Diesel Forum - TheDieselStop.com
Diesel Forum - TheDieselStop.com (https://www.thedieselstop.com/forums/)
-   6.0L Power Stroke Engine and Drivetrain (https://www.thedieselstop.com/forums/f23/)
-   -   6.0 powerstroke long crank (https://www.thedieselstop.com/forums/f23/6-0-powerstroke-long-crank-656378/)
gsch2 08-08-2019 08:59 PM
so when i start cranking on my 6.0 it takes a good amount of time. i just got the oil cooler and hpop replaced. it starts better but makes a clunking noise for like 2 seconds then stops. opinions?
gsch2 08-08-2019 09:32 PM
and it only happens when it sits
dillon134 08-08-2019 11:05 PM
It would help if you could provide us some data. What are your ICP and IPR values while you are cranking? How long does it take to turn over? What year 6.0 do you have?
gsch2 08-09-2019 07:57 AM
i don’t have anything to test that
gsch2 08-09-2019 07:59 AM
it’s a 2006.
bobofthenorth 08-09-2019 01:33 PM
"It only happens when it sits" For a couple of minutes? For a couple of hours? Overnight?
You're going to have to figure out how to get some real numbers - otherwise we're just throwing darts at the wall.
dillon134 08-09-2019 01:38 PM
it’s a 2006.
It being an 2006 6.0L, I'm kind of surprised that you needed a new HPOP as they have been known to be pretty stout. The earlier model 6.0's had weaker HPOP's that were problematic. Long crank sounds like a leak in the HPOP system to me. Maybe the dummy plugs or stand pipes need to be replaced. Also, I would hope that your mechanic installed an newer updated STC Fitting on the HPOP.
You should download one of the monitoring apps like forscan. I think you'll need a wireless dongle to connect it to the vehicle.
gsch2 08-10-2019 12:06 AM
well it starts hard anywhere after sitting for a couple of hours so overnight and stuff
gsch2 08-10-2019 12:09 AM
well i did get some dummy plugs replaced but i don’t know how many. that was my idea at first but it’s still makes a weird noise. i see there anyway i can attach a video somehow?
dillon134 08-11-2019 12:20 AM
There is a wealth of knowledge on this forum for you to review. You should just go through similar threads and learn from those that came before you. I was new to Diesels about 7 years ago and now can do all of my own work. There are 2 dummy plugs and 2 stand pipes. Each can have o-ring failures that cause the symptoms that you have described.
There are also TONS of videos on YouTube about 6.0's.
bomhour 08-12-2019 08:38 PM
You are correct. The Forscan lite app for iphone monitors all of the PID's you mentions. And yes, you need a wifi odbii adapter from Amazon. the whole setup cost about $30
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
