Website?! - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 11-30-2010, 10:08 PM Thread Starter
Website?!
Looking for best place/good pricing on mods. Looking for a egr delete kit with maybe a sct tuner. Any help would be good.
coalburnertx is offline
post #2 of 5 (permalink) Old 11-30-2010, 10:53 PM
Feedback Score: 2 reviews
Look at the Supporting Venders at the bottom of Home page
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
post #3 of 5 (permalink) Old 12-02-2010, 03:52 PM
Strokin' 6.0's Avatar
I bought my delete kit from River City Diesel and am very satisfied with it. What pushed me to buy from them was that they provide a new up-pipe, rather than a block-off plate for the existing up-pipe. They also provide a billet block-off plate for the EGR hole on the intake. Make sure to install a coolant filter kit too; I bought mine from Dieselsite...$176 for everything, if memory serves me correctly. I don't run a tuner, so I can't help you with that, sorry.
Good luck.
Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
2012 Ford bed w/Factory Reese hitch option
4.10 TracLok
Dieselsite Coolant Filter
IH Fleetrite ELC
Blue Spring Update
43,956 miles - Replaced 6.0L
54,814 miles - Turbo
94,943 miles - Fan clutch
98,755 miles - FICM
127,057 miles - Aftermarket Alternator
154,120 miles - HPOP & Oil Cooler
168,514 miles - Radiator, water pump, t-stat & hoses
178,810 mles - #7 injector
181,807 miles - A/C Compressor
199,458 miles - Motorcraft Alternator
199,506 miles - FICM
199,521 miles - #1, #4, #8 injectors
Strokin' 6.0 is offline
post #4 of 5 (permalink) Old 12-06-2010, 11:53 PM
VegasDiesel's Avatar
Overly satisfied with River City Diesel. Great guys to deal with. A few mods with them and I'm about 500 hp and 1,000lb.
03' F350, 6.0, Crew Cab, 4" lift,
Amp Power Steps,
Jimmie Jammers.
4" Turbo Back MBRP exhaust,
Adrenaline HPOP from Dieselsite.com.
155 injectors, egr fix, ARP studs, black onyx gaskets, and SCT custom tunes. All from River City Diesel!
86' 944 Turbo. 4cyl, pushin'600hp. Now Goin' for 700hp! 194mph top speed. been down for a long time and finally getting my tranny rebuilt to handle the power...I hope.
04' 760li. V12, 443hp, Matching 22' wheels on adjustable coilovers, suede headliner, fridge in between reare seats, yadda yadda. Always in the shop.
Yes the girl in my avatar is actually "my girl"
VegasDiesel is offline
post #5 of 5 (permalink) Old 12-07-2010, 12:00 AM
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
dfuser is a vendor on here and he was easy to deal with and helped me with anything i have had a issue with. another guy is adam at first coast diesel, doug at gogo diesel. there are alot of good vendors that will bend over backwards to help you out. what kind of egr delete are you looking for? there are a few options. 1) weld up the cooler, 2) remove the cooler and not modify the manifold, (sinister, mkm, rcd) 3) remove the valve and mod the intake (fcdp) 4) remove the coolant from the intake all together (gogo stage 2) 5)or go the blingdy bling and get the gogo stage 1 intake manifold.
i listed them by price btw
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
