Coolant filter change interval? - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 01-16-2012, 06:09 PM Thread Starter
dvldog458's Avatar
My Photos: (54)
Send a message via AIM to dvldog458
How often do u guys change your coolant filter?
I just bought a bunch of replacement filters and wanted to get routine schedule going.
2004 Excursion Limited 4x4 6.0L
BDS 8" lift, 2.5" shackle kit w/ 40" Nitto Mud Grapplers, 20x10 Jesse James wheels, SCT tuner (Elite Diesel) A-1 H-11 Head studs, Dieselsite coolant filter
dvldog458 is offline
post #2 of 13 (permalink) Old 01-16-2012, 07:53 PM
I change mine with my oil changes every 5000 miles
burke117 is offline
post #3 of 13 (permalink) Old 01-16-2012, 07:59 PM
jeffws's Avatar
X 2
05 F 250 CC PSD FX4
BPD EGR Cooler
DC Power 185 amp
Dieselsite Coolant Filter
Edge Insight CTS w/ Fuel Pressure, EGT and Turbo Timer
Blue Spring Upgrade
HFCM Water Separator Drain Plug Upgrade
High Idle Mod
Mag-Hytec 6 Quart Diff Cover
Bilstein Shocks & Dual Stabilizer
285 75 17 Toyo's
Airlift Air Bags
jeffws is offline
post #4 of 13 (permalink) Old 01-16-2012, 08:03 PM
FMTRVT's Avatar
My Photos: (16)
When the filter stops getting hot.
Jack
YouTube Videos Google - TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline
post #5 of 13 (permalink) Old 01-16-2012, 08:14 PM
This one for me too.
2006 Ford F-250 SuperCrew FX4 PSD Lariat
OxFORD is offline
post #6 of 13 (permalink) Old 01-16-2012, 09:44 PM
rfishoutofwater's Avatar
i change mine out every 6 months.
rfishoutofwater is offline
post #7 of 13 (permalink) Old 01-17-2012, 10:11 PM
Once installed I changed mine at 1k, 5K, and 25K miles. I haven't seen any debris or clogging at that interval and will continue to change mine every 25K or once per year.
Diller is offline
post #8 of 13 (permalink) Old 01-18-2012, 05:12 PM
Same.
-Rich
2005 F-350 PSD
Mdnitedrftr is offline
post #9 of 13 (permalink) Old 03-05-2012, 10:28 PM
When it gets lukewarm (vs. hot) is a good answer, but a clean cooling system will not plug up a filter and cool off. Keep in mind that the filter media is not good forever and so I replace about once a year. If using additives, I'd not replace more than once a year. You don't want to overdose with Supplemental Chemical Additives (SCA).
51stovebolt is offline
post #10 of 13 (permalink) Old 03-08-2012, 07:59 PM
I change my filter every oil change. The filter is cheap and it makes me stay on top of it.
2005 F-350 CC SWB SRW PSD FX4 (decal removed)
Dark Shadow Grey/Medium Flint Leather/captains
SIRIUS
Lariat Luxury with Nifty Xtreme floor mats
Stock 18" rims sporting 35/12.5 Toyo M/Ts
2.5 inch level
Guidepoint
5" MBRP w/kitty
ISSPRO 3 guage set on pillar
SCT from Innovative Diesel
(I run extreme street every day)
1960 Cadillac Series 62 convertible, white paint and top, turqouis leather, 4 1/8 inch white walls, STOCK!
1969 Buick GS convertible, 455 transplant, .40 over, Comp Cams, Edelbrock, TA Performance, TH400,White paint with black interior and black top, original rally wheels.
ZAZBEAM is offline
post #11 of 13 (permalink) Old 03-09-2012, 12:08 PM
There is no technical benefit to change a coolant filter this often. Fleetguard recommends 500 hours or 25,000 miles (and that is for over the road trucks, which have more severe service). Being a sealed system, particulate matter cannot accumulate quick enough to plug even the smallest filters and additives are typically not depleated either. In fact, there is a good reason not to change coolant filters this often: when using filters with SCA, there is a good chance you will overdose your coolant and cause precipitates to form. Changing filters in automotove service even every year is probably overkill, but done as a good measure to make sure the filter media doesn't break down.
post #12 of 13 (permalink) Old 03-09-2012, 02:10 PM
You use non charged filters in these trucks. Do not add SCA.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
post #13 of 13 (permalink) Old 03-09-2012, 04:21 PM
yeah you don't want filters that add chemicals, and you don't want to be using the Ford coolant either.
Idahoser is offline
