Part number help - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 02-29-2012, 09:18 AM Thread Starter
Part number help
Hello I am about to tear down the top end of a 2004 6.0 and do EGR Delete, oil cooler replacement, coolant system flush, coolant filtration and a few other things. My truck has 127,000 miles on it and I am sure my turbo needs some attention. I have heard a couple different things on here for instance a turbo cleaning kit, and a turbo rehab kit. Are these two in the same? If not whats the difference and what are the part numbers for these ? Thanks.
2004 F-250 Lariat 6.0 Powerstroke Diesel
4*4 FX4 package
Clarion Stereo system with Punch 12" subs and Boston Mids and Tweets
fire1peanut is offline
post #2 of 2 (permalink) Old 02-29-2012, 06:18 PM
Feedback Score: 2 reviews
Before you do the repairs need to do the flush first or you may be back at it again doing the repairs over that would suck big time.
Here are some parts don't know if you need them all
3C3Z-9T514-AD Turbo Hardware -- Turbo Mounting Hardware Kit
3C3Z-9T514-B Turbo Hardware -- V Clamp
4C4Z-9V424-AA Turbo cleaning kit
This may help also
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
