Another Alternator - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By TKOPerformance
post #1 of 4 (permalink) Old 02-06-2017, 10:04 AM Thread Starter
Another Alternator
I just replaced my FICM, batteries, and alternator about a month ago and this morning the voltage reading on my scan gauge dropped from 13+ to 11.9-12. Then it stayed at 11.9 and the battery light came on. Am I seriously going to have to replace the alternator again? What would cause this to happen?
russmon06 is offline
post #2 of 4 (permalink) Old 02-06-2017, 05:54 PM
That's not likely the alternator causing that. You're seeing battery drawdown from the GPs. I'd put my money on one or more batteries being weak. If you're putting out 13.5-14V going down the road once its warmed up the alternator is doing its job.
'06 F250 4x4 - 5" Flo Pro exhaust, SB Filter intake, Accufab elbow, Edge Evolution (monitoring only), SCT w/ ID custom tune, FASS 195 pump, Gillette Diesel EGR cooler delete, Sinister Diesel coolant filter, ELC coolant, updated turbo drain tube/oil feed line/STC fitting/oil cooler, ARPs w/OEM HGs, Elite coolant lines, ITP RR fuel system, RCD 175/30 injectors, Powermax, BD CCV, FICM.com FICM w/ ID tune, Elite UP, BPD water pump - 13.069 @ 101.94
'02 WRX - Outback rear disc swap, EBC green pads, DBA pillar vane rotors, TXS UP/TBE/TMIC, Perrin LW crank pulley, PPG billet steel shift forks, ACT Streetlite flywheel & clutch, K&N filter, STi Group N motor/trans mounts, TiC/Kartboy rear diff mounts/subframe lock bolts/outrigger stiffeners, Kartboy SS & all shifter bushings, custom PDX tune for Cobb AP - went 14.1 on a terrible 60ft before most of these mods; shooting for 13.50s
TKOPerformance is offline
post #3 of 4 (permalink) Old 02-07-2017, 09:11 AM Thread Starter
Thank you for the reply, but did you read the post? "The voltage reading on my scan gauge dropped from 13+ to 11.9-12." Indicating that the alternator was out. I had the alternator bench tested and it was indeed bad. My question is what would cause it to go bad in less than a month? By the way how much money were you putting down? haha
post #4 of 4 (permalink) Old 02-07-2017, 10:37 AM
Yes, I read it, but you are misunderstanding what you are seeing. The amp load when starting a 6.0 and while the GPs are lit, which is for several minutes after starting, is extremely high. It is too high for a stock output alternator to fill the void created by the drawdown of the batteries. So what you are seeing is the load draw the batteries down to a degree for which the alternator cannot compensate. Once the GPs go out the alternator can fully recharge the batteries, which is why you see the reading go back up. A weak battery exacerbates this effect.
This is why 6.0s seem to go through batteries much faster than other vehicles. My stock batteries lasted all of two years. I then switched to Interstate Megatron II batteries from which I typically get 5 years. My stock alternator has 194k on it and still does the job.
An option is to swap in a higher output alternator like one from DC Power, but they are spendy ($300+).
Still another option is to upgrade the charging cabling from that alternator by adding a 1 gauge wire from the charging post to the + terminal on the RH battery, and add a 1 gauge ground from the alternator case to the chassis ground lug on the crossmember. I did that upgrade about 74k ago.
TurboThrill likes this.
