Where to install tranny temp sensor??? - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 03-17-2004, 11:09 PM Thread Starter
I really don't want to cut the tranny line to put a fitting in there.
Any other suggestions???
2004.5 Ram 2500 Laramie Sport CTD
1999 F-250 CC PSD
Big Red PSD CC is offline
post #2 of 10 (permalink) Old 03-17-2004, 11:24 PM
ozhoo's Avatar
My Photos: (21)
Re: Where to install tranny temp sensor???
See this thread .
It's a 10 minute job if you use the test port.
O
02/03 built F3506L, DRW, 05 Grille, 4" DPPI Exhaust, UltraLites on the A Pillar and Overhead Console, Firestone Bags & Compressor, Hadley Bully air horns, 50 Gallon Transfer Flow, Rancho 9000's, Leveled 2.5/0
ozhoo is offline
post #3 of 10 (permalink) Old 03-17-2004, 11:25 PM
YODA's Avatar
My Photos: (14)
NOOOOOOOOOO don't cut anything. There is a plug on the side of the trans you can use. Most gage kits include the fittings that will fit.I believe it is the test port.
Do a search here or the the aftermarket general section on this. Someone has pictures of it in their photos. Another search phrase would be gage install.
2004 / 04 F350 CC PSD 4x4 Chestnut Brown King Ranch, Quad Captains, DUALLY
, long bed, auto, 4:10LS
Goodies added.
Retrax bed cover
Bed Rug bed liner
KC backup lights
C-Better mirrors
Prodigy Controller
Reese bed rails, bolt on frame install kit
Viair 550C air compressor and 2.5 gal tank
Grover 34 and 36 inch air horns
Pro Flap mud flaps
Autometer cobalt gauges with under cubby pod
Galaxy 95T CB, Wilson 5000 roof mount antenna
DPPI Cat Back Dual Exhaust
YODA is offline
post #4 of 10 (permalink) Old 03-18-2004, 12:02 AM
YODA's Avatar
My Photos: (14)
I looked high and low for that pick - geese
Goodies added.
Retrax bed cover
Bed Rug bed liner
KC backup lights
C-Better mirrors
Prodigy Controller
Pro Flap mud flaps
YODA is offline
post #5 of 10 (permalink) Old 03-18-2004, 12:59 AM Thread Starter
Excellent!!!
I knew there had to be a test port.
Thanks.
1999 F-250 CC PSD
post #6 of 10 (permalink) Old 03-18-2004, 09:44 PM Thread Starter
Just installed it tonight. Took about 2.2minutes [img]/ubbthreads/images/graemlins/smile.gif[/img] to do.
1999 F-250 CC PSD
post #7 of 10 (permalink) Old 03-18-2004, 10:10 PM
This is my first reply but it is on a topic that I know. The "test port" is not the best place to mount your trans temp sensor for the fact that there is no oil flow over the sensor. That port is a dead end and there for the temp reading is very slow to react and dose not show or tell if your trans cooler might be having a problem until its too late. The best place to install the sensor is in the cooler return line out of the radiator. That is the line that goes to the rear of the trans case. With a compression tee fitting that fits the line cut out a section that will alow the tee to be installed in the line and screw the sending unit into the tee. Using this method will insure there will always be fluid pasing over the sending unit that will give you a much more accurate reading.
Yes I have done this to my torque shift and it works very good. My trans temp rarely gets ovre 125 on the freeway empty.
Scott Trans diagnostic tech.
2003,6.0 psd,cc,torque shift, 3.73,Arizona beige,auto,dual alt,six disc,b/u sensors,power pedals,Autometer Phantom guages Boost, Pyro, Trans in "A" piller tri pod,Isspro turbo timmer,stainless grill,K&N FIPK air filter Cat back four inch w/out the cat into a thirty inch magnaflow and a five inch tip
Play toy:1968 toyota landcruiser with 350 corvett tuned port fuel injection,auto trans,detroit locker York air compressor twin viare 3.5 tanks
cruiserscott is offline
post #8 of 10 (permalink) Old 03-18-2004, 10:21 PM
YODA's Avatar
My Photos: (14)
Scott - do you happen to have a picture of this and how do you tell which line to use?
Goodies added.
Retrax bed cover
Bed Rug bed liner
KC backup lights
C-Better mirrors
Prodigy Controller
Pro Flap mud flaps
YODA is offline
post #9 of 10 (permalink) Old 03-18-2004, 10:25 PM
Yoda- I do have a photo but the line that you want is the one that goes to the rear of the trans. I installed the fittings in a straight part of line along the side of the trans.
post #10 of 10 (permalink) Old 03-19-2004, 02:21 AM
Why would you want it on the return from the cooler? I think that welding a bung in the pan would be the most accurate way of measuring actual tarns fluid temp. The return line from the cooler is not showing the trans temp, but the cooled fluid before it removes any heat from the trans. Maybe a better choice to use the line from the trans to the cooler to get what the temp is as it comes out. Just my $.02
NOGM
'04 F350 6.0 PSD Torqshift CC XLT srw long bed 4" exhaust w/ 3.5" DP SCT Custom flash tuned
'68 Mustang GT Limited Street
'67 Mustang coupe (being restored)
'97 Ford Contour
'04 H&H 24' Flat Top Enclosed car trailer
Work Truck - 1997 Peterbilt 379 Ext hood
American-Class int, 63" flat top sleeper, all bells n'whistles
3406 Cat 550hp , Eaton 18 speed
Nathan P-3 Train horn
48'X 96" Transcraft Superbeam spread axle flatbed trailer
nogm68 is offline
