better Themostat for the 6.0? - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 04-20-2019, 03:29 PM Thread Starter
Hartwig's Avatar
Hello,
does anyone know a thermostat for the 6.0 that opens more/wider, or can I machine it, for more opening at operating temperature?
My coolant is since the EGR delete approx. 10F colder in comparison with EGR cooler. (coolant pressure now 0-7 psi, with EGR cooler up to 18psi)
My camper is very heavy with 6.5 metric tons.
Today I measured the temperatures at the upper and lower radiator hose. At ECT 84C (183F) on the display there is only 66C (151F) on the upper hose and 44C (111F) on the lower hose. I think, the thermostat does not open completely. When I remove the thermostat, the engine warms up very slowly.
Is there a thermostat that opens further, so let more coolant to the radiator?
Thanks from Germany
Hartwig is offline
post #2 of 4 (permalink) Old 04-20-2019, 06:02 PM
bobofthenorth's Avatar
Before you start machining the thermostat I think you have some gauge or measurement errors. I don't understand how the top rad hose can be 18 degrees C cooler than the engine temperature. That's a huge delta - I don't believe it.
2006 F250 6.0 4x4
bobofthenorth is offline
post #3 of 4 (permalink) Old 06-01-2019, 11:20 PM
Part of the cooling problem is the coolant kind of dead ends at the back of the heads. I had to tap the back of the heads and put bypass lines up to thermostat, this increased flow dramatically and cooling.
K3 F350 6.0l 4x4, Crew cab, Lariat, shortbox, T.red, 285 BFG All Terrains, Sirius Radio, SS Grille, Silverstar fog and headlights, Boost and Fuel pressure gauges-Lunar Series Autometer. KYB MonoMax shocks 5w40 Delvac 1 14.7 mpg town.
Sushibar is offline
post #4 of 4 (permalink) Old 06-02-2019, 09:47 AM Thread Starter
Hartwig's Avatar
thats interesting. Do you have pictures of your upgrade?
Hartwig is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Similar Threads
idi swap 7.3 to 6.0 tjames3513 7.3L IDI Diesels (Not Power Strokes) 4 02-18-2012 11:43 PM
Have few questions on a recently bought F350 early built model (1-27-03) 6.0. TXDRAKE 6.0L Power Stroke Engine and Drivetrain 11 10-08-2006 07:39 PM
06 6.0 issues ???? hamp 1999-2007 General Questions 4 07-10-2005 02:26 PM
