Road Trip - Increasing MPG - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 02-15-2012, 10:26 AM Thread Starter
I have an 05 Crew Cab 6.0 4x4... I have been getting roughly 13.5 MPG, roughly 75% Highway 25% City... That is on Winter Diesel... I gained nothing by doing a muffler delete, which alot forums said I would see a slight increase... I am planning on a trip to Florida in two weeks... So... I know driving patterns are the biggest boost but....
What RPM range is going to get the best MPG on the Highway? 1800-2000?
What MOD's are gonna really effect MPG on the Highway that would pay them selves off?
I live in Michigan, How far down do I gotta go before they stop using winter grade diesel?
2005 F-250 6.0L Crew Cab - 86K - Diesel Site Coolant Filter - Muffler Delete -
1997 Trans-Am WS-6 - 74K
Sippinsyrup36 is offline
post #2 of 5 (permalink) Old 02-15-2012, 11:52 AM
anything under 2000rpm. make sure the tires are inflated all the way. maybe a tuner with some custom tunes. I can tell you as far south as st louis it is still winter diesel here.
2003 F350 crew cab 4x4 , 295's on 17's, performance MFG coolant filer, Blue spring, new HFCM, FICM, Batteries and Alt. SCT performance tune, 128k on engine 12/13. Stock everything else.
ryhed is offline
post #3 of 5 (permalink) Old 02-15-2012, 06:27 PM Thread Starter
Thank you
post #4 of 5 (permalink) Old 02-20-2012, 05:35 AM
nitrogen's Avatar
just got back from a short trip over the Rockies. I am running archoil oil additive as well as their AR6200 fuel additive. I don't know if they helped or not, but running 65-74 it gave me 15.2/US gal. it did run well and seemed strong. up here in "The Great White North" we are all on winter fuel.
nitrogen is offline
post #5 of 5 (permalink) Old 02-25-2012, 08:37 AM
I've got the same truck with no performance mods, and get 15-16 mpg (in Phoenix, so no winter diesel here). 13.5 seems low...
2005 F-250 XLT 6.0L Crew Cab 4x4
BulletProof Oil Cooler/EGR Cooler/FICM; updated STC fitting; updated turbo oil drain tube; fuel pressure regulator spring upgrade (blue spring); Line-X bedliner; Jimmy Jammers; ScanGaugeII; Moog ball joints; 185 amp DC Power alternator; new fuel injectors and fuel pump (146k); updated oil rail stand pipes; ~170,000 miles
sgivens is offline
