Can an OBD Adapter cause problem with dash cluster gauges? - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 08-06-2018, 10:24 AM Thread Starter
iqraceworks's Avatar
Question Can an OBD Adapter cause problem with dash cluster gauges?
I’ve been having an intermittent issue with the dash cluster gauges on my 05’ F250 shutting off a few seconds after I start the truck (might happen a couple of times a month). The Tach, Speedo, and water temp gauges die….but the oil pressure, fuel, trans temp, and boost gauge keep working. I also get the wrench and check engine lights as soon as the gauges die. I will also get a TBC fault at the same time.
Usually shutting the truck off and restarting it fixed the issue. The gauges always work for 2-3 seconds after I start the truck…..then after a few seconds, they die and I get the fault.
I had it happen again to me this weekend, and while the truck was idling, the gauges were dead, and I was getting the faults….I tried using my Torque PRO app to scan for codes. Well, the cheap $10 ELM327 OBD Bluetooth Adapter (that I always leave plugged into the OBD connector on the truck) would not hook up to my phone for some reason…..so I unplugged it to see what was going on.
As soon as I unplugged the OBD adapter, I heard a beep from under the dash…….the faults on the cluster all cleared, the gauges all sprang back to life. Even after plugging the adapter back in, everything is fine.
I’m just wondering if anyone else has had an issue like that. Is it possible for an OBD adapter to cause problems like that with the dash cluster and gauges?
2005 F250 6.0 PSD, ARP Studs, Felpro HG's, EGR Delete, IPR Coolant Filter, Bilstein 5100s, Blue Spring Mod, IDP Custom Tunes
iqraceworks is offline
post #2 of 6 (permalink) Old 08-06-2018, 03:44 PM
79jasper's Avatar
Could be. I've seen some weird stuff.
Tpms issues, key fob issues, etc.
Sent from my SAMSUNG-SM-G920A using Tapatalk
79jasper is offline
post #3 of 6 (permalink) Old 08-06-2018, 05:11 PM Thread Starter
I did a little research online, and it sounds like lots of the chevy guys with newer Vette's and Camaros who are using the Torque App with the ELM327 Bluetooth OBD adapters have had strange issues also....gauges going haywire, false engine codes, and faults when they have the bluetooth adapter plugged in.....but when they unplug them, the problems go away. The OBD port pretty much gives you full access to everything in the PCM, so I can see how it could cause issues if the OBD adapter you have plugged into it is doing some funky stuff.
post #4 of 6 (permalink) Old 08-20-2018, 03:01 PM Thread Starter
Well, I’m 110% sure that the ELM327 OBD Bluetooth Adapter is what’s causing the intermittent issues with my gauge cluster.
I haven’t used it for the last few weeks……and then this weekend when I did some towing, I decided to use the Torque PRO app on my phone to keep an eye on things. I had no problems with it at all until later in the day when I stopped at a gas station to fuel up. I left the adapter plugged in while the truck was off, and then after I started the truck up and started to pull out of the gas station…..the gauges went dead, and I got the check engine light on the dash, and TBC fault.
As I was driving down the road I reached down, and as soon as I unplugged the OBD adapter, the gauges instantly came back on….the check engine light turned off, and the TBC fault display turned off….and everything went back to normal.
There is no doubt in my mind now that the OBD Bluetooth adapter is causing my issues.
Tons of people use this same setup on their trucks…I wonder why mine would be having such as issue with it? I guess I can try a different OBD adapter and see if that fixes the issue.
post #5 of 6 (permalink) Old 08-20-2018, 04:10 PM
Phil G.'s Avatar
Even Auto Enginuity can cause similar issues. I pulled into a truck stop just out side of Chicago a few months back and decided to plug the laptop with AE in and see if the trans temp the pillar gauge was reading was accurate because it was showing to be very warm. The battery in the laptop was almost dead so I plugged it into the 1500W inverter (I knew better but forgot, AE warns that this will cause issues, the PC can't share the same ground as the vehicle it is testing). All of a sudden the dash lit up, AE filled up with codes and the truck would not turn over.
Panicked at this point, I jumped out, opened the hood and tried rolling it over with the wire on the PS fender well, it did. By the time I walked back around and sat in the truck, I knew what I had done. I unplugged from the inverter, cleared the codes and started the truck. Talk about a stressful 15min, I had 35' of trailer behind me and a dead truck a long way from home.
I would imagine any OBD connection is capable of cause issues if the software is not written really well. Since the switch over to ELD devices in the commercial trucks which requires a similar adapter to be plugged into the OBD, many have complained about dead or strange acting trucks.
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4. Viper Alarm/RS, WD pillar Guages,AutoEnginuity, 100gal polished alum fuel tank.
All Sold: 99.5, early03 , 2004 - all were 172" wb 4x4 lariat's.
My Worklog - *Updated 8/18 with Edge CTS2 install click here =>*:
Phil G. is offline
post #6 of 6 (permalink) Old 08-29-2018, 04:02 AM
I have a Lauch CR3001 seems works well.
Muerms is offline
