Do Injectors age-out? - Diesel Forum - TheDieselStop.com
 3Likes
post #1 of 33 (permalink) Old 10-05-2018, 05:43 PM Thread Starter
I've got to open up the passenger side and install a new #7 injector. I replaced #4 not long ago. My Excursion has 165K on the original injectors so I'm wondering of I should just replace the other 6 as well. Is there a shelf life on Injectors?
I know most people are reluctant to change all 8 at one time due to the cost. I may have a fuel pressure issue and will resolve that before I drive the truck on the new injectors.
dillon134 is offline
post #2 of 33 (permalink) Old 10-05-2018, 06:16 PM
RT
RT's Avatar
Yes. Your truck is continually monitoring you for phrases like, “ I got a raise” or, “we have money left over this month.” It will respond appropriately. Seriously though, they wear approximately the same so it makes sense to replace them as a group. The exception would be a non wear related catastrophic failure. Kind of like how you buy tires as a set unless you have a blowout.
dje5717 and oilcan1001 like this.
RT is offline
post #3 of 33 (permalink) Old 10-05-2018, 06:20 PM
Lol - nice post RT! Got a good chuckle out of it!
I took his post to mean if he bought the injectors now, but didn't install them for awhile (ie the shelf life question).
Mark
bismic is online now
post #4 of 33 (permalink) Old 10-06-2018, 06:22 AM
05_HARLEY_F250's Avatar
Let your truck know that this type of behavior will not be tolerated by purchasing a new truck and parking it next to it. That note comes before hobby truck repairs.
2005 F-250 Harley Davidson edition:
Bullet proofed, usual mods.
2017 F-350 DRW Lariat Ultimate:
Stock pending warranty.
05_HARLEY_F250 is offline
post #5 of 33 (permalink) Old 10-06-2018, 07:50 AM Thread Starter
Thanks guys. By shelf life I didn't mean how long they last in the box/uninstalled, I meant life expectancy in the truck. I probably could have made that more clear.
My main question was is 165K miles considered a lot on an original set or do people often get more miles on them?
post #6 of 33 (permalink) Old 10-06-2018, 08:19 AM
RT
RT's Avatar
Wow - you're a lot braver than I am. That would be like bringing home a new girlfriend to meet your wife. I can hear her now - "Ow - my transmission hurts..."
stumpman likes this.
RT is offline
post #7 of 33 (permalink) Old 10-07-2018, 03:52 PM Thread Starter
I saw a video where a guy, as a precaution, replaced the injector hold down clamp/bolts because he was afraid that they had been over-torqued. He said that the bolts are no good after that has happened.
Is that true? The reason I ask is that they seemed a little tighter than 26 ft/lbs when I just removed all 4 from the passenger side. If they were over-torqued then it was my fault but I thought I was careful when I removed, cleaned and re-installed my original injectors a few months ago.
post #8 of 33 (permalink) Old 10-07-2018, 05:28 PM
Some people theorize that the head cracking that we occasionally see could be from over torquing of the injector hold down clamps. I am not sure I believe that to be the only reason because we normally see the cracking on the "middle 4" locations (around 3,5 and 1,4 cylinders). Anyway, if it is only "mildly" over-torqued, I wouldn't worry about getting new clamps and bolts.
It is more important to thoroughly clean out the bolt holes and to use a calibrated torque wrench IMO.
Mark
post #9 of 33 (permalink) Old 10-07-2018, 11:23 PM Thread Starter
Roger that. I'm assuming compressed air is best to blow out any oil in the bolt holes. Also, a little oil drained into the injector cups so I'm hoping I can also use compressed air to blow that clean as well.
post #10 of 33 (permalink) Old 10-10-2018, 12:31 PM
I used Brakecleen followed by compressed air. Careful of your eyes when doing it.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
post #11 of 33 (permalink) Old 10-10-2018, 12:34 PM
I got 175,000 out of my first set. 150k to 200k seems to be their average lifespan.
Ford06 is offline
post #12 of 33 (permalink) Old 10-10-2018, 01:31 PM Thread Starter
Thanks 06. Is the Brakeclean intended to clean up the entire rocker arm box housing area or just to thin out the oil to make it easier to blow out of the injector cup/sleeves and bolt holes?
post #13 of 33 (permalink) Old 10-10-2018, 05:26 PM
79jasper's Avatar
Cleaning Out the hold down bolt hole....
Sent from my SAMSUNG-SM-G930A using Tapatalk
79jasper is offline
post #14 of 33 (permalink) Old 10-10-2018, 07:25 PM
Calico5's Avatar
Did you purge out/expel all of the oil that leaked in (from the HPO rail) to the cylinder while the injector was out?
Good way to bend/break a lower end part, if you didn't...
~Al
Al in SoCal
AFE Intake; Garrett 38R; DieselSite Turbine Jacket
HPS Hi-Temp CAC Boots; Banks Big IC, Banks Engine Brake
External Oil cooler & Remote filter; Stealth 4-line Twin HPOP, Melling LPOP
Swamp's: 160cc/30% Injectors & HVHF IDM; DP-Tuner F5; Fluidamper Balancer
Custom Full Reg.-return Fuel System, Pre-& Post-pump filtration
Mishimoto Radiator & Exp. Tank; T444 Water Pump w/Filtration
Bellowed S/S Up-pipes; 4" Turbo-back Custom Exhaust into Twin Stacks
SouthBend D-D Clutch; ZF 6-spd w/CoreShifters Short-throw Stick
GearVendors O/U Drive
Calico5 is offline
post #15 of 33 (permalink) Old 10-11-2018, 04:36 PM Thread Starter
~Al
Not sure I understand your question. When the oil rail is removed, the injectors are still in place so the oil that drains out couldn't (initially) find its way into the injector sleeves and injector hold down bolt holes. I'm sure that a little oil could and does drain into those cavities once those parts (injectors and hold down bolts) are removed. I know this because I can see a little oil in the bottom of the sleeves.
I've never had the heads out and have never had the opportunity to inspect another 6.0 head up close but don't they have drain back channels so that oil can drain back down into the motor? I remember seeing other posts from guys who had dropped bolts or sockets down that channel and had to get them out.
Are you saying that a lot of oil normally finds its way into the sleeve and then into the cylinder and it needs to be expelled out somehow.
Sorry. I appreciate your comment but want to make sure I understand what your saying exactly.
