Dead Battery - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 09-05-2006, 12:54 PM Thread Starter
Dead Battery
Apparently I left the key in the on position overnight. Batteries are dead and doors locked. Keypad does not operate with dead batteries. How can I get enough power to make the keypad work?
2006 F350 DRW King Ranch 4.30 Tow Boss (stock)
600 miles 7-21-06 7000 miles 10-21-06
46,000 miles 3-22-2008 SOLD
2000 F250 XLT WHITE 172" 7.3 3.73
BFG 315/75/R16 TA/KO
140,000 Miles 5/8/06
Rpm Cold Air Kit
iablo Flip Chip Stk-54-85?
Pro-Flo 4" exhaust:Gafrigg Pyro-Trans-Boost
Bilstein 5100 Shocks:Pro Comp stabilizer
Tuff Country leveling Kit:Add a leaf on rear
HHBC is offline
post #2 of 13 (permalink) Old 09-05-2006, 02:46 PM
Re: Dead Battery
Open the door with the spare key, using the lock...?
Get a trained squirrel to climb up through the wheelwell to attach jumper cables?
That's about all I got...
Duncan
The 1997 F250HD Crewcab:
The 2000 XLT Excursion <font color="red">(SOLD)</font>:
The 2003 F250 Crewcab 6.0L:
The 6.0L Bible:
The 6.4L Bible:
frobozz is offline
post #3 of 13 (permalink) Old 09-05-2006, 02:48 PM
Black05's Avatar
Re: Dead Battery
It makes one wonder what we did before vehicles had electric door locks? [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Black/05/F350/XLT/CC/LWB/FX4/SRW/3.73/6.0L PSD/ TorqShift/Updated TBC/Upfitter Switches/SEIC Mod/Diesel Site Coolant Filter/Fumoto Valve/ITEC HFCM Drain Plug/Bilstein Shocks/BFG A/T 28565R18/Built September of 2004
Texas Proud.
God Bless our Armed Forces.
Black05 is offline
post #4 of 13 (permalink) Old 09-05-2006, 03:00 PM Thread Starter
Re: Dead Battery
Guess where the spare key is? I was curious if you could somehow hook up to the trailer hookup to get enough power for the door locks to work.
Charles
Rpm Cold Air Kit
HHBC is offline
post #5 of 13 (permalink) Old 09-05-2006, 09:27 PM
Re: Dead Battery
Among other things it probably depends on how dead the batteries are. If they are really gone then, unless the source is really hi amp, it probably won't wotk. On the other hand if the amps are that high it might over load something. I suspect a possibility would be to apply a voltage to the trailer hook up that is of nominal amperage capability and wait for the batteries to charge slowly. Just guessing here mind you. Never been in quite this spot before. I used to keep a spare door lock key in my wallet for such predicaments.
'05 F350 Lariat DRW 4X4 6L Auto, stock.
Above replaced '91 F350 XLT Lariat DRW 2X4 7.3L 5 speed man.
jbdawson is offline
post #6 of 13 (permalink) Old 01-10-2017, 08:29 PM
jeepraptor's Avatar
Old thread but anything ever come of this? I have this same problem now...someone tried to punch my lock so i cant use a key...
jeepraptor is offline
post #7 of 13 (permalink) Old 01-10-2017, 08:45 PM
Phil G.'s Avatar
The one time I locked mine in on my 99 with it running in a rest area, I placed both my hands flat on the slider glass and forced it open. The latches break easy.
Other than that, IDK. I doubt back-feeding the BAT terminal on the TT connector would work because it must be relayed to the ignition. It loses power when you shut the truck off.
I'm not sure if the latch on the rear slider is replaceable, I never fixed mine but I guess other than that call a lockout service.
Edit: if the key hole is open or can be opened up, maybe a coathanger or thin pliers on the lock rod?
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4. Viper Alarm/RS, WD pillar Guages,AutoEnginuity, 100gal polished alum fuel tank.
All Sold: 99.5, early03 , 2004 - all were 172" wb 4x4 lariat's.
My Worklog - *Updated 8/18 with Edge CTS2 install click here =>*:
Phil G. is offline
post #8 of 13 (permalink) Old 01-11-2017, 06:21 AM
SparkyAl's Avatar
Location: Up to my butt in alligators. Why am I here again?
http://www.revbase.com/BBBMotor/Wd/D...dPdf?id=878488
Connect your charger (+) to the battery wire at the starter and (-) to ground charge it up and unlock it. It will probably have enough to unlock as soon as you turn on the charger... (BTDT)
Sparky Al
2016 F350 4x4 crew cab SRW 6.7L
SparkyAl is offline
post #9 of 13 (permalink) Old 01-11-2017, 09:44 AM
Phil G.'s Avatar
Awesome idea...Before I answered, I was sitting here trying to think of how the batteries could be accessed with a charger from underneath and never even thought of the starter power stud.
Glad someone around here is on the ball!
Phil G. is offline
post #10 of 13 (permalink) Old 01-11-2017, 04:31 PM
I back fed power thru the trailer terminal on a Dodge to get it unlocked. Using the starter lead idea won't require buying a trailer plug either!
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
post #11 of 13 (permalink) Old 01-11-2017, 04:58 PM
SparkyAl's Avatar
FWIW, going to the starter lead won't work on older Fords that use a starter solenoid. That's why I included the drawing link.
Sparky Al
SparkyAl is offline
post #12 of 13 (permalink) Old 01-11-2017, 06:21 PM
klhansen's Avatar
My Photos: (180)
Should work fine on a 6.0L. I know it will on a 7.3L, as the solenoid is mounted on the starter with a hot lead connected to it. There's a second somewhat smaller lead that activates the solenoid coming from the fender mounted relay on '99-'01 truck, and from the Relay Panel starter relay on '02-03 7.3L's and is the same configuration on the '03 6.0L's for sure, and likely the same on later 6.0L's.
Pretty awesome idea for guys that have the all-electric doors.
), AIS,
regulated return,
klhansen is offline
post #13 of 13 (permalink) Old 01-11-2017, 07:10 PM
Phil G.'s Avatar
That would work on some of the older trucks that were live all the time to the TT charge line but the SD's have been relayed through the ignition since 99 as far as I know. I got to think the other brands at some point all did the same. I remember coming out to a dead chevy a couple times in the 90's from forgetting to unplug the trailer overnight and something was left on in the trailer.
Phil G. is offline
