Front bearing replacement - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 08-02-2017, 12:48 PM Thread Starter
I have a 2004 F250 2wd that according to the tire guy I should have the front bearings replaced. Can I just replace the bearings or do I need to replace the hubs too? You Tube videos were mostly addressing hub replacement.
dje57171 is offline
post #2 of 4 (permalink) Old 08-02-2017, 01:14 PM
Texkenusmc's Avatar
In the 4x4 it is all one piece you can't just change the bearing. It might be made the same way.
Texkenusmc is offline
post #3 of 4 (permalink) Old 08-02-2017, 02:26 PM
Relentless007's Avatar
Do yourself a favor and change the entire hub assembly., its a whole lot easier than doing individual bearings. Shop around for hub assemblies, you may be surprised by how affordable they are. rock auto would be my 1st stop.
1997 F250 Heavy Duty 7.3 Powerstroke 4x4 Crew Cab, SRW, Automatic E40D
BTS Valve Body
Tru-Cool Trans Cooler
4" Turbo Back Diamond Eye Stainless Exhaust
Tymar Air Intake
TS Six Position Chip (stock,High Idle, +50, +75, +100, +120)
Tymar HPX line in hand but no installed yet
285/75r16 BFG All-Terrain KO2
ARE LSII Custom Color Tonneau bed cover
Color match Rhino spray in bed liner
Better To Be Tried By 12 Than Carried By 6
Relentless007 is offline
post #4 of 4 (permalink) Old 08-03-2017, 07:42 AM
x2
Eric
2004 Ford Excursion Limited
4X4, 6.0, 1/2004 Build date
Solid Black, Secret Service Look alike
Stock engine w/ EGR Delete
4" turbo back exhaust w/ Deleted Cat
2004 Ford F-250 King Ranch
4x4, 6.0, 2/04 Build Date
Chestnut Brown Metallic
Stock engine with EGR Deleted & ARP Head Studs
SCT Livewire TS from Innovative Diesel
2003 Ford Excursion Limited (Totaled 5/1/2015)
4X4, 6.0, 2/2003 Build date
Bone stock at this point
Very few issues over its life...
knightgang is offline
