Today it was running perfectly fine. I shut it off for about 15 minutes to run some errands. When I came back out, I started it, got a "check gauges" message, and then it died.
Tried again, same thing but no message. Tried a few more times, cranks, starts, dies. When it starts it sounds like it's running fine.
Disconnected-reconnected the batteries. Cranks, starts a little rougher and dies. Tried again, this time it just cranks w/ no start.
All the normal buzz whirrs and whines are present when I cycle the key.
I also tried to start w/ ICP sensor unplugged & then again w/ egr unplugged, both times crank w/ no start.
I don't have a scan tool, so any suggestions before that step would be great.
Then we need the same data as above when cranking, but add:
cranking rpm
FICM sync
Cam/Crank sync
Lots of threads on setting up the Torque Pro. Not as many for ForScan.
Hopefully, when you try to start it next, it will start w/ a cold engine. In the meantime, make sure the batteries are fully charged. I like to even load test them individually before troubleshooting because you may be cranking quite a bit and weak batteries can cause starting problems!
With the oil filter out, crank w/ the starter solenoid wire jumped to the positive battery terminal while you watch the oil filter housing (or you can have someone crank w/ the key). See if the oil filter canister fills up. It should fill up in 10-12 seconds or 4-6 seconds with the filter canister drain valve pushed down (closed).
Sounds like you have an issue with low pressure oil flow. This will confirm it (or not).
Due to it being pretty cold here and sitting here over night I didn't really get the chance to crank it for too long.
I did crank it for about 5-10 seconds roughly 4 or 5 times and the filter was still dry in the end.
Unless there's something else relatively easy to check I will more than likely be bringing it to a shop on Monday as its getting beyond what I'm comfortable with.
You really need to be watching the oil filter bowl fill up (or not) with the cap off and the filter out (as suggested originally).
That said, it sounds like your low pressure oil pump is not working for some reason.
Assuming the oil level is good on the dipstick, you either have an oil pump pickup tube that has become dislodged or you have had some foreign object go through (and damage) the gears of the low pressure oil pump.
Unless there's something else realtively easy to check I will more than likely be bringing it to a shop on Monday as its getting beyond what I'm comfortable with.
See if you are getting oil pressure while cranking. Should be able to see this inside the truck. If you are getting oil pressure its probably the IPR valve. Look up some videos on youtube and they will walk you through good trouble shooting procedures on the subject.
I brought it to a shop and they said when they pulled the Alen bolt under the truck no oil or debris came out. They believe its either some sort of suction tube falling off, low pressure oil pump or a really bad hpop leak.
If the shop didn't rule out the high pressure oil system first, then I don't think much of the shop. While an HPOP can suck down the low pressure oil pressure, if the oil filter is truly dry, then how does the HPOP even get oil ......... That is why that EASY test of checking low pressure oil flow for yourself is very much worth doing FIRST.
Seems to me they are setting you up for an HPOP change (and the 05-07 HPOP's rarely go bad).
Best of luck ..........
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
