Black dimond headgaskets 6.0L - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 21 (permalink) Old 12-04-2015, 11:03 AM
Eli
Eli's Avatar
I have 24k on my o-ring heads with Victor Black Diamond gaskets, which I think are the same thing. My truck weighs 9,500 as I drive it and don't always baby it. I drive a mountain pass about 4 days a week, too. Knock on wood, so far so good.
06 XL 250 6.0 Auto 4x4 Shortbox, Ex-Cab, 200k miles, ARP studs w/o-ring heads from South Houston Engine Services, IPR Remote Oil Cooler and filter, SCT tuner with ID and Gearhead Tunes, PHP FICM tuner, FICM from ficmrepair.com, DC Power alternator, 3.5" downpipe to Magnaflow 4" exhaust. ELC coolant, 2" leveling kit with 20's. She's a runner now!
EBC slotted and dimpled front rotors with EBC YellowSTuff Pads, solid rear rotors/YellowStuff pads. Good stuff!
95 XLT SC 4X4, 3.55, 5 spd, 317k miles, Bullydog extreme chip, Maddog Stage II 160cc injectors, Tymar Intake, 4" exhaust, Walker BTM,H-Max DP, exhaust brake, LUK, 2.5 lift with 285's on 8 Weld Typhoons/air bags.
In the picture...my old 2 wheel drive powerstroke with stage 2 injectors. I sure miss that truck. 20mpg consistantly for 200k miles.
Eli is offline
post #17 of 21 (permalink) Old 12-06-2015, 01:52 PM
Originally Posted by jimmy View Post
The price has something to do with it. Ford only packages the gaskets with head bolts that most of us would never ever use. I do not want to condone those bolts being manufactured by overpaying Ford for them only to toss them on the metal scrap trailer.
That's a solid point.
'06 F250 4x4 - 5" Flo Pro exhaust, SB Filter intake, Accufab elbow, Edge Evolution (monitoring only), SCT w/ ID custom tune, FASS 195 pump, Gillette Diesel EGR cooler delete, Sinister Diesel coolant filter, ELC coolant, updated turbo drain tube/oil feed line/STC fitting/oil cooler, ARPs w/OEM HGs, Elite coolant lines, ITP RR fuel system, RCD 175/30 injectors, Powermax, BD CCV, FICM.com FICM w/ ID tune, Elite UP, BPD water pump - 13.069 @ 101.94
'02 WRX - Outback rear disc swap, EBC green pads, DBA pillar vane rotors, TXS UP/TBE/TMIC, Perrin LW crank pulley, PPG billet steel shift forks, ACT Streetlite flywheel & clutch, K&N filter, STi Group N motor/trans mounts, TiC/Kartboy rear diff mounts/subframe lock bolts/outrigger stiffeners, Kartboy SS & all shifter bushings, custom PDX tune for Cobb AP - went 14.1 on a terrible 60ft before most of these mods; shooting for 13.50s
TKOPerformance is offline
post #18 of 21 (permalink) Old 12-07-2015, 06:23 AM
diesel dave 99's Avatar
thanks guys for all the input, I went with OEM the money is on the customer the redo would have been on me, I'm sticking to what has been working for me at least for now. I guess my wife is right I'm resistant to change.
08 F-350 Crew Cab Dually 4X4 Lariat 6.4 4:10 gears. [email]
diesel dave 99 is offline
post #19 of 21 (permalink) Old 12-08-2015, 03:23 PM
A sound business decision.
Everyone's resistant to change.
post #20 of 21 (permalink) Old 12-08-2015, 11:07 PM
The OE head gasket and the VR gaskets are the same. Remember ford didn't build the 6.0, international did. International used internals from Mahl. Mahl owns clevit and VR. ford wanted there version blue for marketing purposes. That's the only difference. As long as you use head gaskets for your ford dealer or VR supplier your fine.
BGilton79 is offline
post #21 of 21 (permalink) Old 12-09-2015, 05:58 AM
FYI, Mahle, pronounced with the "e" on the end. Its a good German company after all
