How many miles on your 6.0L? Please respond... - Diesel Forum - TheDieselStop.com
LinkBack Thread Tools
Old 05-09-2015, 07:57 AM Thread Starter
For insurance purposes, I need to establish a viable average lifespan of this 6.0 Powerstroke Engine. If you read this thread and own a 6.0, please respond with your current mileage. If you run a fleet, please post your experience of obtainable mileage you have seen from these engines.
Mine had 222022 on it at the time of the accident. I need to establish the basis that this is as Ford Claimed, a 500,000 engine. I have no doubt mine would have made it. Just list mileage, thank you...
Eric
2004 Ford Excursion Limited
4X4, 6.0, 1/2004 Build date
Solid Black, Secret Service Look alike
Stock engine w/ EGR Delete
4" turbo back exhaust w/ Deleted Cat
2004 Ford F-250 King Ranch
4x4, 6.0, 2/04 Build Date
Chestnut Brown Metallic
Stock engine with EGR Deleted & ARP Head Studs
SCT Livewire TS from Innovative Diesel
2003 Ford Excursion Limited (Totaled 5/1/2015)
4X4, 6.0, 2/2003 Build date
Bone stock at this point
Very few issues over its life...
knightgang is offline
Old 05-09-2015, 08:56 AM
dje5717 is offline
Old 05-09-2015, 09:23 AM
As for fleet use I can respond. We had about 150 mixed 7.3 and 6.0 with well over 300,000 miles. And about 30 with over 500,000 miles. In our case tho hrs run were a more accurate determination. They hardly ever traveled very far but ran/idled nearly their whole lives. 12 hrs a day 7 days a week. Really abused in a harsh environment.
dannyboy950 is offline
Old 05-09-2015, 10:46 AM
2003 - only 79000
Built 4/14/03. Picked it up 4/25/03 - F-350, 6.0L, Auto, SRW, Lariat, Camper/Towing/ Pkgs, Heated Seats, upgraded TT mirrors, ESOF, reverse sensors, 2 tone (Tru blue & Arizona Beige)
SCT Livewire, SCT tunes, MKM custom tunes
Bullet proofed at 78K Miles 4/2015 with the following work done. (EGR delete, ELC coolant, blue spring, new (O rings, up pipe, alternator, coolant hoses, and belt) replaced DS valve cover, replaced oil dipstick tube, ARP studs, Ford HGs, heads magnafluxed (they were OK) turbo cleaned)
MDblackd is offline
Old 05-09-2015, 12:28 PM
generalmotor is offline
Old 05-09-2015, 01:24 PM
2006, 23354 mi (honest)
2006, F-350, 6.0, 4x4, Lariat, crew cab, long bed with Leer 180 shell
MagnaFlow 4" turbo back exhaust system
DC Power Engineering 190 amp alternator
Firestone 2400 Ride-Rite air bags
Ranch Hand Legend grill guard
Isspro four gauge pillar set
HID Bi-Xenon headlights
HFCM water drain plug
Fumoto oil drain valve
Accufab intake elbow
Bilstein 5100 shocks
Ctek batteries tender
DFuser coolant filter
Rotella Ultra ELC
Blue Spring mod
Bilstein stabilizer
ScanGauge II
Up-idle mod
Zoodad
ARCHOIL (AR9100, AR6200) & PRI-D & PRI-G Dealer
johnfjensen is offline
Old 05-09-2015, 03:37 PM
2006 - about to turn 87,000
'06 F250
  • blue spring upgrade
  • turbo back straight pipe
  • everything else stock
  • saving up for gauges and bulletproofing
endothermicbiped is offline
Old 05-09-2015, 05:35 PM
2003 286xxx
2003 Ford F250 6.0 PStroke. EGR Delete, Diesel site coolant Filter, 4" straight pipe, SCT tune with Vivans Looney Tune
stereodesigner is offline
Old 05-09-2015, 06:50 PM
'05 98,000
MikeMUSN is offline
Old 05-09-2015, 08:02 PM
had a 01 7.3 380,000- sold
2003 Ford Excursion 6.0 139,000 Miles...F-650 Dash
4-2-2015 Bulletproofing completed:
Completely Rebuilt and O-Ringed Heads.... ARP Studs....OEM Oil Cooler....RCD EGR Delete....OEM Head Gaskets....Glow Plugs....Glow Plug Harnesses....Injector O Rings....Thermostat & Housing...Valve cover, Exhaust, Intake Gaskets....Riffraff Blue Boots....Turbo drain Tube.... Sinister Oil Filter, Sinister Coolant Filter, Fumoto Valve Oil & Block....Fuel Pressure Gauge.... Coolant Temp Gauge....Oil Temp Gauge....Blue Spring....FICM.Com W/Atlas 40....Aluminum Radiator
Marinco Plug Mod
08-10 Side View Mirrors
Firestone Rear Air Bags
Harpooned/ Zoodad Mod
Redhead Steering
Leveled
"If you're lucky enough to live in Texas, you're lucky enough"
blackrod is offline
Old 05-09-2015, 09:30 PM
Mine is at only 175 000.
Ask over on the .org. Might get numbers you are looking for there. Look up Western Canadian Powerstrokes on Facebook. It's a large following and you may have some reputable numbers that you can attach to names, just remember to convert from km to miles where applicable.
Matthew
2005 F-350 ext. cab long box, FX4
Blue Spring
BCP High Idle Mod
DS Bypass Coolant Filter
Rotella Ultra ELC
Rotella T6 Synthetic; 0w-40 (winter) & 5w-40(summer)
EGR Cooler Delete
Bulletproof Oil Cooler, Oil Filter, & Amsoil Bypass Oil Filter
276 000km/172 500 miles as of April. 1 2015.
Canadian Mind is offline
Old 05-09-2015, 09:51 PM
Record holder in our fleet was 382,995.
Motor still running, truck was trashed.
Eric
2003 F250 6.0(Dead) 4WD X-Cab ~18k miles
Fabtech 10" - 38.5 Baja Claws
In Progress: ~700hp 6.0 build
theiba is offline
Old 05-09-2015, 10:15 PM
SnowRunner's Avatar
'05 - 63,500 miles
'05 F250 CrewCab Diesel
'04 Jeep Wrangler Unlimited, 4" lift, 35's
SnowRunner is offline
Old 05-10-2015, 11:17 AM
'04 - right at 200,000. only slight hiccups...
cricha is offline
Old 05-10-2015, 11:32 AM
2005 Excursion = 125K
2007 F250 = 98K
dillon134 is offline
