Scan Guage II - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 11-08-2010, 04:38 PM Thread Starter
OT
OT's Avatar
Question Scan Guage II
Searching I didn't find any current info. here. I read about it awhile back, so....
If anyone is currently using one, what are your opinions on how it works, does what it's designed to do? Any issue's like reliability or slow to display readout's, etc.?
What other feature's/info. displayed have been useful for you? Also, where/how did u mount it? TIA
03 F250 XLT SC/SB 4X4 6L (stock) TqS. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
post #2 of 13 (permalink) Old 11-08-2010, 04:42 PM
I'm running one and it's a great little tool. Great bang for the buck. I display engine oil temp, coolant temp, ICP, and mileage just for kicks.
The flexibility of the xgauge feature gives you access to a lot of the 6.0-specific data points.
Mine's stuck to my dashboard above the vent on the passenger side of the steering wheel.
mjp2 is offline
post #3 of 13 (permalink) Old 11-09-2010, 08:50 AM
I love it. EOT, ECT, Trans temp and boost all in one gauge with lots of other options. I mounted mine between the steering wheel and the middle vent on the dash so I can get a quick look while driving.
Oogs
2004 6.0 E350 Quigley 4x4 w/ Sportsmobile Conversion.
285/75R16 BFG AT/KO. 3.73 Gears.
Dieselsite Coolant Filter.
Aluminess Front/Rear Bumpers.
125W Solar Panel.
Sportsmobile Trailer on 285/75R16 BFG AT/KO tires w/ dual deep cycle marine batteries, water pump, 10 gal water storage, air compressor, storage box & 15W Solar Panel.
SnowMan Mod / Door Seal Mod
"Blue Spring" Upgrade
ridintall is offline
post #4 of 13 (permalink) Old 11-14-2010, 08:10 PM
caissiel's Avatar
I have been using a scangaugeII for the last 3 years. I will never tow without it.
The gauge has all the displays required for engine protection. The temperatures and displays are all digital, so I use it more often then the truck gauges, Just added an EGT gauge because the 6.0 don't display it.
I found some diesel stations that are better then others so I can save up to 15% just around home.
The fuel flow can be calibrated so that I get the real flow with different setting of my Programmer.
2005 Ford SD F250, 6.0L Diesel, Extended Cab, 4 x 4, 6 Speed, 2 Alternators, 2008 Mirrors, 10,000GVW, Max Energy by Hypertech, ScangaugeII for available 60 XGauges and MPG. 20MPG and 12.6 MPG Towing a 15500Lbs 38ft RV 5th Wheel.
caissiel is offline
post #5 of 13 (permalink) Old 11-24-2010, 10:12 PM
hawkeyediesel's Avatar
I love my Scan Gauge also. A few months ago I loaned it to a friend so that he could watch his EOT vs ECT after his Bullet Proof oil cooler upgrade. He loved using it and it drove me crazy not having it for a few weeks.
One of the biggest benefits of the Scan Gauge compared to others is the compact size. I mounted mine underneath the rear view mirror. Made my own mount and bought a CAT 5 female to female connector. I coiled up the cord that came with the Scan Gauge under the dash and ran a seperate CAT 5 cable up the pillar and across the head liner. This makes it very easy to remove it in case I need to use it in one of my other vehicles.
2006 F-250 Lariat Crew Cab | 6.0L Powerstroke | 4x4 Auto Tranny w/ 3.73 | ~105,000 miles | AstroStart Remote Start | LineX Spray-On Bedliner
Turnover Ball Gooseneck Hitch | Scangauge II w/ homemade mirror mount | Glow Shift Fuel Pressure Gauge | Glowshift EGT Gauge
Dieselsite Coolant Filter | CAT Delete Pipe | SCT Livewire tuned by Innovative Diesel
| River City Diesel EGR Delete | Blue Spring Upgrade
High Idle Mod | ARP Studs
2009 30ft Puma Travel Trailer | Approx 8000lbs when loaded up for the weekend!!
hawkeyediesel is offline
post #6 of 13 (permalink) Old 11-25-2010, 01:02 PM
robtechno's Avatar
I read that some users are reading the engine oil temp. Can some one please post the Scan Gauge II code for the 6.0 diesel.
