Filled with Gas instead of Diesel - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 04-02-2008, 09:33 PM Thread Starter
First of all, thank you jerzydiver and sergeantnic for help with my remote start/glow plug input question.
Now, just today my friend(really...not me) accidently filled his '07 PSD with gasoline instead of diesel. He says the fuel light came on prior to filling it up so there were only a few gallons of diesel in it. He stopped at a station and drove up to the pumps. He was about grab the green handled pump when he was interrupted by someone who needed to ask him a question. That was just enough to cause him to grab the green handled pump(which is usually diesel) without reading first. Well, it was gas. He drove about 1 mile and the truck started to run badly. He immediately pulled off to the side of the road and shut it off. Just across the street is a Fletcher's Automotive Repair shop. I pulled the truck there and they will drain the tank and replace the filters etc. However, they said he should also replace the fuel pump. Do any of you have an opinion on this? First of all it has years left on the warranty, but he doesn't want it to become unreliable either(they claim the fuel pump seals/o-rings will be dried out because of the gasoline). Should he have them replace the pump or not? Also, should he do anything else other than draining the tank and replacing the filters? Thank you.
- Myron.
myron is offline
post #2 of 15 (permalink) Old 04-02-2008, 09:42 PM
A friend of mine had the same thing happen. When he bought his truck the dealer took it down to fill it up before he left the lot and put gas in it. He said the dealership acted like it was no big deal and drained the fuel system and refillled with diesel and sent him on his way.
gmalott is offline
post #3 of 15 (permalink) Old 04-02-2008, 09:54 PM
jsmichael's Avatar
Of course is wasn't a big deal to the guy who didn't own the truck. The problem is that gas is going to ruin the fuel injectors. Here's a reply to a similar question:
The tank needs to be drained. I usually disconnect the fuel pump outlet
hose and hot wire the pump so it purges the tank and lines. Add five to ten
gallons of fuel to the tank along with some lubriciy modifier, Marvels, or
even some ATF. Open the fuel filter drain and head passage drains and use
the fuel pump to purge the rest of the system. Replace the fuel filter,
start the truck and start checking for injector damage. Most likely there
will have been some injector scuffing unless he's lucky. If he was really
working the engine he could have piston and/or valve damage. Whatever the
out come recommend that he continue using a fuel lubricity modifier for the
next several fill ups.
Charles Ledger
ASE Master--Auto; Advanced Engine Performance;
Diesel Engines; Medium/Heavy Truck Electrical
Ford Senior Master Technician--Engines, Drivetrain, Chassis
'08 F-350 XLT (Job 3) 4X4 6.4L PSD CC SRW LB, Line-X bedliner, UWS toolbox, Goodyear Wranglers (Silent Armor), Marathon seat covers, Edge Insight
jsmichael is offline
post #4 of 15 (permalink) Old 04-03-2008, 08:51 AM
Smiley1's Avatar
NEVER use ATF or MMO. That stuff does not have the lubricity that our pumps and injectors need. There was a study on those some time back. Very bad.
Use Diesel Klean, Stanadyne, or ashless outboard 2-stroke oil. There are some others that can be used.
2004 F350 CC FX4 280,000+ miles!
2004 Surf Side 30' pull trailer
2002 Mustang GT
1968 Pontiac Firebird (restored)
Smiley1 is offline
post #5 of 15 (permalink) Old 04-03-2008, 08:14 PM
jsmichael's Avatar
Sorry to disagree, but I'll put my trust in Charles Ledger, a Ford Master Mechanic in California. He's the moderator of the Yahoo Powerstroke newsgroup who has helped hundreds of PSD owners diagnose and fix problems. I'm not saying he's the end-all on all PSD knowledge, but he's in the trenches every day working on these trucks. He's not going to recommend using ATF or MMO for helping to lubricate the fuel injectors after someone puts gasoline into their truck unless it's going to help.
