Transmission Temp ? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 11-08-2004, 10:54 PM Thread Starter
Transmission Temp ?
I would like to know from those of you with a added on temp gauge what temps are the auto trannys running with a heavy tow load 13000 lbs, uphill, full throttle. I am trying to decide wether to put a alum. mag-hytec trans pan on. I have the stock gauge and it does not seem to move very much from normal.
03 CC F-250 SWB Sport RED 4X4. Loaded, 4.5 Edge lift,AFE Proguard 7,Magnaflow cat back,Predator Programer,Isspro gauges,Centerlines&305/70/17 Goodyear MTS
jimr is offline
post #2 of 7 (permalink) Old 11-11-2004, 10:56 AM
Re: Transmission Temp ?
I have yet to see a 5r110w overheat the fluid. The overheating that occurs in the trans is isolated to a specific clutch pack (usaully direct). Even as the frictions overheat and destroy themselves you would never see this on a guage. These trans have great cooling capacity, cooler size, cooler line size, ect. Nothing like the 4r100 had.
2003 4X4 F250, custom TS165 stacked with Diablo Predetor, MBRP 4" turbo back, SWAMPS injectors, 2 stage NOS, Suncoast upgraded trans with stock converter, AIRAID intake. fuel system going in now, along with more upgraded trans.
cholland is offline
post #3 of 7 (permalink) Old 11-11-2004, 05:15 PM
I towed an 8k trailer with 2 bikes in the bed and 4 people in 100deg heat and the temp never got over 180 with some pretty good climbs (45-50mph). My temp guage is mounted in the pan so its direct oil temp.
Rich
05 F350 Lariat loaded
richgann is offline
post #4 of 7 (permalink) Old 11-11-2004, 07:10 PM
Rich
I was told to take it out of my Pan and go inline with the Trans cooler.The Oil in the Pan Bottom will never Get Hot! [img]/ubbthreads/images/graemlins/shrug.gif[/img]
SuperKaz is offline
post #5 of 7 (permalink) Old 11-12-2004, 05:25 PM
towing a 15K# 5er up a 5% grade at about 65 mph.... I got 171* as my very highest for the trip. This is using a X-monitor gauge set that is tapped into the stock temp sensor.
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ Black Interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Icon Lift Kit, Icon 2.5" Piggy-Back Shocks, KMC Beadlocks w/ 33" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Line-X, MotoBar, Gentex Temp/Direction Mirror, Baja Designs 22" Onx Pro Light Bar
RRose is offline
post #6 of 7 (permalink) Old 11-13-2004, 08:31 PM
wingnut60's Avatar
Mine is in the pan, and I have never seen over 200d even in Colorado mtns in 90 degree heat--and I pull a 9K load and do it as fast as is safe.
2017 F450 KR
2010 F450 Lariat 4x4--died, but reborn, traded
2009 F450 Lariat 4x4--died, scrapped
2007 F350 KR DRW CC 4x4-Gone to pasture
2015 Mobile Suites 38RSSA--hoping for another 10 years
2005 Mobile Suites 36TK3--traded, 10 years of camping memories
wingnut60 is offline
post #7 of 7 (permalink) Old 11-14-2004, 07:25 AM
my 04 weight 10500lbs and I used a infra red temp gun and it was always around 180 degrees, but since my refalsh and my torque converter not locking up like it used to the temp is now in the high 190's and its now winter time. All my 180 temps were in the hot of the summer
skippydoo is offline
