Im mixing my home brew 70% to kerosene 30% - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 08-07-2006, 04:00 PM Thread Starter
I have done this with one tank so far. All is and was well but Im woundering if its a big deal. Kerosene is $.20 cheaper and Im thinking more about using it durning the winter to help out with a gelling issue
2006 F250 4x2, MBPR Exhaust, Factory 20s" w/ 34.2 inch tall tires and 4.10 gear
racing4funn is offline
post #2 of 7 (permalink) Old 08-07-2006, 04:04 PM
Spencnaz's Avatar
My Photos: (14)
Re: Im mixing my home brew 70% to kerosene 30%
I use kerosene during cold weather sometimes up to 50/50 mixture.
Be advised that you may get some surging and powerloss if the two fuels are not mixed properly.
The Green Monster
: 2001 F250 Powerstroke, 2WD, ZF6 transmission. Bully Dog GT Tuner set in tow mode. MotorSilk boric oxide added to engine, transmission and diff. Showing 30mpg on the freeway running home brew biodiesel. NTZ 1/2 Micron bypass oil filter. Dieselsite coolant filter. 4" open turbo back exhaust. Ford AIS intake. Donaldson ELF7405 oil filter. Caterpillar ELC next on the list.
Spencnaz is offline
post #3 of 7 (permalink) Old 08-07-2006, 04:46 PM
My Photos: (15)
If you are mixing it during warm weather you gain nothing except a higher fuel bill. Mixing it in the winter can certainly help with gelling, just make sure you mix it well, as Spencnaz sez, and we were told at the bio-d convention it should be mixed while the temperature is above the cloud point of both fuels.
MH
Tim
Y2K F250, XLT, SC, SB,4X4 (no decal), 3.73 LS, Dark Toreador Red, DeeZee running boards, Outland Sport bar, 3 'A' pillar guages, NVK5, Hutch tank, TT fuel reg, harpooned tank and spiderman crawling up the grill... Sunnybrook 26FKS travel trailer and Ham, WBØTUB
Maroon Harpoon is offline
post #4 of 7 (permalink) Old 08-07-2006, 05:04 PM
Spencnaz's Avatar
My Photos: (14)
Here's a really simple method of mixing.
Pour in your dead dinosaur juice first then put in your biodiesel.
What happens in that because the biodiesel is more dense, it will settle through the dinojuice mixing as it goes. Remember too, that your truck's fuel system has a return line so that will do some mixing too.
If you want to get anal about it, you can premix it in a fuel can and then put it in your truck like mixing two-stroke fuel.
The Green Monster
Spencnaz is offline
post #5 of 7 (permalink) Old 08-07-2006, 10:00 PM Thread Starter
I dry with a pump circulating in a barrel so Im thinking about adding it after its dried and let it run for a little while longer
post #6 of 7 (permalink) Old 08-07-2006, 11:19 PM
Spencnaz's Avatar
My Photos: (14)
Sounds like a plan to me, just be sure that the pump motor is an enclosed unit, kerosene vapors are explosive.
The Green Monster
Spencnaz is offline
post #7 of 7 (permalink) Old 08-08-2006, 09:38 PM Thread Starter
huh? well well will see [img]/ubbthreads/images/graemlins/smokin.gif[/img]
  Diesel Forum - TheDieselStop.com > Other Topics > Bio-Diesel and Alternative Fuels