Regarding MMO, I've used that on a regular basis in my old 7.3L PSD, and I've started using it in my 6.4L PSD. MMO is a great lubricant for the fuel system.
post #6 of 15 (permalink) Old 04-03-2008, 11:45 PM
Smiley1's Avatar
No thats OK. I actually like MMO for other uses except for the fuel system after I read this below:
You can just skip to the bold below if you want. This has been posted on this forum before IIRC.
The following are the preliminary results of a research study on diesel fuel Lubricity Additives. There is likely to be further commentary and explanation added at a future time.
PURPOSE:
The purpose of this research was to determine the ability of multiple diesel fuel additives to replace the vital lubricity component in ULSD (Ultra Low Sulfer Diesel) fuel.
HISTORY:
ULSD fuel is the fuel currently mandated for use in all on road diesel engines. This fuel burns cleaner and is less polluting than it’s predecessor, called Low Sulfer Diesel Fuel. Low sulfer fuel contained less than 500 ppm of sulfer. ULSD contains 15 ppm or less.
As diesel fuel is further refined to remove the polluting sulfer, it is inadvertently stripped of its lubricating properties. This vital lubrication is a necessary component of the diesel fuel as it prevents wear in the fuel delivery system. Specifically, it lubricates pumps, high pressure pumps and injectors. Traditional Low sulfer diesel fuel typically contained enough lubricating ability to suffice the needs of these vital components. ULSD fuel, on the other hand, is considered to be very “dry” and incapable of lubricating vital fuel delivery components. As a result, these components are at risk of premature and even catastrophic failure when ULSD fuel is introduced to the system. As a result, all oil companies producing ULSD fuel must replace the lost lubricity with additives. All ULSD fuel purchased at retail fuel stations SHOULD be adequately treated with additives to replace this lost lubricity. The potential result of using inadequately treated fuel, as indicated above, can be catastrophic. There have been many documented cases of randomly tested samples of diesel fuel. These tests prove that often times the fuel we purchase is not adequately treated and may therefore contribute to accelerated wear of our fuel delivery systems. For this reason it may be prudent to use an after market diesel fuel additive to ENSURE adequate lubrication of the fuel delivery system. Additionally, many additives can offer added benefits such as cetane improver, and water separators or emulsifiers.
CONTENT:
In this study we will test multiple diesel fuel additives designed to replace lost lubricity. The primary component of this study is a side-by-side laboratory analysis of each additive’s ability to replace this vital lubricity. Additionally, claims of improving cetane, water separation or emulsification, bio-diesel compatibility and alcohol content will be noted. These notes were derived from information that was readily available to consumers (via the label and internet information) and none of this information has been evaluated for validity and/or performance. Cetane information has only been noted if the word “cetane” was used in the advertising information. The words “improves power” has not been translated to mean “improves cetane” in this evaluation. Information on alcohol content is provided by indicating “contains no alcohol”. Omission of the words “contains no alcohol” does not imply that it does contain alcohol. This information was simply missing in the information available to a consumer. However, the possibility of a form of alcohol in these products is possible. Additionally, information on dosages and cost per tankful are included for comparison purposes.
How Diesel Fuel Is Evaluated For Lubricating Ability:
Diesel fuel and other fluids are tested for lubricating ability using a device called a “High Frequency Reciprocating Rig” or HFRR. The HFRR is currently the Internationally accepted, standardized method to evaluate fluids for lubricating ability. It uses a ball bearing that reciprocates or moves back and forth on a metal surface at a very high frequency for a duration of 90 minutes. The machine does this while the ball bearing and metal surface are immersed in the test fluid (in this case, treated diesel fuel). At the end of the test the ball bearing is examined under a microscope and the “wear scar” on the ball bearing is measured in microns. The larger the wear scar, the poorer the lubricating ability of the fluid. Southwest Research runs every sample twice and averages the size of the wear scar.
The U.S. standard for diesel fuel says a commercially available diesel fuel should produce a wear scar of no greater than 520 microns. The Engine Manufacturers Association had requested a standard of a wear scar no greater than 460 microns, typical of the pre-ULSD fuels. Most experts agree that a 520 micron standard is adequate, but also that the lower the wear scar the better.
