Hi all,
I have been making w85 for years but stopped after a bad batch went through and plugged my injectors - bypassed a filter - user error :crying:
So started building a centrifuge, finally said screw it and bought one.
Background - Oil has been settling for over a year, Mixed 15% gas and let settle for a month or so then started cleaning.
Idea is particulates should come out of a thinner solution faster.
Also have notices that after mixing a sludge seems to settle out over the next while.
How fast are you all running oil through? I did the first pass at 15/lhr ~4gallons/hr and got lots of nasties. So I figured I would run a second pass to verify - bowl clean = fuel clean.
:surprise:Second pass at 7l/hr 2g/hr got lotsa nasties!!!
How slow and how many passes do I need to run?
I want it super clean as it is going into my Mercedes Jeep CRD. (Is a "test" jeep, high miler that I bought specifically to test w85 in before putting it in my "good" one.)
Run in my cummins, perkins etc no problem
How are your results?
thx John
thx John
