Any ideas on what this noise is? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 10-15-2019, 05:06 PM Thread Starter
https://youtu.be/Qm-WNm3aCAk
Can’t figure out what this noise is. Any ideas? A loose bolt/nut bouncing around under the valve cover is my guess. Thanks for the help.
Jcallon33 is offline
post #2 of 8 (permalink) Old 10-16-2019, 01:06 AM
No clue. Doesn't have any rhythm to it... It sounds random.
dillon134 is offline
post #3 of 8 (permalink) Old 10-16-2019, 07:44 AM
It's pretty loud so it sounds like its outside the block. Cracked flex plate? Maybe loosen the fan belt so the stuff on the front of the motor doesnt turn and see if it goes away. If not then it's probably in the bellhousing
HONDARACER is offline
post #4 of 8 (permalink) Old 10-16-2019, 10:30 AM
Pull the valve cover and inspect rocker arms and bridges to eliminate issues there that could make it drop a valve. What does it do if you increase engine speed? (cut broom handle or anything you have handy. measure between front edge of driver's seat lower cushion and acc pedal then add 1 1/2 inch. Slide stick progressively to the right to adjust speed)
That is not flex plate. I had a 6.0 with that and it was regular beat knock like it is on any gasoline engine. It changed with trans in gear and the loading from that. Loose TC nuts was also a regular beatnoise that didn't sound like that.
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
post #5 of 8 (permalink) Old 10-16-2019, 12:44 PM
Pull the accessory drive belt off and see if it go's away.
DENNY
DENNY is offline
post #6 of 8 (permalink) Old 10-21-2019, 11:17 PM
RGJ58's Avatar
After reading your post I figured oh no maybe a failing lifter. But after watching the video I certainly don’t think that is the case as the noise is only ever now and then. I could be wrong but I would do what some of the other posters have suggested first start by taking the fan belt off. Start the truck for a short period and see if the noise goes away. Otherwise also check the area of the flex plate as also stated. If none of this proves to help find the noise I would take a pipe put your ear up to it and move it down the valve cover there. I know that sounds stupid but it may help isolate the noise of the engine and help you detect a possible valve train issue. However I do believe it’s going to be something other than valve train issues. One other possible thing I can think of is a timing gear set issue under the front cover. Otherwise good luck keep us informed on what you find!
RGJ58 is offline
post #7 of 8 (permalink) Old 10-23-2019, 02:18 PM
Rocker arm/bridge.
2002 F250 7.3 ext sb
2003 F350 DRW 4x4 CC LB
thecustommuffler is offline
post #8 of 8 (permalink) Old 10-31-2019, 09:31 AM
GaF2504x4's Avatar
timing chain/gear
TIMING CHAIN/GEAR is in the back of the motor on 6.0 I believe.
2004 F250 4x4 Lariat CC Mostly Stock
Fumoto oil drain valve.
Mishimoto Coolant Filter.
Replaced Coolant Cap 2016
Blue Spring
Rotella ELC Coolant
replaced 110 amp alt with 185 amp alt.
at 88k miles 2019
powerstrokehelp.com
ARP studs
o-ring heads
bulletproof diesel water pump
rear head coolant bypass to therm housing
oil to water heat ex-changer replaced
hpop replaced (it was right there)
replaced top and bottom rad hose, coolant overflow return hose and reservoir (another new cap)
new belt, pulleys and tension-er
rear end service
transfer case service
transmission serviced (2nd time)
u-joints replaced, center bearing replaced, balanced shaft.
first brake job:
4 rotors replaced (due to warping)
4 calipers replaced
carbon/ceramic pads
EGT sensor added
Edge CS2 added
GaF2504x4 is offline