METHOD:
An independent research firm in Texas was hired to do the laboratory work. The cost of the research was paid for voluntarily by the participating additive manufacturers. Declining to participate and pay for the research were the following companies: Amsoil and Power Service. Because these are popular products it was determined that they needed to be included in the study. These products were tested using funds collected by diesel enthusiasts at “dieselplace.com”. Additionally, unconventional additives such as 2-cycle oil and used motor oil were tested for their abilities to aid in diesel fuel lubricity. These were also paid for by members of “dieselplace.com”.
The study was conducted in the following manner:
-The Research firm obtained a quantity of “untreated” ULSD fuel from a supplier. This fuel was basic ULSD fuel intended for use in diesel engines. However, this sample was acquired PRIOR to any attempt to additize the fuel for the purpose of replacing lost lubricity. In other words, it was a “worst case scenario, very dry diesel fuel” that would likely cause damage to any fuel delivery system. This fuel was tested using the HFRR at the Southwest Research Laboratory. This fuel was determined to have a very high HFRR score of 636 microns, typical of an untreated ULSD fuel. It was determined that this batch of fuel would be utilized as the baseline fuel for testing all of the additives. The baseline fuel HFRR score of 636 would be used as the control sample. All additives tested would be evaluated on their ability to replace lost lubricity to the fuel by comparing their scores to the control sample. Any score under 636 shows improvement to the fuels ability to lubricate the fuel delivery system of a diesel engine.
BLIND STUDY:
In order to ensure a completely unbiased approach to the study, the following steps were taken:
Each additive tested was obtained independently via internet or over the counter purchases. The only exceptions were Opti-Lube XPD and the bio-diesel sample. The reason for this is because Opti-Lube XPD additive was considered “experimental” at the time of test enrollment and was not yet on the market. It was sent directly from Opti-Lube company. The bio-diesel sample was sponsored by Renewable Energy Group. One of their suppliers, E.H. Wolf and Sons in Slinger, Wisconsin supplied us with a sample of 100% soybean based bio-diesel. This sample was used to blend with the baseline fuel to create a 2% bio-diesel for testing.
Each additive was bottled separately in identical glass containers. The bottles were labeled only with a number. This number corresponded to the additive contained in the bottle. The order of numbering was done randomly by drawing names out of a hat. Only Spicer Research held the key to the additives in each bottle.
The additive samples were then sent in a box to An independent research firm. The only information given them was the ratio of fuel to be added to each additive sample. For example, bottle “A” needs to be mixed at a ratio of “480-1”. The ratio used for each additive was the “prescribed dosage” found on the bottle label for that product. Used motor oil and 2-cycle oil were tested at a rationally chosen ratio of 200:1.
The Research Laboratory mixed the proper ratio of each “bottled fluid” into a separate container containing the baseline fuel. The data, therefore, is meaningful because every additive is tested in the same way using the same fuel. A side-by-side comparison of the effectiveness of each additive is now obtainable.
THE RESULTS:
These results are listed in the order of performance in the HFRR test. The baseline fuel used in every test started at an HFRR score of 636. The score shown is the tested HFRR score of the baseline fuel/additive blend.
Also included is the wear scar improvement provided by the additive as well as other claimed benefits of the additive. Each additive is also categorized as a Multi-purpose additive, Multi-purpose + anti-gel, Lubricity only, non-conventional, or as an additive capable of treating both gasoline and diesel fuel.
As a convenience to the reader there is also information on price per treated tank of diesel fuel (using a 26 gallon tank), and dosage per 26 gallon tank provided as “ounces of additive per 26 gallon tank”.
In Order Of Performance:
1) 2% REG SoyPower biodiesel
HFRR 221, 415 micron improvement.
50:1 ratio of baseline fuel to 100% biodiesel
66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel
Price: market value
2)Opti-Lube XPD
cetane improver, demulsifier
HFRR 317, 319 micron improvement.
