Upgraded Water pump - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By shoguy89
post #1 of 8 (permalink) Old 11-13-2015, 11:39 AM Thread Starter
Upgraded Water pump
I have an 03 Excursion 6.0 and I am planning to change and upgrade the water pump. I read somewhere here in a post that I could in put a later model pump, such as an 04 or 05, which has a larger impeller as long as I also change the the front cover. Is this true and can someone explain a little further. Is it more complicated and what do I have to watch out for?
2003 Ford Excursion 6.0 139,000 Miles...F-650 Dash
4-2-2015 Bulletproofing completed:
Completely Rebuilt and O-Ringed Heads.... ARP Studs....OEM Oil Cooler....RCD EGR Delete....OEM Head Gaskets....Glow Plugs....Glow Plug Harnesses....Injector O Rings....Thermostat & Housing...Valve cover, Exhaust, Intake Gaskets....Riffraff Blue Boots....Turbo drain Tube.... Sinister Oil Filter, Sinister Coolant Filter, Fumoto Valve Oil & Block....Fuel Pressure Gauge.... Coolant Temp Gauge....Oil Temp Gauge....Blue Spring....FICM.Com W/Atlas 40....Aluminum Radiator
Marinco Plug Mod
08-10 Side View Mirrors
Firestone Rear Air Bags
Harpooned/ Zoodad Mod
Redhead Steering
Leveled
"If you're lucky enough to live in Texas, you're lucky enough"
blackrod is offline
post #2 of 8 (permalink) Old 11-13-2015, 02:50 PM
You can replace the front cover and use the later pump.
What problems do you have with the pump now other than leak?
Loads of people I know tow 20K+ loads with 03-04 models and overheat has never been an issue.
Front covers have been in short supply so you may have a hard time finding one other than a used one.
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
post #3 of 8 (permalink) Old 11-13-2015, 08:53 PM Thread Starter
I have had no problems with my pump at all or with engine temp. I have 168k on my Ex. I want to change to a Sinister pump to avoid problems. I figure that if I change I could upgrade if I could and if it is advisable. While Im in there I want to change the power steering pump also.
Marinco Plug Mod
Redhead Steering
Leveled
blackrod is offline
post #4 of 8 (permalink) Old 11-19-2015, 06:28 AM
I think the later pump offers dubious benefit for the time and expense of swapping the front cover, which is also very hard to find right now, and likely isn't going to get any easier unless they start making new ones again. I'd just swap in a BPD pump for your year and call it a day. The upgrade is going away from the plastic impeller in favor of billet. Once that's done the system should be pretty much bulletproof.
'06 F250 4x4 - 5" Flo Pro exhaust, SB Filter intake, Accufab elbow, Edge Evolution (monitoring only), SCT w/ ID custom tune, FASS 195 pump, Gillette Diesel EGR cooler delete, Sinister Diesel coolant filter, ELC coolant, updated turbo drain tube/oil feed line/STC fitting/oil cooler, ARPs w/OEM HGs, Elite coolant lines, ITP RR fuel system, RCD 175/30 injectors, Powermax, BD CCV, FICM.com FICM w/ ID tune, Elite UP, BPD water pump - 13.069 @ 101.94
'02 WRX - Outback rear disc swap, EBC green pads, DBA pillar vane rotors, TXS UP/TBE/TMIC, Perrin LW crank pulley, PPG billet steel shift forks, ACT Streetlite flywheel & clutch, K&N filter, STi Group N motor/trans mounts, TiC/Kartboy rear diff mounts/subframe lock bolts/outrigger stiffeners, Kartboy SS & all shifter bushings, custom PDX tune for Cobb AP - went 14.1 on a terrible 60ft before most of these mods; shooting for 13.50s
TKOPerformance is offline
post #5 of 8 (permalink) Old 11-19-2015, 09:19 AM Thread Starter
Thanks Jimmy and TKO. Your opinions are certain appreciated. I think I will go with the simple solution, BPD pump.
Marinco Plug Mod
Redhead Steering
Leveled
blackrod is offline
post #6 of 8 (permalink) Old 11-23-2015, 06:47 PM
If it ain't broke...don't fix it.
If you wan to throw money at it, pull the EGR off, tune it properly and never look back.
TousleyParts likes this.
Doug Lewis
Ford Performance Specialists
351 Six Flags Pkwy SE
Mableton, GA 30126
770-949-7191
Not Racist, Not Violent
Just no longer Silent!
Question with Boldness.
2008 F-450 King Ranch w/4.30 gears
SCT Custom Tuning by FPS, Deleted, 16mpg
2001 F-250 Platinum Edition - Gone, but not forgotten
CIA, Garrett GTP38R, 4" Exhaust, SCT Custom Tuning by FPS
shoguy89 is offline
post #7 of 8 (permalink) Old 11-23-2015, 10:30 PM
Exactly. I don't think it would really be worth the upgrade, imo anyways.
TousleyParts is offline
post #8 of 8 (permalink) Old 11-24-2015, 09:24 AM Thread Starter
Thanks for your responses. I will change the water pump and be done with it. Btw, Ive thrown a lot of money at my Ex including the EGR delete. It runs great and Im trying to keep it that way by staying 1 step ahead.
Marinco Plug Mod
Redhead Steering
Leveled
blackrod is offline