Thanks.
robtechno is offline
post #7 of 13 (permalink) Old 11-26-2010, 09:59 AM
ebusa's Avatar
Thanks.
Engine Oil Temp.
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
MTH: 00090005FFD8
-Evan
2005 F350 Crew Cab LB FX4 Lariat
5'' Tuff Country Lift
35'' Toyo MT on Race Line Renegade 20's
AFE Magnum Force Stage II CAI
MBRP 4'' Exhaust Turbo back,
ARP Studs
Coolant Filter
SCT X3 tuned by Everyone..
PowerMax Turbo
PHP FICM Tuner
Metal CAC tubes
ebusa is offline
post #8 of 13 (permalink) Old 11-26-2010, 10:53 AM
Band_Member's Avatar
My Photos: (64)
Anyone know if you program your tire size into your trucks computer with this thing ? I went from 265's to 315's. Thx
on edit: can you read yer fuel pressure with it too ?
2005 F250 XLT SC, LB
6.0 Torqueshift 3.73LS 4x4 T/C
Trk Bld: 02/05/05 KY
Eng Bld: 02/03/05 Indianapolis
2825 Hrs +/-, 101K Miles - No Major Probs other than brakes
DC Power 185 Alternator
ZOODAD, SEIC,
Atlas 40 FICM @ 90K
4" Banks Turbo-Back Duals
3.5" Ready Lift
Bilstein 5100's
315 - 70R17 Duratrac's
Centramatics
Bodiak Front Receiver
SG2
Coolant Filter
HFCM Plug Upgrade
FP Gauge
Zerex Red ELC
Band_Member is offline
post #9 of 13 (permalink) Old 11-26-2010, 05:49 PM
Band Member,
To my knowledge you can not reprogram for different tire sizes with the Scan Gauge. All that it is capable of doing is reading info from the OBDII port. It can read just about any sensor and read/clear codes. You can not hook up external sensors for something like fuel pressure. In fact, there isn't anything out there that can read fuel pressure. I purchased a normal gauge for fuel pressure & EGT.
post #10 of 13 (permalink) Old 11-27-2010, 03:31 AM
My Photos: (64)
Thx Hawkeye
ZOODAD, SEIC,
Atlas 40 FICM @ 90K
3.5" Ready Lift
Bilstein 5100's
Centramatics
SG2
Coolant Filter
HFCM Plug Upgrade
FP Gauge
Zerex Red ELC
post #11 of 13 (permalink) Old 11-27-2010, 10:00 AM
robtechno's Avatar
Oil Temp on Scan Gauge II
Originally Posted by ebusa View Post
Engine Oil Temp.
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
MTH: 00090005FFD8
Thank you for the input, but the TXD has one space left for the last digit. With you setting it will not work. Will you please be so kind to check again.
My Ford is a 2006 6.0 psd.
Maybe that is different from your year. I will also ask Scangauge them self.
Thank you.
Regards
Rob
post #12 of 13 (permalink) Old 11-27-2010, 02:31 PM
This is what worked in my truck. It is different than what was already posted, but it's worth a shot:
TXD: 07E0221310
RXF: 046205130610
RXD: 3010
MTH: 000901F4FFD8
NAM: EOT
For some reason there seems to be some trucks out there that are different than others, hence the different codes you input into the Scangauge. Of course, mine was different than most. Try this code to see if it works. A good way to verify is when the truck is cold. EOT & ECT should be within a degree or two.
post #13 of 13 (permalink) Old 12-02-2010, 05:27 PM
robtechno's Avatar
Scan Gauge II for 06 F350 6.0
Thank you both for the diffrent codes but they do not work on my truck.
I asked the Scan Gauge company as well but they did not answer me yet.
They asked for one code on my gauge but not heard since.
I will probably install a digital oil temp gauge but need to find a place to hook it up with out drilling some where, at least that is what I prefer.
Any ideas for the 6.0 engine in an 6.0
Thanks.