256:1 ratio
13 oz/tank
$4.35/tank
3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment
Gas and Diesel
cetane improver, emulsifier
HFRR 439, 197 micron improvement
640:1 ratio
5.2 oz/tank
$2.60/tank
4)Opti-Lube Summer Blend
Multi-purpose
demulsifier
HFRR 447, 189 micron improvement
3000:1 ratio
1.11 oz/tank
$0.68/tank
5)Opti-Lube Winter Blend
Muti-purpose + anti-gel
cetane improver
HFRR 461, 175 micron improvement
512:1 ratio
6.5 oz/tank
$3.65/tank
6)Schaeffer Diesel Treat 2000
cetane improver, emulsifier, bio-diesel compatible
HFRR 470, 166 micron improvement
1000:1 ratio
3.32 oz/tank
$1.87/tank
7)Super Tech Outboard 2-cycle TC-W3 engine oil
Unconventional (Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/tank
$1.09/tank
8)Stanadyne Lubricity Formula
Lubricity Only
demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 479, 157 micron improvement
1000:1 ratio
3.32 oz/tank
$1.00/tank
9)Amsoil Diesel Concentrate
Multi-purpose
demulsifier, bio-diesel compatible, alcohol free
HFRR 488, 148 micron improvement
640:1 ratio
5.2 oz/tank
$2.16/tank
10)Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
11)Howe’s Meaner Power Kleaner
Multi-purpose
Alcohol free
HFRR 586, 50 micron improvement
1000:1 ratio
3.32 oz/tank
$1.36/tank
12)Stanadyne Performance Formula
cetane improver, demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 603, 33 micron improvement
480:1 ratio
6.9 oz/tank
$4.35/tank
13)Used Motor Oil, Shell Rotella T 15w40, 5,000 miles used.
Unconventional (Not ULSD compliant, may damage systems)
HFRR 634, 2 micron improvement
200:1 ratio
16.64 oz/tank
price: market value
14)Lucas Upper Cylinder Lubricant
Gas or diesel
HFRR 641, 5 microns worse than baseline (statistically insignificant change)
427:1 ratio
7.8 oz/tank
$2.65/tank
15)B1000 Diesel Fuel Conditioner by Milligan Biotech
Multi-purpose, canola oil based additive
HFRR 644, 8 microns worse than baseline (statistically insignificant change)
1000:1 ratio
3.32 oz/tank
$2.67/tank
16)FPPF Lubricity Plus Fuel Power
Emulsifier, alcohol free
HFRR 675, 39 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$1.12/tank
17)Marvel Mystery Oil
Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel.
320:1 ratio
10.4 oz/tank
$3.22/tank
18)ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive
Multi-purpose
Cetane improver, emulsifier, alcohol free
HFRR 696, 60 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$2.38/tank
19)Primrose Power Blend 2003
Multi-purpose
Cetane boost, bio-diesel compatible, emulsifier
HFRR 711, 75 microns worse than baseline
1066:1 ratio
3.12 oz/tank
$1.39/tank
CONCLUSIONS:
Products 1 through 4 were able to improve the unadditized fuel to an HFRR score of 460 or better. This meets the most strict requirements requested by the Engine Manufacturers Association.
Products 1 through 9 were able to improve the unadditized fuel to an HFRR score of 520 or better, meeting the U.S. diesel fuel requirements for maximum wear scar in a commercially available diesel fuel.
Products 16 through 19 were found to cause the fuel/additive blend to perform worse than the baseline fuel. The cause for this is speculative. This is not unprecedented in HFRR testing and can be caused by alcohol or other components in the additives. Further investigation into the possibilities behind these poor results will investigated.
Any additive testing within +/- 20 microns of the baseline fuel could be considered to have no significant change. The repeatability of this test allows for a +/- 20 micron variability to be considered insignificant.
CREDITS:
This study would not have been possible without the participation of all companies involved and dieselplace.com. A special Thank You to all of the dieselplace.com members who generously donated toward this study and waited longer than they should have for the results. You folks are the best. Arlen Spicer, organizer.
