Edge CTS - Pyrometer or No Pyrometer? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 11-27-2010, 05:07 AM Thread Starter
Planning to pick up a CTS this weekend given the incentives and discounts available. I am wondering if I really need a pyrometer on my 2007 F350 PSD or is the info on EGT from the PID good enough?
Thanks!
Paul
2007 F350 DRW 4X4 Crew Cab Long Bed Lariat
Dieselite Coolant Bypass filter
Amsoil Bypass filter
Performance Edge - CTS Insight
Tow 2002 Boston Whaler Outrage 28
15,000 Pacific Triple Axle Trailer
Reese Trunnion Bar with Sway Control #66157
bwhaler is offline
post #2 of 7 (permalink) Old 11-27-2010, 10:33 AM
ZMANN's Avatar
it is needed if you want the edge to display EGT ,, it is not a OEM PID
I however chose not to get it and use a standalone AUBURN display with stagged alerts
the proprietery thermocoupler and price was a turn off on the edge that and I use all of the info i get on the CST I wouldn't want to loose one in favor of the EGT
O6 King Ranch cc sb 4 inch lift ,35 Pro Comp,Helo’s Edge Insight CTS guage only , Auber EGT , o8 center console ,2x10 subs, xm satellite ,coolant filter,RSX 9000 shocks,dual bilstein steering stabilizers ,Viper , remote toolbox popper, High Idle mod , up fitters added ,weather guard mats , ARP's, BPD EGR cooler, Marinco Mod ,Zoodad waste Fabtech traction bars, Some other stuff
ZMANN is offline
post #3 of 7 (permalink) Old 11-27-2010, 10:53 AM
Feedback Score: 2 reviews
Thanks!
Paul
Paul
I see you pull a Triple Axle Trailer and a heavy one a pyro is a must if you do not want to melt something, the max temp is 1250* and before you turn it off cool down to 350* to 370* so are they a must YES I pull a 14k 5er and look at mine all the time.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
post #4 of 7 (permalink) Old 11-27-2010, 11:00 AM Thread Starter
Originally Posted by 2 Stroker View Post
Paul
2 stroker
Thanks Guys! I realize now that I was looking at a 6.4L thread suggesting to bag the pyometer for the pid.....ooops.
Stroker - I have not gone on any hauls yet as I have had to mechanical issues on the truck that has prevented me to do so. I have benefited from your suggestions - coolant and oil bypass and other. Thanks for being so active and willing to repeat the same thing so many times for us newbies =) .
Paul
bwhaler is offline
post #5 of 7 (permalink) Old 12-03-2010, 10:27 PM
Paul
How is the truck coming on the road yet
2 stroker
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
1700 Super Chip
3" dp-4" exhaust
Tymar Intake
post #6 of 7 (permalink) Old 12-04-2010, 05:59 AM
HeavyAssault's Avatar
My Photos: (6)
Make sure you get the EGT starter kit for the CTS. The harness allows for adding additional sensors. EGDE has said they will be releasing a fuel pressure sensor soon.
2015 F-350 CCLB PSD 4X4 3.55 ELD
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
post #7 of 7 (permalink) Old 12-04-2010, 07:41 AM Thread Starter
Thanks for the reply. I did order it even though we have yet to see an accessory yet. I have heard that the fuel pressure sensor is coming soon so I am holding off for 60 day....the I am off to the traditional. Thanks!
bwhaler is offline
