03, crank no start, no buzz, passes buzz test on AE - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 07-25-2019, 12:46 AM Thread Starter
Hello again,
This truck is putting me through the ringer.
I had the #5 injector come apart (I verified I got all of the parts that came off of the injector) causing a contribution code and a shorted/ oil soaked ICP causing a no start hot. I replaced the injector and the ICP and pig tail along with a new IPR screen. After all of this it started and idled up to operating temp. Went for a quick drive to walmart and as I was pulling into my house it was very low on power. Checked for codes but it did not throw any and the only stored code is p1000 and some ABS codes
I shut it off and now it is a crank no start again and it does not do the pre-cycle clatter.
I assumed I screwed something up and went over everything I did with a fine tooth comb and didn't see anything. I ran the "Injector Electrical Self test" it does not do the clatter, 8 count, clatter, 8 count, clatter but it comes back as a pass. Does anyone know what the actually procedure this goes through to give a pass fail?
The film is a replacement from international dated 03/2015 milage unknown.
So I assumed I had air in the HPOP system and have gone through 3 charges on the batteries assuming that would purge it. it does not even try to light off.
The data is:
FMP, 48V 47v cranking
FLP, 12V down to 10v briefly while cranking
FICM V, power matches FLP
FICM SYS, yes
SYNC, yes
ICP V, .25 up to 2.1V high then settles at 1.9V
ICP, 15XX
ICP desired, 15XX
IPR, Peak at 60% then settles at 49.X%
Fuel PW, 1.9-2.0MS
Fuel Timing, 5.5*
EOT, 80*
RPM, ~170 on fresh batteries
there is a little over 1/4 tank in it
I pulled the cap on the secondary fuel filter and it fills within a few seconds.
I have base oil pressure on the gauge in the dash
Is there a way to measure output from the FICM?
Thanks!
03' F350, 6.0, 4x4, EXT Cab, Long Bed
WR310rdr is offline
post #2 of 5 (permalink) Old 07-25-2019, 08:13 AM
bobofthenorth's Avatar
Make sure the main harness plugs are fully seated into the FICM
2006 F250 6.0 4x4
bobofthenorth is offline
post #3 of 5 (permalink) Old 07-31-2019, 07:30 PM Thread Starter
Harnesses were fully plugged in.
I picked up a spare FICM from a running truck to swap in and still have a no buzz condition but now have an injector circuit low on #5 and #8 rather then a straight pass.
I checked my V-Ref and have 5 volts
Any ideas where to go here?
I am making some assumptions that...
If I can read voltages in the FICM, and now receive the DTC's for injector 5 and 8, the canhi and canlo lines are intact and passing data to the ECM and probably don't need to be checked.
If i can read voltages the FICM ground is good and intact.
If im getting a DTC from 5 and 8 both sides of the injector harness should be good.
Are these assumptions accurate?
WR310rdr is offline
post #4 of 5 (permalink) Old 08-01-2019, 08:47 PM Thread Starter
I pulled the injector harness today and buzzed it with a DMM and all lines have continuity, I buzzed the remaining connector to ECM and again all lines passed.
The injector 8 code makes sense as there was some grease on the connector. the 5 is still a question mark a new injector should be good. Edit: reinstalled the injector harness and am back to a buzzless pass on AE with no injector faults
Im really lost at this point on what to test next...
WR310rdr is offline
post #5 of 5 (permalink) Old 08-13-2019, 12:32 AM Thread Starter
After talking with Ed at Ficm repair I bought a new FICM thinking the logic board was toasted.
New FICM was installed today with no change. Still no audible click either during the initial start up procedure or during the self test on AE or Forscan.
Does anyone have any idea what could be going on? My next thought is PCM but at this point I'm throwing parts at it hoping for a solution...
WR310rdr is offline
