6.0 power stroke no start hot or cold - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 06-11-2019, 04:30 PM Thread Starter
I just rebuilt my 6.0 power stroke with black diamond head gaskets, new heads, all new oil rail seals, new ICP and pig tail, new IPR pig tail, new glow plugs, new glow plug harness, turbo rebuilt, new stock injectors with 30% nozzles, FICM +40HP flash, new HPOP, and ARP head studs. New oil and filters and upgraded 4 hole banjo bolt for fuel system. The truck started once on its own. Ever since then the truck will only start with ether. Doesn’t matter hot or cold it won’t start without ether. ICP reads 220 psi engine on key off. 600-1000 psi while cranking and 600-1400 once running. IPR 14-60% when cranking and 20% when running. FICM voltage 12.5 Volts FICM injector voltage never drops below 48 at any time. I talked to another shop and was told I need to drive it for a few miles to clear the air out of the HPOP and oil system. Any other ideas?? Thanks
Deercentral is offline
post #2 of 12 (permalink) Old 06-11-2019, 10:03 PM
Derkperk's Avatar
How long did it run after the one time it started? What’s your fuel pressure???
'05 F250 Lariat Crew Shorty Dark Stone FX4
AFE, MBRP single 304 4"w/ test pipe
ARP's w/ stock gaskets, Air Dog II 165
Driven Diesel Reg Ret fuel Kit
RCD Delete, 180/75's, 68mm VG Blow Jobby
Innovative Diesel Tuned SCT X3
Diesel Site coolant filter, Insight CTS
Overhead Auto Meters, Leveled
Homebrew traction bars
35x12.50x20 ATZ's on Ultra Mako's
Derkperk is offline
post #3 of 12 (permalink) Old 06-12-2019, 12:22 PM Thread Starter
I just rebuilt it. Have about 5 miles on it. Runs great once it starts.
post #4 of 12 (permalink) Old 06-12-2019, 12:40 PM
Who's injectors did you use?
Mark
bismic is offline
post #5 of 12 (permalink) Old 06-12-2019, 05:16 PM Thread Starter
Ford oem
post #6 of 12 (permalink) Old 06-12-2019, 05:35 PM
I guess I was wondering who modified them ...
Also, this doesn't make sense to me:
Mark
bismic is offline
post #7 of 12 (permalink) Old 06-15-2019, 11:42 AM
If your driving it shouldn't have air in the hpop
Bluebyyou411 is offline
post #8 of 12 (permalink) Old 06-15-2019, 11:32 PM
bobofthenorth's Avatar
Are you saying it cranks up to 1000 PSI injector pressure and doesn't start? If you're saying 220 PSI ICP KOEO then that doesn't make sense to me either. You didn't specifically say but I assume you are getting FICM sync on the non-starts?
2006 F250 6.0 4x4
bobofthenorth is offline
post #9 of 12 (permalink) Old 06-16-2019, 10:29 PM
Supporting Member
IIRC: IPR should be running at 85%. About 10 miles driving (after I did a cooler relocation), my IPR valve screen clogged (limped home). Replaced the screen and the truck ran file.
hdude
2006 F350 Lariat CCab Dually FX4, 205K, Bilstein 5100s, EGR Delete, BPD Cooler Relocate, BPD WaterPump, Coolant Filter,
Upgraded BlueSpring and easy to fix common failure points.
hdude is offline
post #10 of 12 (permalink) Old 06-16-2019, 11:59 PM
No it shouldn't. If you see 85% more than momentarily you've got a problem.
2006 F250 6.0 4x4
post #11 of 12 (permalink) Old 06-17-2019, 11:32 AM
Supporting Member
My bad. When I get my truck back together, I will be able to refer to my ScanGuage to find the PID that was able help diagnose the IPR being clogged and I will update my previous post.
hdude
hdude is offline
post #12 of 12 (permalink) Old 06-17-2019, 12:45 PM
ICP of 220psi KOEO means a biased sensor or wiring issue. If the PCM is thinking it is 550psi when it is really 330psi then it will never start and run right. Unplug ICP sensor and see what happens when it uses default table values.
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
