permalink) Old 04-07-2014, 04:06 AM Thread Starter
Which PID are you guys using for the trans temp??? There seems to be 4 different options, Transmission Fluid Temp (Method 1) • Transmission Fluid Temp (Method 2) • Transmission Temperature(Method 1) • Transmission Temperature(Method 2)
Also, what information did you use for the 6.0's vehicle profile? These will differ a little from single, super, crew cabs & LWB/SWB & SRW/DRW.
post #54 of 75 (permalink) Old 04-07-2014, 08:31 PM
I down loaded the torque pro app on my phone how do I get the 6.0 ford set up
323flint is offline
post #55 of 75 (permalink) Old 04-07-2014, 09:21 PM Thread Starter
From the main screen on TP, hit your phone's option button and in the bottom left hand corner will be a "Settings" button. Press that, then scroll down to "Manage extra PIDs/Sensors". Press that, then again press you phone's option button and select "Add predefined set". A "Select Vehicle" screen will pop up and you'll want to select the "Ford (Incl PowerStroke)" option. And that's it. At that point in time you'll be able to select from 177 PIDs. Let me know it you have problems, otherwise, enjoy!
post #56 of 75 (permalink) Old 04-07-2014, 10:15 PM
Got it to work thank you can't beat it for 25 bucks
323flint is offline
post #57 of 75 (permalink) Old 04-30-2014, 05:09 AM
How many pids can you monitor? I have an insite cts , but might like this better. Also you could get a glowshift 3in1 to monitor egt, fuel and boost.
06 F250 XLT sc sb /w 200,000plus miles
tow pkg.
snow plow pkg.
upfitter /w
high idle mod
back up camera
rear back-up lights
Blue spring and banjo bolt mod
Edge insite cts
new interstate batteries / may have hurt FICM
only Ford filters
Flushed/ CAT coolant
low coolant temps
two new thermostats
new coolant senser/ still LOW COOLANT TEMPS
mobile one oil/ going back to rotella T-6
REV-X / helped stiction
ARCH OIL AR 9100 /stiction cured so far 27*
ARCH OIL AR 6200 / @ 2 mpg increase
2stroked out is offline
post #58 of 75 (permalink) Old 04-30-2014, 08:19 AM
No personal experience, but a lot of guys have posted problems with the glow shift setup.
'06 F250 4x4 - 5" Flo Pro exhaust, SB Filter intake, Accufab elbow, Edge Evolution (monitoring only), SCT w/ ID custom tune, FASS 195 pump, Gillette Diesel EGR cooler delete, Sinister Diesel coolant filter, ELC coolant, updated turbo drain tube/oil feed line/STC fitting/oil cooler, ARPs w/OEM HGs, Elite coolant lines, ITP RR fuel system, RCD 175/30 injectors, Powermax, BD CCV, FICM.com FICM w/ ID tune, Elite UP, BPD water pump - 13.069 @ 101.94
'02 WRX - Outback rear disc swap, EBC green pads, DBA pillar vane rotors, TXS UP/TBE/TMIC, Perrin LW crank pulley, PPG billet steel shift forks, ACT Streetlite flywheel & clutch, K&N filter, STi Group N motor/trans mounts, TiC/Kartboy rear diff mounts/subframe lock bolts/outrigger stiffeners, Kartboy SS & all shifter bushings, custom PDX tune for Cobb AP - went 14.1 on a terrible 60ft before most of these mods; shooting for 13.50s
TKOPerformance is offline
post #59 of 75 (permalink) Old 05-10-2014, 11:28 AM Thread Starter
Sorry for not responding sooner, I didn't see this post until now.
Take the amount of pids the Insight will/can display, then multiply it by 2-5 times, and even more if you decide to use a tablet.
The layout I use currently consist of 12 pids updating simultaneously. The pids I monitor are:
Row 1: Coolant Temp/ RPMs/ Engine Oil Temp
Row 2: Intake Temp/ Trans Temp/ ExhaustBack PSI
Row 3: Boost/ Fan RPMs/ VGT cycle
Row 4: FICM Logic Power/ VBattery/FICM Main Power
Allow me to explain a few factors. Once you've selected the "Realtime Information" icon from the main menu, this brings you to the main screen for monitoring your parameters. From this main screen, you are able to swipe between 5 pages of gauge layouts. You can increase and decrease the amount of swipe-able pages.
Select your phone's option button, a list of options will appear with "Add display" at the top. Selecting that will allow you to chose from several gauge types such as, dial needle, dial meter, digital display, etc. Once you've selected the type of gauge, you then select which parameter(sensor) you want designated to it. Finally after you choose the parameter, you select the size of the gauge you want. There are 6 sizes to choose from, Tiny, Small, Medium, Large, Larger, and Extra Large.
Then you drag and drop the gauge on any part of the current page you are on. To modify these, simply hold your finger on the gauge until an Items Options page pops up. You can post to Facebook, see history, zoom display, make it a floating widget(I did not know this), move display, bring to front, bring to back, and many other options are available.
-"Here's looking at you, kid."
The attachments from left to right:
Left - 5 x 8 pid layout to give you some perspective.
Mid - 6 different gauge sizes (mind you this is on an LG Optimus G)
Right - My current layout
post #60 of 75 (permalink) Old 06-12-2014, 02:35 PM
surfman
Guest
Posts: n/a
trans pid
Which PID are you guys using for the trans temp??? There seems to be 4 different options, Transmission Fluid Temp (Method 1) Transmission Fluid Temp (Method 2) Transmission Temperature(Method 1) Transmission Temperature(Method 2)
Which PID did you end up using for the trans? I am getting a big difference between the two that I am looking at.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
