Changing camshafts - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 11-12-2004, 04:50 PM Thread Starter
Changing camshafts
With all this horsepower talk why has no one changed the camshaft in a 6.0. Does no one make one, you would think you could get a cam made for less than some of the boxes. Just a thought [img]/ubbthreads/images/graemlins/shrug.gif[/img]
6670 is offline
post #2 of 9 (permalink) Old 11-12-2004, 07:56 PM
Re: Changing camshafts
Camshafts are not as important when you are using a turbocharger. With the 6.0's 4 valve head getting air in and exhaust out are not a problem. I suspect changing a camshaft in one of these engines would cost more in labour than a chip and would definatly void warrantys.
1999 F250 2WD RC/LB posi AIS, Superchips DPI propane, 4" turboback exhaust, gauges, Edge Evolution tuner [looking into a Propane chip]
SMOKESKULL is offline
post #3 of 9 (permalink) Old 11-12-2004, 10:01 PM
A cam swap would only be viable if you pulled the engine and were searching for every little bit of hp. There are many other areas that have yet to be used that are easier than a cam. The cam comes out the rear of the engine.
Tadd
TaddL is offline
post #4 of 9 (permalink) Old 11-13-2004, 02:32 PM
CarterKraft's Avatar
My Photos: (30)
Tadd
I think the cam will definantly be last on my list.
2018 F-350 Lariat Ultimate 4x4 DRW 6.7
CarterKraft is offline
post #5 of 9 (permalink) Old 11-13-2004, 04:52 PM Thread Starter
Did'nt realize that the cam needed to come out the back of motor talk about major pain. [img]/ubbthreads/images/graemlins/shocked.gif[/img]
6670 is offline
post #6 of 9 (permalink) Old 11-14-2004, 11:43 PM
just cut the firewall [img]/ubbthreads/images/graemlins/smile.gif[/img]
97f250RED is offline
post #7 of 9 (permalink) Old 11-15-2004, 06:47 AM
mudguppy's Avatar
My Photos: (12)
so do i need to make my hole behind the radio or cigarette lighter??? [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Travis
'03 F350 Dually, 6.0, Supercab, longbed, 4.10 LS, sport pkg, extremely RED, STRAIGHT PIPED, SCT Xcalibrator, full guages
- Job1 programming, Harpooned, Skweeker Mod, Zoodad Mod
- Did that thing that you're not supposed to talk about
'79 Bronco, 468cid Ford 460 marine motor, C6/NP205
Previous -'99 F250, Rg Cab XLT, 7.3/6spd, 3.73
Project truck
- '96 Cummins, 215hp/5spd, Diprocol guages, Plate & AFC full fwd, hi-capacity external lubrication system
To add: 2 1/2T axles, 46" goodyears, etc.
mudguppy is offline
post #8 of 9 (permalink) Old 11-15-2004, 07:57 AM
Iwould say just under the radio and to the left a little. [img]/ubbthreads/images/graemlins/grin.gif[/img]
2004 F-350 Green, Lariat, Crewcab 4X4, Torq-Shift, 4" Procomp lift, Weld 16X8 Scorpio wheels, Hog 4" stainless exhaust, Airaid Intake system, Proparts 2 gauge pod, Isspro EGT and Boost gauges, Proparts 2 gauge underdash pod, Autometer trans temp and water temp gauges, Cyclops no start, Prodigy brake controller, XM Sattelite Radio, Frozen Rotors and pads, Viair compressor, 5gal air tank, train horn, Fumoto Drain Valve, Clifford Matrix RSX-6 alarm with remote start, Xenon fender flares, CCV Mod, Innovative Diesels SCT with extreme tune, Banks Technicooler, Mag-Hytek tranny pan and diff. cover and more mods to come.
Sent Back(Old School) Quadzilla 160 Module (Shifting Problems)
Sold Banks 6 Gun (Not near enough power)
GreenCrush is offline
post #9 of 9 (permalink) Old 11-15-2004, 02:36 PM
hahah im not resposible for your damages if yall choose to go this way [img]/ubbthreads/images/graemlins/smile.gif[/img]
