2005 6.0 blowing upper tube off at turbo - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 05-04-2019, 06:09 PM Thread Starter
This started about 6 months ago when you first start and drive it sluggish tell it warms up and has blown the upper intercooler tube off at the turbo half a dozen time in last 6 months did it again yesterday. Has new boot and clamps from Ford but still pops off
Excursion05 is offline
post #2 of 9 (permalink) Old 05-04-2019, 07:12 PM
This was happening to me a few years ago and the problem was the oil blowback into the seal area. Ended up just cranking down on the clamp and it hasn't come off since. Have to be careful not to over-tighten it, which I'm sure you already know.
Good luck with it. It's definitely a PITA.
dillon134 is offline
post #3 of 9 (permalink) Old 05-04-2019, 09:24 PM
klhansen's Avatar
My Photos: (180)
Take the boot off and clean it and the tube with a good solvent. Brakeclean works well. Then get some liquid laundry detergent and smear a little inside the boot and reassemble. The stuff lets the boot conform to the tube initially then dries like glue.
), AIS,
regulated return,
klhansen is offline
post #4 of 9 (permalink) Old 05-05-2019, 02:41 AM
05_HARLEY_F250's Avatar
After mine blew off under heavy throttle and put a nice lump in the hood I searched the forums and found some people were using a 3” exhaust clamp mounted to the alternator to hold it down (see attachment) however I ended up switching to a riffraff diesel boot with some new spring clamps and never had another issue. I’ve also heard of people using a little hair spray to add a little tack to the inside of the boot, assemble it before it dries.
2005 F-250 Harley Davidson edition:
Bullet proofed, usual mods.
2017 F-350 DRW Lariat Ultimate:
Stock pending warranty.
05_HARLEY_F250 is offline
post #5 of 9 (permalink) Old 05-05-2019, 09:05 AM
If the vane ring in turbo is sticking or has the actuator slot worn out then the boost is not controlled right and it overboosts at upper revs and underboosts off idle. That leads to the sluggishness and then overboost that overpowers clean hose and tight clamps. The two wire connector on the VGT solenoid may be off but that should give service engine soon light.
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is online now
post #6 of 9 (permalink) Old 05-05-2019, 09:03 PM
STMPDUST's Avatar
I take a round piece of silver solder and wrap it around the lip on cold tube, install boot and put clamp directly over the solder ring i made, tighten the clamp and it has never moved in 5 years.
2015 KR Dually CC 4X4 Bronze Fire HC
2011 KR Dually CC 4X4 Royal Red
2005 Eddie Bauer Excursion 4X4 ,White
STMPDUST is offline
post #7 of 9 (permalink) Old 05-06-2019, 12:18 PM
Derkperk's Avatar
You may be on to the underlying condition here as most a adding a solution to the symptom.
However if there are no other issues, as over-boost, the hairspray tip works well.
'05 F250 Lariat Crew Shorty Dark Stone FX4
AFE, MBRP single 304 4"w/ test pipe
ARP's w/ stock gaskets, Air Dog II 165
Driven Diesel Reg Ret fuel Kit
RCD Delete, 180/75's, 68mm VG Blow Jobby
Innovative Diesel Tuned SCT X3
Diesel Site coolant filter, Insight CTS
Overhead Auto Meters, Leveled
Homebrew traction bars
35x12.50x20 ATZ's on Ultra Mako's
Derkperk is offline
post #8 of 9 (permalink) Old 05-08-2019, 07:58 AM
What have you done to verify that MAP, EBP, and BAro sensors are accurate? What do they all 3 read at KOEO?
Have you checked to see if the MAP hose has a leak or is plugged? How about the EBP tube and sensor - checked for carbon plugging them up?
Mark
bismic is online now
post #9 of 9 (permalink) Old 06-25-2019, 10:17 AM
I had same problem clean both really good, get your clamps from b&d I got mine from alligator diesel best clamps out friend is running 110psi boost with these and also spray elmers glue you can get this glue at any arts and crafts store. Clean really well with brake cleaner then apply the glue put it bacj in and tighten till spring is collapsed to the point of stripping the threads its 1/2 you wont hurt it. I did same never lose a boot again i only get around 40 to 50 psi boost. Mine first blew passing on a hill on interstate my girlfriend thought a ran someone over and freaked out lmao it took out the return hose going to degas bottle. Which was 40 at the dealer for a 1 and a half foot hose. But this will work if you clean all traces of oil off turbo and hose.
Bluebyyou411 is offline
Similar Threads
'2005 F350 6.0L Turbo replacement, Stock Garrett vs Garrett Power Max dcr31686 Upgrades and Aftermarket - 6.0L Engine 3 11-09-2015 10:54 AM
Pyro readings after the turbo - how much temp loss? VX23Hokie '99 & up Upgrades and Aftermarket - 7.3L Engine 11 03-12-2006 08:14 PM
Taking the Plunge, first performance modifications DarthSurplus '99 & up Upgrades and Aftermarket - 7.3L Engine 7 07-27-2005 11:05 AM
Pre-turbo EGT sensor question? LIZMAN '99 & up Upgrades and Aftermarket - 7.3L Engine 17 06-07-2005 05:57 PM
