Loud Knocking mystery? - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 04-14-2019, 07:02 AM Thread Starter
2004 6.0 with 328k miles, just bought it about 3 weeks ago, no issues other than some minor oil leak. Changed oil and filter. Added some fuel cleaner two tanks ago. No lights on the dash... two days ago I noticed an audible knocking sound while idling, then more when I’d come to a stop with no load. If I’d be under load it’ll go away. (Or even just put it in reverse from neutral) Driving is fine and quiet at any speed, no miss, no power loss, but the knock/rattle sound is there as soon as it’s back at idle. There’s no smoke other than a small puff at a cold start up. It’s just so loud I can’t ignore it. It’s definately louder on the driver side. Any ideas what this could be?
2004-6.0L is offline
post #2 of 9 (permalink) Old 04-14-2019, 07:03 AM Thread Starter
I just replaced the fuel filters last night and added some more Amsoil diesel fuel treatment to see if that’d help.
post #3 of 9 (permalink) Old 04-14-2019, 09:27 AM Thread Starter
Nothing is effecting performance, just a loud rattle/knock noise at low speeds. Could it be the flexplate?
post #4 of 9 (permalink) Old 04-14-2019, 01:53 PM
Record the sound and post. Not many people are going to offer a guess on just a description of a sound. Also, run the engine at various rpms when you do the recording.
Mark
bismic is offline
post #5 of 9 (permalink) Old 04-14-2019, 05:23 PM Thread Starter
Great idea, Thanks! Made a video but can’t post it. I’ll try a sound clip
post #6 of 9 (permalink) Old 04-14-2019, 05:36 PM Thread Starter
post #7 of 9 (permalink) Old 04-16-2019, 06:54 AM Thread Starter
Played that video for a mechanic, He said it "sounds like a loose heat shroud rattle"... Crawled under there and found the lower starter bolt missing and the top two were loose. New bolt in hand! M12 x 1.75 x 40MM
post #8 of 9 (permalink) Old 04-16-2019, 08:32 AM Thread Starter
Well that wasnt it...
post #9 of 9 (permalink) Old 04-16-2019, 10:19 AM Thread Starter
Took it to the shop, Torque converter backed off and was loose. Theyre applying loctite to the bolts and re-tightening for me. fingers crossed, thats it!
Similar Threads
Crazy loud noise I have no idea sportco8 '99 & up 7.3L Power Stroke Engine and Drivetrain 7 01-09-2009 04:56 PM
Loud Knocking - Sounds Very Serious.... RED-PSD-VAN '99 & up 7.3L Power Stroke Engine and Drivetrain 2 12-23-2008 11:20 AM
Knocking noise bob807968 Power Strokes 1994-1997 General 0 05-29-2008 12:09 PM
New injectors and still horrible knocking noise ClassicFordGuy 7.3L IDI Diesels (Not Power Strokes) 20 01-14-2008 10:23 PM
Extremely Loud in Morning, EBPV? w74bronco '99 & up 7.3L Power Stroke Engine and Drivetrain 14 12-21-2005 07:28 PM
