Lost power when I added Attitude ??? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 03-07-2004, 07:12 PM Thread Starter
trs900's Avatar
Sent my edge back for update, got it back truck would not start...called Edge they sent me a new one with a return label for bad one with out any ??? they sure do have good customer service ... Well I decided to add Attitude so when I got it I noticed it was Manufactured 2-14-2004 and it says on screen it is version 1.6.. I drilled my exhaust and mounted attitude... now the part I dont understand is when I set Attitude on 5/5 I dont have near the power or throttle response that I had with just Edge Juice.. it reads temperature ok.. etc...
To verify this I disconnected Attitude and with edge juice only all my power was back.. Is Attitude defective or did I not do the proper procedure when I started up attitude... I will call Edge tomorrow.. has any one else had this happen..
2003 350 Lariat CC DRW 4x4 6.0 5 speed auto 2002 build date magnaflow #15956 turbo back
trs900 is offline
post #2 of 7 (permalink) Old 03-07-2004, 10:35 PM
Strictly Diesel's Avatar
Feedback Score: 3 reviews
Re: Lost power when I added Attitude ???
Did you connect the MAP sensor wire too? The Juice/Attitude combo will run like "doo doo" if the MAP wire is not connected as the Attitude won't fuel the motor without seeing boost.
Double check the MAP wire connection and if it still doesn't work right, check for continuity on the wires in the Edge MAP harness. I have had to swap that harness for a customer and it fixed all of his "low power" problems.
Dennis Schroeder - Co-Owner of Strictly Diesel
Race Truck :: 6050# / 11.31 @ 120mph / Best 60' of 1.56 ... with "Built" Race Engine (Fuel Only!)
Race Truck :: 5980# / 10.965 @ 124mph / Best 60' of 1.54 ... with "Built" Race Engine (Nitrous)
Strictly Diesel is offline
post #3 of 7 (permalink) Old 03-07-2004, 11:05 PM Thread Starter
trs900's Avatar
No... that explanes it... I did not connect map sensor as wire did not come with Attitude they are sending it now...
Thanks I will wait till I get map sensor hooked up, then we will see..
trs900 is offline
post #4 of 7 (permalink) Old 03-08-2004, 07:07 AM
You will know when you get it hooked up right. There will be no questions in your mind about it.
2011 Ford F250 Lariat, CC 6.7, 20's, ARE Topper, bedrug, EDGE CTS.
<a href="
target="_blank"><img src="http://mefi.us/images/fuelly/smallsig-us/89813.png" width="115" height="40" alt="Fuelly" title="Share and compare MPG at Fuelly" border="0" style="border:solid #ccc 1px;padding:4px;background:#fff;"/></a>
Dick is offline
post #5 of 7 (permalink) Old 03-17-2004, 09:29 PM
teamroper60's Avatar
I'm waiting on my Juice to arrive (any day now). I downloaded the instructions and have read through them. I'm wondering, will I need to plug in the MAP sensor cable if I'm not running the attitude??
Thanks.
#43
President and Webmaster
teamroper60 is offline
post #6 of 7 (permalink) Old 03-17-2004, 10:17 PM Thread Starter
trs900's Avatar
No, if just using juice you are ok.. attitude plugged into juice then you have to hook it up..
trs900 is offline
post #7 of 7 (permalink) Old 03-17-2004, 10:37 PM
Thanks for the info!! That's what makes this site great. No matter what the question, someone will probably know the answer! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
#43
