Dorman Oil or filter caps - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 08-17-2019, 10:54 PM Thread Starter
I have had three trucks now with oil leaks at oil filter cap using Dorman caps. The same cap is used for HFCM filter. The filter cap shrinks and the O ring doesn't seal. Two were just seeping but one quit running when HPOP ran out of oil and seems to be OK after a new cap, oil fill, and mess clean up. You can tell it is a problem as a Ford/IH cap gets hard to turn the instant the O ring gets into top of housing, Dorman cap can be run down to stop with little more than hand tightening. The Dorman caps fit the threads loosely before the O ring makes contact where OE caps have little loose motion.
All these people had used Wix integrated cap filters and then realized how much more expensive those were and went back to standard filters and cap. AutoZone, OReilly's, and others have Dorman caps in stock.
SPREAD THE WORD
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
post #2 of 2 (permalink) Old 08-18-2019, 07:35 AM
I have used Dorman bolts before, but didn't even want to do that. Dorman quality is pretty bad IMO. Thanks for the post Jimmy.
Mark
bismic is offline