2002 Mustang GT
Smiley1 is offline
post #7 of 15 (permalink) Old 04-04-2008, 12:32 AM
I use Bio at 2% AND Stanadyne in every tank. I admit 28,000 miles isn't a lot to base it on, but I love the way the truck runs. After the new flash I am averaging 17+ mpg. I would use these before MMO or ATF - the reason being that Bio is a GREAT cleaning agent AND adds lubricity! I would think it would help flush the gas out also.
At 30,000 miles, I will pull the EGR to see if this program is effective at keeping EGR systems healthy.
Mark
bismic is online now
post #8 of 15 (permalink) Old 04-04-2008, 05:13 PM
FamilyRide's Avatar
This is a thread about a gy that filled his tank with gas, not another, another thread arguing snake oil and Mama's fried chicken diesel additives. If there was any damage, no miracle additive is going to fix anything.
Let them drain the tank, replace filters, refill with diesel and be on his way. If by some long shot chance there was some kind of damage, he'll know it.
It's not the first time it's happened; it won't be the last.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #9 of 15 (permalink) Old 04-04-2008, 05:51 PM
I totally agree.
gmalott is offline
post #10 of 15 (permalink) Old 04-04-2008, 09:06 PM
Well ........... when you drop a fuel tank, it is evident that it is hard to get all the contents out. Therefore the need to add something that will put the residual into solution in a way that will not harm components. There is a connection to additives and cleaning the fuel system in a way that will not generate a lot of soot and potentially cause issues w/ EGR systems and sensors. An EGR equipped system has a lot more to be concerned about than a non EGR system. Also, lubricity additives can help reduce any scuffing potential as the last bit is sent through the system.
(And also- Biodiesel is manufactured fuel, not fried chicken grease)
The posts on fuel additives have the potential to help and are really not "off topic".
Mark
post #11 of 15 (permalink) Old 04-04-2008, 09:43 PM
Smiley1's Avatar
I dont think anyone was suggesting that an addative could fix damaged parts.
2002 Mustang GT
Smiley1 is offline
post #12 of 15 (permalink) Old 04-06-2008, 03:37 AM
FamilyRide's Avatar
I'm not referring to 80% of the replies that took the thread off into another additive lala land , reply #3 implies it.
post #13 of 15 (permalink) Old 07-30-2008, 02:34 PM
I just did the same thing to my 05 6.0Lt with 25k on it. I have siphoned all of my gas out of the tank (got just as much out as I knew was in there), added 5 gallons of diesel and shook the truck up a bit, then siphoned that out as well. I am now going to change the fuel filters. Before I do this I would like to get an opinion from someone who has gone through this experience. What was the ending solution and how did it turn out?
shmee05PSD is offline
post #14 of 15 (permalink) Old 07-31-2008, 01:54 PM
hottip's Avatar
When I bought my '05 The lot monkey filled it with gas and I got about 2 miles down the road before I noticed the truck was running bad. I brought it in the next day and they drained the tank and replaced the filters. It now has 80,000 miles on it and never has caused a problem. I add Standyne every 2000 miles, with the price of diesel and a bottle of Standyne on every fill up I think it becomes a matter of economics. That puts the price od deisel over $5.50 a gallon. Are the benefits worth it?
2005 Lariat 6.0 LWB fourx4 3:73 Silver Metalic, Heated Captains chairs, Tow Command, Reverse Sensor, Intergrated Brake Control, Power Rear Window
MBRP Turbo back exhaust, Glasstite Canopy, billet grill, 162+
Scan Gauge 2
Bear - Flat Coated Retriever
2000 HD Road King
1998 Campion 542 Explorer fishing machine
The difference between stupidity and genius is that genius has its limits.
hottip is offline
post #15 of 15 (permalink) Old 08-04-2008, 04:57 PM
Thanks, that is what I did last week. When I finished it fired right up and I drove it over 500 miles this weekend. It ran fine the whole time. Did Ford say anything about the warranty after something like this happens?
