School me on Greasecar - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 07-27-2016, 11:50 AM Thread Starter
Howdy! I recently bought a 2000 E350 Powerstroke that has a Greaser setup installed on it. It's missing the fuel tank, but everything else is said to be there. Thing is, I know NOTHING about this stuff. This is my first diesel, so I'm totally clueless. I've done some research, but have one big question (issue?).
I bought an oil filter and a fuel filter. Oil, no problem. Went to change the fuel filter and...no fuel bowl! Fuel hose is run directly from a valve on the frame to what looks like a distribution block in the valley. Just wondering if this is normal. How does the fuel (or WVO if used) get filtered? Is it fine to run like this or can I put a fuel bowl back in?
If you need any other info, please let me know. My van is laid up right now until I find out if I can drive it as is or if I might be hurting it by not having a fuel bowl.
Thanks!!!
imacarfan2 is offline
post #2 of 3 (permalink) Old 07-27-2016, 10:31 PM
yan7gin's Avatar
this is what the fuel system should look like (see pic). now If modification where made to accommodate other type of fuel well I can't answer because I know nothing about bio diesel.
Personally I would reinstall a fuel bowl and use diesel instead of bio. filtering you fuel is a must
Name:	Returnless Fuel System.JPG
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #3 of 3 (permalink) Old 07-29-2016, 01:43 AM
Excalibur773's Avatar
Please post clear pics of the parts otherwise we are just guessing...
Excalibur773 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Bio-Diesel and Alternative Fuels
