To Stud or Not To Stud? - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By Radioflyer
post #1 of 12 (permalink) Old 10-30-2015, 08:33 AM Thread Starter
I just picked up a 2006 Ford F-350 with only 39,000 miles. Everything is perfect mechanical condition with all maintenance performed. I can never leave my vehicles alone, so it is time to start modding. I will definitely be buying a tuner for this truck and running a performance type tune, but not taking it to the edge with an extreme tune.
I am absolutely prepared to stud the vehicle now, but also wondering if I am better served by just waiting. It seems some people are able to get away with a 100-150 hp tune without studs for relatively long periods of time.
So if I decide not to stud and roll the dice, what is the worst that will happen to the engine if the head bolts start to fail? Essentially I want to know if it will cost me more money to stud after head gasket failure?
MAINE DIESEL is offline
post #2 of 12 (permalink) Old 10-30-2015, 04:36 PM
It is always cheaper to Stud before than after. You can ruin the whole motor putting too much heat on it without the proper modifications first and it can potentially end up costing you a full engine rebuild or a motor swap. Not cheap even if you can do it yourself.
CycleVIN is offline
post #3 of 12 (permalink) Old 10-30-2015, 05:49 PM
Agreed. Buy O-ringed heads factory gaskets and ARP Studs and be done forever. Head gaskets still fail with studs. You need Orings to add strength. If you don't you run the risk of hydro locking and bending or braking rod, pistons ect. Do it right the first time. Buy heads from UCF MACHINE SHOP. Look them up
BGilton79 is offline
post #4 of 12 (permalink) Old 11-04-2015, 09:03 AM
Just do vr black dimond head gaskets same thing as oem, save the money
323flint is offline
post #5 of 12 (permalink) Old 11-04-2015, 11:41 AM
Justus's Avatar
I have heard via other forums that Black Diamond gaskets are not good???
2006 Ford F-350 6.0LPowerstroke
Tan, Lariat, CCLB, 4X4, CB, LineX, Bed box, 5thWheel, tow pack
MODS
BPD FICM PS, SCT X4 w/EGT probe, PHP FICM tuner, straight piped, Blue spring, coolant filtration, CAT-1/ELC,- EGR valve,
leveling kit, 35" Toyo Open Country MTs, STC upgrade, Mean Green alternator, dual Optima's, Stant Degas cap, Archoil 9100/6200
FUTUREPLANS
New oil cooler/EGR cooler delete, STUDS, diff covers, ARBs, bumpers
Justus is offline
post #6 of 12 (permalink) Old 11-05-2015, 08:12 PM
I had a set of black diamond gaskets fail last year on a customers truck. I figured it was a head but they check out good. needless to say it got OE gaskets and o-ringed heads.
post #7 of 12 (permalink) Old 11-05-2015, 09:52 PM
Read this thread they are the same, I've had both in my hand at the same time.
6.0L Head Gasket Comparison - Ford Powerstroke Diesel Forum
323flint is offline
post #8 of 12 (permalink) Old 11-05-2015, 09:58 PM
How long did the bd gaskets last
323flint is offline
post #9 of 12 (permalink) Old 11-05-2015, 11:14 PM
chuckster57's Avatar
IIRC the gaskets that had a high failure rate were/are black onyx.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #10 of 12 (permalink) Old 11-06-2015, 09:06 AM
Correct.
Black Onyx and Black Diamond are entirely different gaskets.
Black Diamond are made by Mahle/Victor Reinz and they come from the same factory as Motorcraft. Unless you are running high boost and larger turbo's (like a 65 or bigger), no real need for O-ringing the heads. If it's stock turbo, I suggest spending a little extra money on the studs, and call it good. Personally, I'm partial to A1 H11 studs. Run about 730 bucks for a set, but have a 240,000psi tensile rating versus the 220,000 the standard ARP's do..
323flint likes this.
08 CCSB 6.4 617 RWHP Fuel Only Un-corrected ***SOLD**
Radioflyer is offline
post #11 of 12 (permalink) Old 11-06-2015, 10:25 AM
Originally Posted by Cody @ ATP Trucks View Post
Correct.
People alway mistake black onyx and black diamond
323flint is offline
post #12 of 12 (permalink) Old 11-06-2015, 11:35 AM
I took my heads to Houston engine in Houston, Texas and they were only $400 more for the O-Rings, so I did the O-Rings. I dont regret it even though my 6.0 is basically stock. My heads are good. Runs perfect!
2003 Ford Excursion 6.0 139,000 Miles...F-650 Dash
4-2-2015 Bulletproofing completed:
Completely Rebuilt and O-Ringed Heads.... ARP Studs....OEM Oil Cooler....RCD EGR Delete....OEM Head Gaskets....Glow Plugs....Glow Plug Harnesses....Injector O Rings....Thermostat & Housing...Valve cover, Exhaust, Intake Gaskets....Riffraff Blue Boots....Turbo drain Tube.... Sinister Oil Filter, Sinister Coolant Filter, Fumoto Valve Oil & Block....Fuel Pressure Gauge.... Coolant Temp Gauge....Oil Temp Gauge....Blue Spring....FICM.Com W/Atlas 40....Aluminum Radiator
Marinco Plug Mod
08-10 Side View Mirrors
Firestone Rear Air Bags
Harpooned/ Zoodad Mod
Redhead Steering
Leveled
"If you're lucky enough to live in Texas, you're lucky enough"
blackrod is offline
