How Many Miles On Your 6.0L W/O Studs, Tuners - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 04-18-2019, 01:11 PM Thread Starter
Just curious how many miles some of you have on your bone stock 6.0s. No studs, tuners etc.... Have they been trouble free miles? What year?
2006 F350 Lariat Crew Cab
"The Red Sled"
MightyWhitey is offline
post #2 of 9 (permalink) Old 04-18-2019, 10:50 PM
'05 F350 XLT, 22K. master cyl. switch, bad ficm, stuck turbo, frozen rear calipers, rusted trans. cooler lines (radiator), inop. windshield washer (broken wire).
HOF350 is offline
post #3 of 9 (permalink) Old 04-19-2019, 10:32 AM
2003 Excursion Eddie Bauer with approx 145k miles, no tune or studs. New front axle seals, Atlas 40 ficm, switched to Rotella coolant, new oil cooler and base plate only cause I did an EGR delete and was that close, blue spring update, coolant filter, y-pipe, turbo drain pipe and seals, ICP sensor and pigtail. All this work was basically done because I did the EGR delete and figured while I was there I might as well. Did not technically need it and did the EGR delete versus getting a new EGR valve.
2004 F250 XLT with approx 155k miles. No studs but has had new injectors, EGR delete, coolant filter, aftermarket exhaust, and glow plug control module. Does have a fuel economy tune as it was provided by the shop who did the injectors for a minimal fee. I'm sure the tuner does have other tunes but don't use them, has enough power for what I need now.
mach158 is offline
post #4 of 9 (permalink) Old 04-20-2019, 09:31 AM
148000 miles '05 XLT regular cab. No mods. 90% miles on 100% bio diesel.
New injectors at 113,000. Replaced glow plugs at 124,000. Just replaced dust shield and rebuilt e-brake.
Current issue tow/haul not engaging or light just not illuminating.
Overall this has been a very good truck!
2005 F-350 XLT 4x4 SRW Reg Cab long bed 6.0PS tow command
1986 F-250 4x4 woods truck - well broke in 460 gas, they can hear the sucking sound all the way to Texas!
1989 F-250 XLT 4x4 SRW 7.3 IDI soon to replace the '86
robertwoodling is offline
post #5 of 9 (permalink) Old 04-22-2019, 11:10 AM
2328,000 miles. I had to replace injectors around 175K. Other than that, just peripheral problems and the usual preventative maintenance and internal oil leak revisions. Brakes are being a PIA right now and I am going to have to rebuild the front end soon.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
post #6 of 9 (permalink) Old 07-21-2019, 12:41 PM
Lucky?
2004 F250 King Ranch 167K, just maintence and regular services.
N8_6.0 is offline
post #7 of 9 (permalink) Old 07-21-2019, 05:14 PM
bobofthenorth's Avatar
2006 Lariat F250 - EGR delete from new, otherwise stock - 402,000 km right now. New injectors last winter, turbo rebuild. FICM @ roughly 200,000 km. Otherwise normal R & M - rad, water pump, injectors, misc harnesses, wheel end maintenance.
2006 F250 6.0 4x4
bobofthenorth is offline
post #8 of 9 (permalink) Old 07-22-2019, 10:27 AM
Cool 2004 6.0 Lariat Crew Cab 4x4
Bought used with 87K in 2015 so I don't know for certain. I haven't replaced much although I did add a coolant filer and secondary oil filter. I bought a Route 66 Warranty when I bought it (I highly recommend the company). Under that warranty it needed ONE injector, a transmission wiring harness and a couple of items I don't recall at the moment. I did have to replace the EGR valve right after getting it to fix a problem with stalling. As a preventative action, I would like to replace the head studs and at the same time the rest of the injectors, glow plugs and harnesses when I do to make the labor charges average out. Currently at 115K miles.
DailyDriver1 is offline
post #9 of 9 (permalink) Old 07-22-2019, 03:23 PM
Sounds like you got a good one. Unfortunately they are going to have a few nagging items that need attention. The owner that can resolve them himself (or with a good warranty) will most likely have a nice truck for years to come - especially when buying one w/ low miles!
Mark
bismic is offline
Similar Threads
Sinister Diesel Coolant Filter after 650 miles 6.4 Option 6.4L Power Stroke Engine and Drivetrain 4 09-24-2014 10:45 PM
Having a new 6.0L KR shipped 400 miles. What is best? SeppDietrich 1999-2007 Ordering Information 28 12-30-2002 05:41 PM
