Cat and MPG - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 12-05-2010, 09:47 AM Thread Starter
skirk55's Avatar
Cat and MPG
I removed my cat and I can not be sure about mpg improvement. I removed it and took mt 5th wheel on vacation. I could feel the better response but my mpg were not what I had expected. I put it back on to see if there was a change. Yes when you run a yellow light the truck took to long to respond. The turbo lag is not good. I think I got 2mpg better with it on. That may be me the new found power was nice to feel it.
Will removing the cat improve or reduce MPG?
_________________________
2005 Ford F-350 Crew Cab Long Bed 4x4 Diesel 6.0
Ready Lift Leveling Kit
Pro Comp MRX-6 Shocks
Pro Comp 33x13.50 x 18 Tires
Reese 15K Hitch
Two Golden Retrievers and a Flat Coat
skirk55 is offline
post #2 of 7 (permalink) Old 12-05-2010, 11:49 AM
Anything that reduces exhaust backpressure is more likely to increase mileage on a diesel engine.
Evel486 is offline
post #3 of 7 (permalink) Old 12-05-2010, 05:06 PM
hawkeyediesel's Avatar
Since removing my CAT I have seen no improvement or decrease in MPG. It hasn't changed a bit. But I did notice a difference in the turbo spooling up quicker and it pulls my camper better.
For what it's worth, by monitoring the exhaust back pressure with my Scangauge II, with the CAT installed at WOT the sensor said there was 50psi of exhaust back pressure. With the CAT removed at WOT only dropped to 47psi. This doesn't sound like much, but it does prove that the CAT is restricting the exhaust and removing it does make things flow better.
2006 F-250 Lariat Crew Cab | 6.0L Powerstroke | 4x4 Auto Tranny w/ 3.73 | ~105,000 miles | AstroStart Remote Start | LineX Spray-On Bedliner
Turnover Ball Gooseneck Hitch | Scangauge II w/ homemade mirror mount | Glow Shift Fuel Pressure Gauge | Glowshift EGT Gauge
Dieselsite Coolant Filter | CAT Delete Pipe | SCT Livewire tuned by Innovative Diesel
| River City Diesel EGR Delete | Blue Spring Upgrade
High Idle Mod | ARP Studs
2009 30ft Puma Travel Trailer | Approx 8000lbs when loaded up for the weekend!!
hawkeyediesel is offline
post #4 of 7 (permalink) Old 12-05-2010, 07:34 PM Thread Starter
skirk55's Avatar
OK Everyone proved it to me my cat will go back on this week! I guess the feel was too much for my foot to resist. I was looking at a new exhaust with a down pipe replacement. Will this help my mpg or will it stay the same?
Reese 15K Hitch
skirk55 is offline
post #5 of 7 (permalink) Old 12-05-2010, 11:28 PM
IMO once you added the leveling kit and 33/13.5/18's you shouldn't worry about MPG....That's your problem,going back to stock tires will help....
2004 F-350,Lariat,CC,6.0L,6spd.,FX4,
Power Rear Slider,Power TT Mirrors,Moonroof,4.5" DR hanger kit with DR shocks,Welds w/315's Toyo MT's (sold),35's Nitto Trail Grappler w/18" XD Black Monsters,straight pipe MBRP SS Turbo back exhaust..
asnotme is offline
post #6 of 7 (permalink) Old 12-06-2010, 06:13 PM Thread Starter
skirk55's Avatar
My tires did lower the mpg but when Ford re flashed my truck it lost 4 mpg. When I pull my 5th wheel I get 8 mpg I was hoping to get it up to 10 that would be where I want to be. The tires are the best thing I have ever done! You should see my wife getting in and out of the truck. The truck in the snow is outstanding. In the mud better that anything I have ever driven. The ride is wonderful. The tire noise? Loud but I have bad hearing.
Everything for the Powerstrokes like cold air intakes, programmers and exhaust systems advertise they save mpg. I am willing to spend the extra money to get more mpg and I also am going to install an extra fuel tank in the bed. I need a better driving range now 260 miles per tank is not very good. When my tires ware out I will get tires a little narrow. Or trade the truck in for a new one after we get back from Alaska.
Reese 15K Hitch
skirk55 is offline
post #7 of 7 (permalink) Old 12-06-2010, 07:07 PM
West28's Avatar
I've tried all sorts of thing to get better mileage out of my trucks including removing the CAT and then trying a 5" turbo back. I didn't get any noticable amount more. I put a functional ram air hood with a cold air intake on my 04 and that made more of a difference than anything else I've done. I run 36 15.50 Muds towing a 36' 5'er and a 16' cargo trailer behind that on my 04 and get 12 mpg.
06 F350 KingRanch 5" Turbo back exhaust, 8" lift, 38 15.50 R20's, EGR delete, Edge A2, ARP's, TV's and backup camera, coolant filter system, upgraded fuel regulator.
04 F350 KingRanch Banks 4" Turbo Back exhaust, intercooler, Aurora turbo, edge chip, Functional ram air hood connected to AirAid intake, 4" lift with 36 15.50 R20's, Tv and game console.
West28 is offline
