What size of injectors should I go with a 6.0L - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By 323flint
post #1 of 7 (permalink) Old 11-12-2015, 09:14 AM Thread Starter
Looking at doing injectors I do tow and I'm at 5500 ft altitude. Either I stay stock or 175 stock or 175 30.
323flint is offline
post #2 of 7 (permalink) Old 11-14-2015, 08:20 PM
If I had to do it again I would probably go with 155cc with the smallest nozzle I could get. Definitely upgrade your turbo if you haven't already. You won't like your EGT's if you run larger sticks with a stock turbo.
BGilton79 is offline
post #3 of 7 (permalink) Old 11-14-2015, 11:37 PM Thread Starter
I just stay stock, went from 13 mpg to 20 mpg. I've got a kc stage 2 turbo.
323flint is offline
post #4 of 7 (permalink) Old 11-15-2015, 06:59 AM
So, 323Flint, do you attribute your increase in fuel mileage directly to the upgrade in your turbo? I've only run one tank of diesel through my truck since I bought it (92,xxx miles on it), getting 12.3 mpg. I'd love 20 mpg. Sea level for now, Gulf coast, but intend to travel the nation.
Thanks,
Bob
********************************************2003 Ford F-350 Super Duty, 6.0L Power Stroke V-8, dually, long bed, quad cab; 2008 Lincoln MK Z; 2010 Puma by Palomino 29' fifth wheel RV; de K4RDG, Five Flags Amateur Radio Association.
NavyMustang82 is offline
post #5 of 7 (permalink) Old 11-15-2015, 07:54 AM Thread Starter
Thanks,
Bob
No I had the turbo on when I got 13 mpg, the only thing I did what the injectors. This mpg is hand calculated to.
NavyMustang82 likes this.
323flint is offline
post #6 of 7 (permalink) Old 11-16-2015, 10:12 PM
How many miles did you have when you did injectors? My fuel economy is not as good as I'd like. From 13-15 mpg. I bought mine with 209,000 and now I have about 223,000.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters. SD starter. DP 80hp tuned PCM.
'04 F550XL reg. cab. ZF-6 speed. EGR delete. Coolant filter. Cat EC-1 coolant. LF777 bypass oil filter. Blue-spring fuel pressure regulator. ScanGauge II. Glowshift fuel pressure gauge.
'06 F350 xlt crew cab. 5R110 auto trans. 4x4. EGR Delete. DIY Coolant filter. Cat EC-1 coolant. Blue spring fuel pressure regulator. Open CCV. SCT X4 Gearhead Tunes. Dual SPA fuel/oil pressure gaugeWicked Wheel 2.
sdan27 is offline
post #7 of 7 (permalink) Old 11-16-2015, 10:25 PM Thread Starter
173000 miles
323flint is offline
