Tow tune vs lower gear ratio - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 02-28-2018, 07:14 PM Thread Starter
I'll admit that I'm not a regular reader of this or any forum but I tend to lurk around when I have a question about my superduty. If this question has been asked a thousand times already, I apologize. But humor me if you will. I drive an 07 6.0 250 with 3:73 gears. I've been pulling a 6000lb TT for the last few years and the truck has no issues doing so. I just purchased a 5er that weighs in at 12K. I live in Florida so the roads are pretty flat and I don't think I'll be heading to the mountains. Here's my question. I want to be able to pull onto the highway and maintain highway speeds (65ish). The driveline guy says to go to 4:10 or 4:30 gears. The tuning guy says to skip new gears and do a 5" exhaust and a tow tune. Of course, they both want to sell their own services.
I figured it best to get answers from people who are living it, not just selling it. What do you think?
SlowRide1602 is offline
post #2 of 8 (permalink) Old 02-28-2018, 07:22 PM Thread Starter
Forgot to mention that the truck is bone stock with the exception or her delete.
post #3 of 8 (permalink) Old 02-28-2018, 07:24 PM Thread Starter
Damned autocorrect ....egr delete!
post #4 of 8 (permalink) Old 03-01-2018, 01:21 AM
Go stand next to a fire and you will get the same effect!! Smoke up your a$$!! I have run 3 7.3 Fords all will pull a 12k 5th wheel stock with no problems! I have done chips, exhaust, turbo, and a lot of other mods because I like to play. My new to me is a stock early 99 DRW with 4.10 rear auto. It will pull my 31 ft 5th wheel just fine over Alaska hills and we have a few big hills. A 6.0 has a lot more HP to make up for the gears!!! Save the money for bullet proof upgrades. Give it a year the way it is if you are not happy upgrade.
DENNY
1999 F350 AUTO 4x4 CC LB DRW 4.10
DENNY is offline
post #5 of 8 (permalink) Old 03-01-2018, 06:18 PM Thread Starter
Well, just pulled the new camper home from the dealer. 12000lbs is heavy. But, the truck pulled it better than I expected. Never got much over 60 due to traffic, but I'm not as worried about it now. Still might do gears though, just cause I want to. Thanks Denny.
post #6 of 8 (permalink) Old 03-02-2018, 08:41 PM
Just some food for thought....picture yourself pulling on a rope tied around a spool. The spool has some drag, but you have no issues pulling the rope. Add some more drag to the spool and your arms start to feel the burn of the added load and the rope has more tension on it. You work out a bit and this eases your burden some and the rope is surviving with the added tension. Add some more drag to the spool and once again your arms are burning and the rope is beginning to reach its max sustainable load. You work out some more making it easier once again for you to pull the rope. However, with your newfound strength, you manage to pull harder than what the rope can sustain. At some point the rope prematurely fails and you are no longer pulling on the spool without repairing the rope. The working out and stressing of the rope both could have been avoided by simply changing the diameter of the spool in anticipation of the added drag.
Been pulling for years and I can say that nothing compares to pulling with the right gears. Have pulled with absurd 3.42 gears right up thru the tall 4.56's. In nearly every instance, 4.10's have felt the best. Only with tires larger than 35's has it seemed that I could have used more gear.
boggerdak is offline
post #7 of 8 (permalink) Old 03-03-2018, 10:54 AM Thread Starter
Now that's a pretty good analogy. Gears it is. Thank you Sir.
post #8 of 8 (permalink) Old 03-05-2018, 10:49 PM
I have a '03 F350 4X4 dually 6.0 that I pull a 15K 5'r with and it does fine with 3.73 until I get in the mountains. This spring I am going to change to 4.30's to help that. I have a friend that has an almost identical truck and 5'r with the 4.30's and he gets over 1 MPG better than I do on the same trips and I can't come close to staying with him in the mountains, empty not towing around town he get the same MPG as I do. I can do the work myself so it is just the parts cost but it still ain't cheap.
jetjockey99 is offline
